Royal super guard laminator plus
Laminating sheet went in put didn't come out
leroyal
  • 2120 Answers
SOURCE: How do I remove jammed
Use a box cutter and reverse the feed
Posted on Aug 29, 2008
checkitright
  • 1362 Answers
SOURCE: A laminating sheet is stuck
OOOOooooooooohhh!!!!!
Hate to tell you, BUT, the laminate is melted on the fuser. You learned the hard way, htere are specific laminates for different types of machines, the reason is because of the amount of heat it can tolerate. If you look in the back of the box it will tell you what machines they are good for, if yours is not listed, you should look at the manual or the website.
You will have to take it apart and remove the melted plastic, with hopefully minimal damage to your machine, otherwise the fuser will need to be replaced.
Posted on Sep 05, 2008
  • 199 Answers
SOURCE: Laminator
ok we think again
Posted on Jun 22, 2009
SOURCE: I have a Ibico el12 ii laminator and need to know
You need to put your document in a carrier to prevent the heat from buckling the pouch before it makes it into the rollers. I've had a similar problem in the past before I remembered to use the carrier.
Posted on Oct 02, 2009
  • 17 Answers
SOURCE: Hi, Our Ibico IL19VT Laminator (A2)
You can open this yourself but i recommend sending it for repair. If you decide to do it yourself here is how: turn the unit over and on the end with only one screw (not the power setting side) take it out using a Philips screwdriver. Next you will need size 3 and 4 hex bits. Use size 4 to undo the 4 hex screws. Hold the non power end and it should slide off. You will see four rollers two on each side of the heater element. Using the size 3 hex bit undo the 4 hex screws at the exposed end and lift up and out the 2 housing bits. Careful as these are made of plastic and break easy. Remove the offending material and then put everything back together.
Simples!
Posted on Jan 14, 2011
Can you delaminate a glossy movie poster?
Norine, if indeed 10% did laminate, In all probability it will wreck the poster try to remove it. I am not sure if it will work, could you run the poster through the laminating machine a second time.
May 06, 2016 | Gbc HeatSeal Ultima 65 Roll Laminator
Laminator will not stop beeping
We just brought home a new Royal Sovereign Laminator. Plugged it in and turned it on. It will not stop the loud, annoying beep and is stuck on reverse. It's going right back to the store for a refund. Will not ask for another Royal. If you can't make it right, don't try to sell it!
Apr 02, 2014 | Royal Sovereign 13" APL-330U Hot & Cold...
Paper **** inside
Probably rolled itself around the rollers. Got to be real careful to not have any exposed inside surface (of the laminating pocket) showing since that coating is heat-activated and sticky.
Unplug it, wait for it to cool, flip it over and remove the screws holding it together.
If the laminating pocket is just physically wrapped around one of the rollers, it will come right out. Re-assemble and go back to work being careful not to put anything through that is the least bit curly.
If the laminating pocket is stuck to one of the rollers, just chuck the thing out and buy another one. The cost of parts and repairs will exceed the cost of a new unit. To remove the adhesive, one would have to disassemble the entire motorized assembly and then heat the "offended" roller to more than 180?F to get the adhesive to soften enough to scrape it off. Then, while it\'s still hot, one has to use a solvent matched to the adhesive to remove all remaining traces (\'cause if there is any left, it will just suck the next laminating sheet right around the roller and you\'re back where you started).
Remember:
- Use only laminating pockets for that brand (different models may have different temperature ratings). If the clerk says their laminating pockets are universal, ask the Clerk to guarantee in writing on his company\'s letterhead that they\'ll be responsible for any damage / repairs / replacement. They won\'t.
- Don\'t put anything that\'s curling through.
- Don\'t put anything through where part of the inside of the laminating pocket is exposed (because as it heats up it will stick to anything and everything it touches)!
Mar 05, 2014 | Xerox Staples XRX LM1910 Laminator
Scotch Thermal Laminator not heating up.
well it sounds like you may have cut a wire or pull one somewhere. i would go ahead and take it apart carefully and check everything. may have unplugged something hopfully! let me know whwat happens!
Jan 31, 2014 | 3M TL902VP Scotch 9" Thermal Laminator...
Lamination Problem
You have to go to printer driver, see the general settings and put more darkness(normally it ranges from 0-20, it should be set at 10. Try puting the darkness at 11,12,13, etc until it laminates properly. Don't forget to put back the setting when printing ymcko, or you will burn ribbon.
If the head that prints color is the same that laminates, then you should be cleaning the head after use.
Jan 17, 2014 | Datacard SP75 Plus Card Printer
How doses the plastic feed through the xrx lm1910 laminator
You will need to make sure that you are using the right type of plastic. also, is the plastic the right size? Also, you need to check if you are trying to feed at all. Are you able to feed the paper?
Jun 08, 2012 | Xerox Staples XRX-LM1910 Laminating...
Guess I'm not too bright. Have a pack of GBC SelfsSeal Laminating Sheets, 9 x 12. Instructions say "Center item face sown on the clear non-adhesive." "Peel away the liner and...
It's not you, it's the instructions. They are just wrong and will not work as directed. However, I have found a way to use these sheets that works for me, but it is still not particulary easy.
Step 1) Lay the 1st sheet on a flat surface, adhesive side up. Pressing down on the small 1/2" strip of backing, peel away the large backing sheet exposing the adhesive. Holding the sheet you want to laminate face down and at an angle to the work surface, carefully align the material by "bumping" it up against the edge of the 1/2 strip. Once aligned, carefully and gradually lay the item onto the adhesive. Like I said, not particularly easy, but if you are careful, it will work.
Step 2) If you want to double laminate, which I usually do, the second laminate sheet seems easier to me. Leave the Step 1 laying flat on the work surface. Take a second lamination sheet and again, hold it down on a flat surface and peel away the large backing sheet, leaving the small 1/2" backing attached. Take this 2nd sheet and holding it over the 1st, face down and angled up from the work surface, align the 1/2" strips of both sheets together and again carefully lay the 2nd sheet over the first single-laminated item. The two 1/2" strips don't stick to one another allowing a bit more flexibility for alignment.
Press all of this together and work out any bubbles or wrinkles. Once that is done, pry the two sheets apart at the very edge to remove the two 1/2 strips.
Unless you are incredibly lucky the edges will never align 100%. I use a paper-cutter to trim off any irregularities after I finish laminating.
Apr 11, 2011 | Gbc Selfseal Letter-size Laminating Sheets...
The sheet im laminating rolled up inside, cannot get it out
Water-based cleaners will not work with this type of adhesive. Rubbing alcohol or a citrus-based cleaner (eg, Goo-Gone) will be required.
Feb 22, 2011 | Xerox Staples XRX LM1910 Laminator
Laminator
ok we think again
Jun 22, 2009 | Office Equipment & Supplies
813 people viewed this question
jasbo
jasbo
