One depression of the trigger causes two nails to fire in succession.
This gun should be bump-fired only. Do not place the gun on the work and press trigger. Make sure that the safety spring is in place and has good tension. The spring helps to push the foot off the trigger so that it fires once. You could also adjust the screw that pushes on the firing valve. Turn in or out several turns till head of nail is correct when bump firing then lock the nut. The safety foot fits rather loose on the gun and should still work ok but can get so loose that it falls off the nose. Good luck
SOURCE: hitachi nail gun nr90ad leaks from trigger when
The nail gun should have came with some lubricating oil. A couple of drops should be installed where you connect the air hose to the nail gun every time you use your nail gun (or per the manufactures specifications) This helps lubricate all the internal o-rings. You may have to put a few drops in and use the gun a bit to get it to seal up. If it still doesn't after that, it may need the o-rings replaced.
SOURCE: Hitachi NV45AB coil nail gun is leaking air from
the top!! o-ring inside of thr top plate is bad you need to remove the plate /dissasemble and replace the o-ring
I appears that the pushing lever must be perfectly vertical for the gun to fire correctly. If the gun is tilted slightly, it double fires a nail. Has anyone ever had a problem with a worn pushing lever of an NV45AB?
