Question about Texas Instruments BA-II Plus Calculator
Yield to Maturity interest rate is 12 times to big
TI BA II Plus
PV = 1081.95
FV = 1000
n = 3
PMT = 50
Cpt I/Y, answer should be 2.15%, but I get 25.80
which is 12 times larger than should be.
Thomas
  • Anonymous Mar 04, 2009
    i have the same problem with this calculator
  • berty7 Mar 04, 2009
    just click on this link and your problem is solved! you're welcome!
My TI BA II Plus is returning incorrect answers for TVM problems... Is this common and can it be fixed?
Let's see, 10% interest per year on $100 for one month. That's 10/12 of a percent interest on $100 is $0.83, added to $100 is $100.83 (with a bunch more 3s at the end). Clearly this is the correct answer.
What answer are you expecting? The future value at the end of one year instead of one month?
Nov 30, 2013 | Texas Instruments BA-II Plus Calculator
My BA II plus professional showing wrong answer while computing "N" during TVM calculation
Make sure you have P/Y set to 1 and BGN/END set to END. With those settings, pressing 9 I/Y 9 2 0 FV 1 0 0 +/- PMT CPT N should produce 7.00 .
Aug 25, 2012 | Texas Instruments BA-II Plus Pro...
Calculating TVM variables I/Y & N. eg. N = 10, PV = 10,000, FV = 20,000, PMT = 0 but when I CPT I/Y I get Error 5
Error 5 indicates that no solution exists. In this particular case, you're asking for the interest rate on a savings account that pays you 10,000 now and an additional 20,000 10 years later. (Or a loan where you pay 10,000 now and an additional 20,000 10 years later.)
Either PV or FV should be negative. For example, if you deposit 10,000 in a savings account and withdraw 20,000 10 years later, use -10,000 for FV.
Aug 08, 2011 | Texas Instruments BA-II Plus Calculator
Im am baffled. my ba-II plus is not calculating TVM correctly. ive tried resetting, making sure end period was selected (i.e. ordinary annuity) but no luck. as an example i enter... n=1, i=10, pv=-1,...
It's giving you the correct answer for the problem you've input. When you specified 1 for n, you told it one month. If you specify more digits, you'll see that the answer is 1.00833333.
By default, the calculator works with annual interest rates but counts periods in months.
Jun 11, 2010 | Texas Instruments BA-II Plus Calculator
Computing N in a TVM calculation (receive Error 5 message)
Hey,
Just found out the answer!
Apparently you can't have both FV and PV positive. Try the calculation with one of them being negative.
Jan 12, 2009 | Texas Instruments BA-II Plus Calculator
PV and FV problem, result not like in manual
You have the payments-per-year set to 12. For this pair of problems, it needs to be set to 1.
Press 2nd [P/Y] 1 ENTER.
Jun 24, 2008 | Texas Instruments BA-II Plus Calculator
Simple loan payment
Are you putting 30x12=360 for N? Since you have monthly payments, you have to compute it a little different. Also, you have to find the effective monthly interest rate. 1.0575^(1/12) = .4669839%.
Another way is to enter 30 for N and 5.57 for I/Y, and change P/Y to 12.
Hope this helps!
Apr 08, 2008 | Texas Instruments BA-II Plus Calculator
Finding N value on Ba11 PLUS
You need to have your PV and your PMT be a different sign. Try making your payments negative.
Mar 17, 2008 | Texas Instruments BA-II Plus Calculator
I do not have the directions and need to figure out how to calculate mortgages.
Here is the link to a guide;
http://www.buec.udel.edu/bowersh/finc311_F04/Documents_f04/Quick%20Guide.pdf
Set PV=-$100,000
[2nd] P/Y= 12.00
N= 12 x 30 = 360, (i assume it's 30 Y amortization)
I/Y = 5.75%
FV = 0
[CPT] PMT
Hope this helps
Jan 16, 2008 | Texas Instruments BA-II Plus Calculator
Texas Instruments BA-II Plus Calculator Logo
697 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
