Question about Campbell Hausfeld 5 Peak / 1.7 Running HP, 17 Gallon Husky Air Compressor
Husky air compressor wont build pressure - Campbell Hausfeld 5 Peak / 1.7 Running HP, 17 Gallon Husky Air Compressor
  • 140 Answers
SOURCE: husky comp on 1st start builds up 75 lbs and wont restart
Check the reset button on the motor to see if it tripped. The motor may be overheating. Some motors have an internal breaker and they have to cool off before they restart. Also check the pressure switch. Move the switch back and forth ( on and off ) and listen for a click. If it doesn't click with low to no air pressure then the switch is bad.
Posted on Dec 30, 2008
mrhappyface
  • 205 Answers
SOURCE: Husky 17gal 5hp compressor will not cut off when
bad pressure switch or it is wired incorrectly replace switch and check the wiring or could be out of adjustment you compressor is made for max 125psi should be a screw to adjust on the pressure switch near where the wires are connected back out counter clockwise to lower and see if that turns it off
Posted on Feb 26, 2009
  • 19 Answers
SOURCE: i have a husky compressor, model number y6010-wk.
Problem: My compressor is not producing the air that it once did. It takes twice as long to pump up.
Solution:
1)Turn off your compressor or disconnect the power.
2)Remove the connector tube that sends air to the tank.
3)Remove the head bolts on top of the pump.
4)Remove the head off of your pump.
5)Remove the valve plate off of your pump. It may be a one piece or a 2 piece design.
6)Inspect the valve plate for broken reed valves or broken gaskets above or below the valve plate.
Posted on Mar 03, 2009
  • 7 Answers
SOURCE: I have a Husky model Y6010 air compressor.
First remove the valve using probably about a 1/2" wrench but make sure there is no pressure in the tank before you do so. check the cone and seal by loosening the valve by hand and check for debris. If there is no debris then the problem is either the pressure relief valve or weak pressure regulator but may also be a bad piston seal if it is a direct drive unit.
Posted on May 02, 2009
gaz-dee
  • 62 Answers
SOURCE: My husky 2 gallon air compressor is not building
sounds like the compression rings on the piston neen replacing or the none return valve faulty.
Posted on Oct 28, 2009
While using my compressor (Husky WL65004AJ) the compressor used to go on when the pressure dropped down to about 85-90 psi. Now it doesn't. The only way that I can build up the pressure again is to shut...
Hi and welcome to FixYa, I am Kelly. I tried several places too cross this model number: WL65004AJ without success. The pressure switch has 2 settings one for HIGH cutoff and one for LOW cycle on. 1/2 of your pressure switch is not functioning properly. With the proper model number I could find a source for the pressure switch for you. There are a couple of different types of presure switchs, One is a stand alone switch on the air plumbing with no external controls (under $30.00) and one is an all-in-one switch that has the on off switch and air lines connected to it that runs around $86.00. You need a pressure switch.... it is just a matter of finding out which one fits your model and replacing it.
Thanks for choosing FixYa,
Kelly
Apr 15, 2011 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
Husky 202900 when i turn it on motor runs but it but will not bui
when i turn it on motor runs but it will not build up air pressure
Apr 13, 2010 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
Have a husky 19 gal 1.5hp it kicks on when first start to work and when it builds up air and i use it and when it wants to kick back on it wont i have to wait till it cools down.
Is there an option for you to run this compressor on 220 volts vs 110 volts??? If so, you may want to convert it by following the re-wire instructions on the motor or wire access plate/instuction book. The reason your compressor won't fire up again after building pressure is the head pressure is to great at restart and 110 household current is not enough to give the power needed to turn the piston. You'll need to replace the plug and have someone run a 220 volt circuit once the conversion is completed.
Jan 18, 2010 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
Husky Q26 will not build pressure. Where do I buy parts?
First check the check valve and also if it has an unloader valve make sure it is closing.
The main check valve is often right where the air goes into the tank. The unloader can be integral to the pressure switch or on the compressor.
Sep 26, 2009 | Air Tools & Compressors
While running to build pressure it slows down then speeds up
hi buddy can be the valves sticking try squirting oil in the air filter and get back to me
Sep 19, 2009 | Air Tools & Compressors
Apr 28, 2009 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
Husky 17gal 5hp compressor will not cut off when it builds up pressure. Pressure valve will pop open and then I cut it off buy hand
Feb 20, 2009 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
Husky comp on 1st start builds up 75 lbs and wont restart
Dec 30, 2008 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
Campbell Hausfeld 5 Peak / 1.7 Running HP, 17 Gallon Husky Air Compressor Logo
22 people viewed this question
Top Campbell Hausfeld Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
