Question about Uniden BC248CLT Base Scanner
Uniden marine radio
The old cb radios could be peeked for more output. Can a marine radio be peeked?
  • 170 Answers
Cb radios are usally detuned to meet fcc regulations. The other radios usually are peaked out all the way.
Posted on Jan 31, 2009
Need a schematic for a UNIDEN HH979 VHF Marine radio.
Go direct to UNIDEN or a repair statin that services this unit
Oct 15, 2014 | Uniden Hh979 Vhf Marine Handheld Radio...
I have a Uniden Atlantis 260 that will not transmit. I have checked the battery and it is fine. The unit is only 2 yrs old and the 12 month warranty has run out.
thats the problem with warrenties.They always run out before the product breaks.Did you let moisture get inside? I don't think its that much of a problem. take it to a cb shop and let them do it up for you.
Dec 03, 2013 | Uniden Atlantis Hand Held Vhf Marine Radio...
W do I turn off squelch control on a digitech DC-1065 marine radio hand held 5 Watt
Hi David,
Before I try to give advice, I need more info.
I possess a Digitech DC1065 UHF 80 Channel CB hand held, so there seems to be some confusion here.
I live near Perth, Western Australia.
Firstly, How many channels does your radio have?
If the answer is 80, then what you have is a UHF CB, not a marine band radio.
Marine band is VHF with 87 Channels, in Australia that is, and the default channel is always 16.
Digitech are an Australian radio manufacturer, so you'll get great backup service.
If your radio is not defaulting to Ch16, then I am right about it being a UHF CB.
Therefore, it is useless for VHF anything, let alone Marine band.
I'm almost 100% sure this is a UHF CB in your possession.
Try this to prove me right please.
Reply to me with your Country and nearest city, I'll then be able to find a solution for you real quick, though I believe I already have.
Looking forward to your response.
Regards,
Peter
Dec 21, 2012 | Motorola Walkie Talkie 2-Way Radio
Looking for the best micaphone for cobra 148gtl
Turner+2 Ham CB Radio Microphone Transistorized SSB Base Station Shark Fin
turner microphone ' eBay
Jul 29, 2012 | Cobra 148 GTL 120-Channels Base CB Radio
I NEED TO KNOW HOW TO ENTER CODES INTO THE SCANNER
hi what do you mean by codes ,or do you mean frequencies ,to enter frequencies press the program key enter the frequency you want to listen too and press enter you can select different banks for different communications ,such as emergency,air traffic,marine,rescue,etc hope this helps
Jan 08, 2011 | Uniden Bearcat Pro PC68XL 40-Channels Base...
Have new dx959 doesnt get out very far talking 100yrds or so use rdking 56 mic mic works fine on old radio pc 78 and gets out fine also are 959 radios ok or junk has good reception
The DX959 has an output power setting knob. It's located next to the channel selector and is labeled RF Power. Turned counterclockwise will reduce output power. Turned clockwise will increase output power. Your switch is probably turned all the way counterclockwise resulting in low transmit volume.
Also, make sure the wiring for the RK59 is correct for the Galaxy. Even though it's a 4 pin plug, the pinouts may be different for the Uniden and Galaxy radios. Do a Google search for mic pinouts for your two radios to check.
Jul 12, 2009 | Galaxy Radios DX-959 40-Channels Base CB...
I just purchased a uniden solara dsc.I HOOKED IT UP AND THE NOAA WORKS BUT I TRIED TALKING AND NOTHING HAPPENED.(I have a tractor with a radio and neither of us could hear each other).
The Uniden Solara is a MARINE RADIO not a CB. Marine (boat) radios operate in the VHF-Hi range and CB is in the VHF-Lo range. You also need a license to operate a marine radio, or you can identify yourself with the name of your boat but you MUST be in the water.
Jun 20, 2009 | Uniden OCEANUS-DSC-BK Base CB Radio
ONLY 2 WATTS DEAD KEY AFTER BEING PEEKED/TUNED AND MOD KIT.
it sound that a can has been set of balance, or the output  transister has crashed. did you up grade the output before ajusting for more output.
May 20, 2009 | Uniden Bearcat Pro PC68XL 40-Channels Base...
Corbia marine cb radio 41 plus
If it is a CB radio it is limited to what all the other cb radios do. You can get them "tuned up" but its illegal and depending who does it can harm the radio.
Dec 21, 2008 | Cobra 18 Wx St Ii Mobile Cb Radio
Modification of frequency output of uniden pro 510xl
deweyp, hi, if you are wanting to turn the power up some on the radio, do this; tune L4, L5, L6, L9 for
maximum RF forward output. There are 2 versions of the radio, and both are listed as 510xl. If you are wanting to expand the freq's or add channels, then no, there is no mod for that radio. If your going to tune the radio for more power, make sure you have a power meter to watch the output. It is preferable to tune into a dummy load so your not broadcasting over the air. You tune the radio for peak output, using a steady awwww sound in to the mic. Just be careful as that radio has a fairly small driver and final transistor. Don't want to let the factory smoke out of it,,,
Here is what the little variable adjustments are for and what they control;
VR1 Squelch
VR2 TX Meter
VR3 RX Meter
VR4 RX IF Gain
Hope this helps you out, let us know,, Mechanic
Feb 19, 2008 | Uniden PRO510XL 40-Channels Base CB Radio
Uniden BC248CLT Base Scanner Logo
81 people viewed this question
Top Uniden Radio Communications Experts
Iron
Iron
Robert McClure
John
John
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
