Question about Whirlpool Duet GHW9150P Front Load Washer
To much goes into the washer
It seems like the water level is to much
  • Whirlpool Master
  • 17,130 Answers
If the water flows though the inlet then the flow pressure should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Test a pressure switch: Click on : http://www.youtube.com/watch?v=HZZ2bDMspj8
Posted on Jan 24, 2013
How do I increase water level in my wfxd8400uc?
I get this complaint a lot from home owners , I take it you have just got your first front loader washer , and you don't think it adds enough water to wash anything , this is the water saving feature of front loaders
but a simple test I tell most folks to do if they think there water level sensor is not working right
set washer to auto load sense on water level , normal wash cold water, permapress add nothing to drum completely empty! no soap unless you have a auto soap dispenser then it wont start to you add some and close door
start cycle wait till fill is complete just as it goes to agitate stop cycle (plug can be pulled for this if buttons have locked out )and open door see if water level is two fingers wigth under door seal , if its close your ok if it's a long way off then contact a repair department to look at auto sense water level
May 07, 2015 | Washing Machines
I HAVE A MAYTAG PERFORMA WASHER MODEL#pav3240. the washer continues to fill during rinse cycle and overflows the top. If i turn to spin cycle water drains out and machine goes through cycles. it seems like...
Clean out the water-level switch air dome tube AND the the connection to the tub where the tube connects. It may well be full of gunk and not allowing the water level switch to react quickly enough.
Jun 06, 2017 | Maytag Washing Machines
When washing machine fills with water to rinse, the water does not cut off.
Easy fix. No parts needed. All washers have a water level switch of some sort.
Each switch has a small rubber tube attached to it. The tubing goes down under to the base of the tub. As the water level rises the pressure builds inside that tubing. When the desired level is reached the switch kills the water works and starts the motor works. Off she goes a washing. What you must do is find the water level switch and remove that hose. Blow out the sediment in the base of the tub and reattach that hose securely. Then pump out the water in the tub so that the pressure can have a chance to build in that tubing. Retry and party on!
I have over 500 free service manuals at my appliance digest link HERE
Mar 26, 2011 | Washing Machines
Found water underneath washer, clothes seem to have more water in them, washer doesn't seem to be draining properly
Can be due to clogging in the drain pump/valve which is not draining off due to the dirt accumulation. remove and clean- back flush to see if this works.
Also make sure that the level of the washer is tilted to the drain side valve as no water must remain but drain in gravity. use a spirit level to set.
Mar 21, 2011 | LG WM-1832C Front Load Washer
My washer wont aloud my water to go insidethe washer
If the washer makes a humming sound, but no water goes in, and there is no other action, the water shut-off valve is off (outside the washer), or the pipes are frozen.
For top-load washers: If the washer starts agitating immediately without filling the tub, the water level switch is bad (falsely senses the tub is full already) or the water level sensing hose plugged up while there was water in the machine, and it has still has pressure inside it to fool the level switch.
Nov 27, 2010 | Maytag Washing Machines
GE Washer agitates when I try to fill it up with water,wont fill
You have a bad water level switch or a clogged plastic hose that goes to the water level switch.
Use a putty knife to open the front panel. The clips are at the top right and left sides just below the top lid. Push in on the clips and pull out on the panel.
On the left side of the tub you will see the air dome with aplastic hose connected.
Remove the hose and insert a small wire into the air dome hole to clean it out ouf soap scum. Then, blow through the hose and listen for a faint click in the water level switch. Also check the hose for a hole or being pinched.
The set the timer for spin and run a spin cycle then retry the water level and wash cycle.
Apr 01, 2009 | GE WBSR3140DW Top Load Washer
Kenmore washer overflows during rinse cycle.
SOME OF THESE MACHINES HAVE TWO PRESSURE SWITCHES IN THEM, ONE FOR THE MAIN WASH WATER LEVEL AND ONE FOR THE RINSE WATER LEVEL. CHECK FOR A PLUGGED AIR PRESSURE HOSE FIRST AND THEN CHECK THE PRESSURE SWITCHES.
Jan 27, 2009 | Kenmore 22422 Top Load Washer
Washer water level low, clothes come out dry !!
This is the water saver feature and the only solution may be to put it on the maximum wash cycle to get clothes really clean.
These washers normally get the clothes almost dry.
Mar 04, 2008 | Frigidaire GLTF1670A Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
20 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
