Question about NetGear Computers & Internet
Need password for n200
I need a password for my Netgear N220 WNR2000 I see a security number there . Is that the password??? Nancy
  • 7,627 Answers
If the NetGear has a Security Key (password) , only you or the person that set it up will have the password. Has it been secured? Here is a user manual: http://www.lmi.net/wp-content/uploads/WNR2000.pdf
Posted on Jan 23, 2013
buffalonyman
  • 1865 Answers
SOURCE: netgear wnr2000
You should not need any software to connect to the router. Use connection wizard in VIsta to setup the internet connection
Posted on Aug 16, 2009
  • 27 Answers
SOURCE: Problems connecting with a Netgear WNR2000
your easiest solution is probably just to reset everything back to defualt settings. there is a small pin hole button on the back or bottom to do this.
hope this helps!
Posted on Aug 24, 2009
bob_computer
  • 3153 Answers
SOURCE: I have a netgear WNR2000 but i cant access my IP address
There are a few things you can do to help reliability
You should first make sure that the modem and router are individually set up correctly.
I do have a guide for that.
Once that is done you should consider giving out proper IP addresses
Big business does this for security and reliability and it is no different for home users except maybe easier
Read the guide for router and modem first and if any of it may apply to you then try and do it.
The second part deals with IP addresses and this may well help you
I have a selection of computers laptops servers at home on a small network
It is quite some time since I last had to do any sort of system wide shutdown
Try the following procedure and write down anything you change so that if you need to go back you know what was changed.
Connect ONLY the MODEM to a pc and nothing else
Go to the start menu and select RUN
In the box type "cmd"
Now in the black screen that has come up type "ipconfig /all"
Take note of the numbers that are in 4 groups e.g. 192.168.1.1
Also take note of the name in front of those numbers !
Take note of the DEFAULT GATEWAY
Now do the same thing with your ROUTER
If that too has the same IP as your modem in "default gateway" then you need to fix that issue as that is probably a part of your problems.
The fix for router modem conflict is to set the router to use a different IP range.
To do this only have the router connected (by wire) and open an internet explorer page (it will fail but that's ok)
In the address bar type the number you got for default gateway above for the router e.g. 192.168.1.1 and press ENTER
When it asks for the user name, give it the one you gave it when you set the router up or the default one from your manual
Also give it the password you gave it when you set it up or once again the default one from the manual.
You now need to look for a box that has the number you just used to get into the router.
It may just say IP address or Starting IP or something similar
That is the number you should change. I usually change the third block e.g. 192.168.2.1 as opposed to 192.168.1.1
You should also have some DNS numbers from the checks further up with the MODEM
You should find the DNS boxes and place those numbers in there. This will allow your computer quicker access to finding things on the internet
Now look for the save settings button and do so.
Reconnect the modem and router. The cable from the modem should go to the YELLOW socket on the router.
Power up the modem and WAIT until all the correct lights are on.
Then do the same with the router.
Now power up a pc and check that you can surf without problems
If not then the problem may lay elsewhere. Go back and re-check.
Now to issuing IP addresses and why.
The computer has to knock-on the routers door and ask for directions home as its address changes everytime it leaves home (switched off)
You are going to give it a permanent key to its own door. Write down all that you do once again.
The same applies to both wireless and wired connections.
You may get an occasional error regarding the IP address already being assigned tell it to ignore and go ahead.
Call up your control panel and select Network Connections
If you have more than one don’t worry
Right click the first one and select properties
Scroll down to Internet Protocol (TCP/IP) highlight it then click properties
There are boxes here where you are going to type numbers.
Click the "Use the following IP address"
If you changed your router to lets say 192.168.2.1 Then I would use 192.168.2.10 as the first number
The second box is 255.255.255.0
The third box would be 192.168.2.1 (same as your router address)
The two DNS numbers at the bottom can be got from the numbers you wrote down early on when you just had the modem connected
E.g. 207.147.239.12
207.147.239.200
Now click OK
If you have more than one connection available then go to the next one and do the same EXCEPT the first IP
I would use 192,168,2.11. The rest would be the same as before.
Now move on to the next computer and do the same again but this time in the first box I would jump by ten so the IP would be 192.168.2.20
Again if it has more than one connection then do the same as above and advance the number by one in the top box
Next machine same deal advance by ten. Once you have all your computers done then shut EVERYTHING down
If your problems are mainly wireless related the next part might be of use.
It is more than possible that the location of your router or co channel interference is causing disruption.
If its channel interference try setting your router to auto for channel selection.
If you are not getting any more than a 10mb connection to the router consider moving the router
It may be a problem with the windows wireless config
To turn of wireless zero config open control panel, click administrative tools, now services, then scroll down to wireless zero config.
Double click on it then click stop. Then set the service to manual. Make sure you click the APPLY button before hitting OK. You can now close the rest of the windows.
I would suggest at this point you also do a shut down and restart.
What you have just done is tell windows to stop messing about looking at other peoples wifi to see if it fancies something better (sound familiar ?)
You told it that it only has eyes for you ;-)
If you have any problems use the information you wrote down to back step to a working point and then double check from there
I know this looks like a lot to do but for most of us with more than a couple of computers at home it is usually worthwhile
Posted on Nov 30, 2009
govinda123
  • 2260 Answers
SOURCE: forgot wpa key on ps3 netgear wireless wnr2000
Is there any computer online using the router.
If yes then you
can open the router set up page on that computer.
router set up
page is the page where you can check all the router settings.
Click Here for more information about the routers and network
Posted on Jan 16, 2010
SOURCE: Netgear wnr2000 router ICON missing,
i there it mite be windows at fault there it self .can you go back to an early restore point. falling that get your windows disk and run it from bios boot from cd when you first switch computer on and press any key to boot from cd and when you enter the blue screen don't hit the f2 or the f6 mode wait and till further down the line after it said starting windows and you should see an opion saying press (r) to repair and follow the instrushion when you get to c:\windows try this chkdsk /r
so it for examble how it will look c:\windowschkdsk /r then press enter
Posted on Feb 07, 2010
Wnr2000 wont connect to kindle
I think it is a Kindle settings issue. Does the NetGear work with your other devices? Is it Secured with a password?
Dec 30, 2012 | NetGear WNR2000 Wireless Router
Wep key for wnr2000
Hello. If you need WEP key or you would like to setup wireless security for WNR2000, access the router user by typing http://www.routerlogin.net or 192.168.1.1 in the address field of your browser and then press Enter.
Enter admin for the router user name and your password (or the default, password).
After logging in. In the main menu on the left, click on Wireless Settings, from there you can check the WEP or you can setup wireless security from there if you haven't done so.
Glad to be of service. Have a nice day.
Oct 28, 2011 | NetGear WNR2000 Wireless Router
Reset password
The default password for the router's Web Configuration Manager is password. NETGEAR recommends that you change this password to a more secure password.
To change the administrator password: 1. On the main menu, under Maintenance, select Set Password to display the Set Password screen. 2. To change the password, first enter the old password, then enter the new password twice. 3. Click Apply.
Best of luck!
Sep 06, 2011 | NetGear WNR2000 Wireless Router
I want to secure my router with a password.
Connect a LAN cable from the Netgear to the LAN port on yourcomputer, open a browser and enter the Netgear configuration URL -
http://192.168.0.1
The default login = admin
The default PW = password You can now change the admin password and configure thewireless settings.
Go to the wireless configuration and set up the SSID and WPA or WPA2encryption.
Apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on thislink and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Aug 19, 2011 | NetGear WNR2000 Wireless Router
How do i get my wep key
Log into the router and go under wireless settings.
Mar 28, 2011 | NetGear WNR2000 Wireless Router
Change password
Here is a direct link to show you how to change the existing password for your router, simply copy and paste link into address bar and hit enter.
http://pcsupport.about.com/od/netgear-default-passwords/a/wnr2000-default-password.htm
Mar 27, 2011 | NetGear WNR2000 Wireless Router
Put a blackberry phone on my wireless network and now the netgear router is asking for a securty key to get i pods x box etc on
To find the security password for your netgear router please follow these steps,
1. Use an Ethernet cable to connect a computer to any one of the four LAN ports of the NETGEAR router.
2. In a web browser, enter the router's IP address - either http://192.168.0.1 or http://192.168.1.1 by default.
3. When prompted for a Username and Password, enter the default username and password (admin; password) unless you have already changed it.
4. In the left side click on Wireless settings , Under
Jan 06, 2011 | NetGear WNR2000 Wireless Router
How do i turn off the wps security on my netgear wnr2000
how do i turn off wps on my netgear router i have reseting it but it keeps coming on
Nov 16, 2010 | NetGear WNR2000 Wireless Router
Need to get my WEP
  1. In a web browser, enter the router's IP address - either http://192.168.0.1 or http://192.168.1.1 by default.
  2. When prompted for a Username and Password, enter the default username and password (admin; password) unless you have already changed it. NETGEAR recommends changing the default password to increase the security of your network.
  3. Select Wireless Settings from the Setup menu in the left-hand navigation bar.
  4. There you can set the wep and wpa settings
Nov 09, 2009 | NetGear WNR2000 Wireless Router
hope this helps!
Aug 24, 2009 | NetGear WNR2000 Wireless Router
Computers & Internet Logo
46 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
