Question about Xerox Phaser 3040B Laser Printer
Xerox phaser 3040 paper jam
I have a paper jam and i can't figure out how to get it "unjammed".
SOURCE: Xerox Phaser 6250N Jam at Registration Roller
I use to have the same problem, but downloaded a fuser patch at the Xerox site:
http://office.support.xerox.com/SRVS/cgi-bin/webcgi.cgi?new,kb=Phaser_6250,company=%7B5AC8CA72-62D5-4658-8D6F-D2F393C98A63%7D,ts=xo,ques=ref%28security_level%29:1,ques=ref%28Country%29:45,/,case=R1001052703
if that link doesn't work, go to the Xerox site and look in the area:
Home > Support & Drivers > Phaser 6250 > Knowledge Base
ID: R1001052703Phaser 6250 Support Knowledge Base Jam at Registration Roller (code Jam RR)
Follow the instructions and hopefully your printer problem will be resolved.
Posted on Oct 07, 2008
SOURCE: Xerox 6250 - Jam at Registration Roller
Ik heb een deregelijk probleem gehad, ook bij merdere printers tegelijk. De oorzaak was achteraf logisch. We hadden een nieuwe zending briefpapier waar een bepaalde film op zat waar de printer niet tegen kan. Logisch, want het kan niet zijn dat alle 3 printeres tegelijk hetzelfde mankeren.
Ander papier erin. De eerste hoeveelheid zal nog problemen geveb tot der olletjes vrij zijn van de vettigheid.
groeten,
G.Eijken te Hoorn
Posted on Nov 15, 2008
  • 2072 Answers
SOURCE: Xerox Phaser 8560 display error
There is a known issue with that display. Call 1-800-835-6100 and tell Xerox you have a problem with the diaplay, They should replace it free.
Posted on Jan 27, 2009
  • 526 Answers
SOURCE: Phaser 8560 error code
Most likely you are using generic ink or ink not made for that specific machine. The black ink is the one causing the problem. the printer will then need to be reset.
Posted on Apr 15, 2009
SOURCE: xerox phaser 6120 laser printer paper jam fuser
Fix, well i am a dentist in Marysville washington and just got this printer from a family member and same thing was going on.
I looks like paper stuck in the middle roller. I just got a small mirror and pair of dental tweezers and removed a lot of jammed paper. it works fine now but you need do go to the dental section in drug store, so you can see where the jam is at.
Posted on Oct 26, 2009
How do I clean toner from machine?
Probably it's the jammed paper that might caused the error. I suggest have it serviced by the technician. Be aware of the paper handling capacity of your machine to minimize jamming:
3300MFPV_X
Phaser 3300MFPV/X, Copy/Print/Colour Scan/Fax, B&W, 28 ppm, A4, 1200 dpi, 50-sheet ADF, 250-sheet Paper Tray, 50-sheet Multipurpose tray, 150-sheet Output Tray, 96 MB, Automatic 2-sided printing, USB/Ethernet, PCL/PS3, Scanning software, 220 V
Apr 28, 2014 | Xerox Phaser 3300mfpv/x Print Copy Scan...
My phaser 3040 xerox printer says there is a paper jam, but there isn't
I suggest You Go to Official Xerox Printer Page For You Xerox Printer Problem On Below Xerox forum URL Link: Clearing Paper Jams In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On :
Xerox Printer Support
Feb 27, 2014 | Xerox Phaser Office Equipment & Supplies
Xerox Phaser 3040 printer stopped after the first 3 pages
what message did you get?
Check the error history and job history for errorcodes.
May 28, 2013 | Xerox Phaser Office Equipment & Supplies
Paper jam and cannot see any paper
This PDF gives step-by-step help on clearing paper jams on the 8860MPF:
http://download.support.xerox.com/pub/docs/8510MFP/userdocs/any-os/en/user_guide_en.pdf#G12.1054794
Apr 14, 2013 | Xerox Phaser 8560MFP Laser Printer
Xerox phaser 3117 paper jam problem, how to solve it
If paper jams every time, just open printer cover, pull out toner cartridge and you see paper feed roller it is rubber, just clean roller with alcohol and cloth.
I hope this help!
Mar 31, 2011 | Xerox Phaser 3124 Printer
My Phaser 8500 will not print and has error 08,045,43:75066 - Anyone know what this means?
The Xerox support site indicates there is a paper jam to the printer, so you should check the paper tray, front and exit cover for any jammed paper then power off and back on the printer. Have a look here: http://www.support.xerox.com/support/phaser-8500-8550/support/enus.html?operatingSystem=win7x64&fileLanguage=en
Feb 24, 2011 | Xerox Phaser 8500/DN Printer
XEROX PHASER 6180 SAYS PAPER JAM, I CLEARED PAPER JAM, PUT IN NEW CARTRIDGE, AND IT STILL SAYS PAPER JAM
Check the fuser for paper stuck in it.
Check that the 'paper out' sensor arm (in the fuser) is not broken. If it IS broken, you'll need a new fuser.
Mar 16, 2010 | Xerox Phaser 6180N Laser Printer
Jam at registration roller?
I can tell you "exactly" where your jam is !
If you open the top cover and remove the imaging unit. Look straight down, and you will see a black rubber roller about 8 inches long. this is the registration roller. If you remove the four screws (two on the left side, one in the middle, and one on the right) and gently lift up your wrinkled paper will be right there. Since your are not replacing the registration assembly you do not need to remove the two connectors that attach to the main board from the registration assembly. Just remove the paper, reseat unit, and put back screws. There is a test to see if your unit has the fix that gives the drive assembly a little more power to aviod jams in the future. This is a software fix.
I believe it's available on the xerox website as a postscript snippet. xx.ps
Mar 17, 2009 | Xerox Phaser 6250 Laser Printer
Xerox Phaser 3040B Laser Printer Logo
288 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
