Question about Electrolux Dishwashers
WT38UK Scrolling Fill Error
I have a WT38UK under counter commercial dishwasher and it scrolls FILL across the display. It fills the boiler then fills the machine upto the water sensor on the bottom left then just sits there with FILL scrolling. I can press the drain button which goes through the cleaning and draining cycle until END is displayed.
rickzilla
  • 706 Answers
SOURCE: DIshwasher doesn't drain or fill
Hello annie8866,
First off.. unplug power and then reapply power to it for a little while to see if a power reset will put it back in the proper sequence.. next, check inside the base for a drain inlet and a filter/screen and clean anything you see out of it.. Then try cycling it without dishes to see if it will run thru a cycle and drain properly.. Its ok to add a cup or two of white vinegar during the wash process to remove byproducts of the wash from the inner components.. Make sure the drain hose is not clogged or kinked up.. Try these things and get back to me if it is still misbehaving..
Posted on Sep 30, 2008
  • 1462 Answers
SOURCE: My bosch dishwasher does not fill with water (although it drains)
most bosch have the inlet valve at the end of the fill pipe and it has an anti-flood device.
try turning off the water, take off the fill pipe then reconnect it and see if this works.
taking off the fill pipe resets the anti-flood device
Posted on Nov 26, 2008
fphandyworks
  • 56 Answers
SOURCE: BOSCH dishwasher SHU5302UC12 water will not fill
was the safty tab on the inside of the units water receiver removed?
Posted on Jan 05, 2009
  • 236 Answers
SOURCE: my carlton dishwasher fill and drains but does not wash
sounds as though the wash motor/pump is jammed or has seized therefore no wash.
Posted on Mar 16, 2009
SOURCE: Miele G 7856 Commercial Dishwasher
Hi. The above machine stops mid cycle and drain/fill light is on, also error code F3E, have cleaned both hot and cold water inlet filters, also checked drain pump and drain line, all ok. Machine drains with no issues and fills with hot water, runs for a while then shuts down.
Any ideas?
Posted on May 29, 2010
Comenda lf321 commercial. Why doesn't it fill?
There may be a defective fill valve or float switch
Dec 17, 2015 | Dishwashers
Dishwasher starts to fill, then displays watertap error.
Not enough information to answer. Need manufacturer and model number before we can help.
Oct 30, 2015 | Bosch Dishwashers
How Do I fill the dishwasher with water to first start it
Close the front access door and turn on the power switch. It should automatically fill.
Oct 02, 2014 | Hobart C44a Commercial Dishwasher
Insinger commercial dishwasher ...water keeps overflowing when unit is off. cannot find a repair manual for GS 14
Most likely a leaking fill valve...the seat may be worn out or there may be some debris in it causing it to not fully close.
Perhaps Insinger offers a valve rebuild kit. parts@insingermachine.com
Sep 17, 2009 | Dishwashers
The hobart lxih is stuck in delime.
To reset or clear delime message, on control board there are 3 buttons. from power off, drawer open, manget on door switch, door closed, hold PROG on board and press the ON key on keyboard. pressing select moves to next poption, up arrow increases setting. step through select until you see delime, settings for LXi are de for disabled, and 1 through 65= x100 cycles. rg if set at 5, after 500 cycles the message apears. To keep the settings and clear the message a delime sequence needs to be run precisely as described.
DO NOT MIX DELIME ACID, RINSE AGENTS OR OTHER ACID WITH BLEACH PRODUCTS, OR HAZAEDOUS GASES WILL FORM.
With machine off, remove rack , close door, press and hold wash/delime key and press ON. Delime will be lit on display, release wash/delime key, and let machine fill. you should then see ADD and DELIME on the display, open the door and add the delime agent following supplier's instructions precisely. close the door, press wash, delime will flash. After delime is complete power is turned off. Inspect the machine and repeat if necessary.
DO NOT LEAVE THE ACID IN ANY LONGER THAN RECOMMEDED.
Jun 18, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Error code
The unit did not reach it's full fill level after 10 minutes.
Check that water is not siphoning out as quickly as it fills. The drain hose must go up and attach under the counter top or go through a hole in the cabinet at, or near the counter top prior to connecting to the drain under the sink.
Also check that water is coming in at a sufficient level. Check the water shut off under the sink to be in the full open position. The screen in the water valve could be blocked, or the valve itself could be bad. If no water is coming in at all, make sure there is nothing (silverware) under the float. If not, suspect a bad valve.
**Remove power from the appliance prior to attempting any repairs.
May 10, 2009 | LG 24 in. LDF 7811 Stainless Steel...
E4 error after attempting to fill and get to temp
This is what I found for the E4 code...hope this helps...and thanks for rating my effort...The Fang.
Machine won't fill or won't fill high enough(LX18, LX30 display shows "E0," "E2," "E3," or "E4")
1.Low water pressure — check for clogged hose strainer; check that site water pressure meets minimum flow pressures.
2.Make sure probes are clean.
3.No water pressure — main water supply valves may not be working.
4.Drain valve open - turn machine off to drain machine, then on. Repeat twice (this assists in clearing any drain valve obstructions). Wait for machine to reach READY mode and press WASH. Slowly open door several seconds later and note water level. Close door; 30 seconds later, open door slowly and check that water level is the same as it was. If not, repeat the
OFF-ON procedure.
5. Delime machine.
Apr 28, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
E-2 Error on LX30 Hobart Dishwasher
E-2 error is a fill problem. Water did not reach the lower probe within the time out. (innitial fill only
1- Is the bottom probe clean?
2- No fill water (check valve, hose,fill screen in end of hose, and fill source.)
3- low water pressure, should be 20 PSI flow.
4- Fuse 1FU blown.
5- Check wiring to fill valve.
6- Check relay board function.
Feb 15, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Any ideas?
Aug 20, 2008 | Miele 24 in. G638 Plus Free-standing...
Randomly Fills Up & Spills Over
If your unit fills with the power OFF, 99% of the time it is a bad fill solenoid, OR DEBRIS in the solenoid. But before replacing it, I recommend inspecting it.
The fill valve is in the front area behind the kick panel. It has a large brass cap with little notches on it. Turn off the water and inspect the valve for debris. If you take it apart slowly, and catch the plunger and spring, it is easy. The only trick is having a pair of channel locks big enough to remove the cap!
Good luck. Mike
Jun 09, 2008 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Dishwashers Logo
32 people viewed this question
Top Electrolux Dishwashers Experts
Mike
Garth Jackson
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
