Question about Cabela's Marshall's National Wild Turkey Federation Ceiling Fan
MOTOR NOISE IN JOHN MARSHALL NTWF CEILING FAN
LOUD WHINING NOISE IN MOTOR WHEN FAN IS RUNNING. CAN MOTOR BE REPLACED?
How to get rid of the whining noise in a ceiling fan
If you're using a dimmer control for the fan, get rid of it! Always use a fan control with 3-4 speeds.
Apr 24, 2016 | Hunter Dryers
Whining sound
check the oil level
Jun 21, 2014 | John Deere Garden
There is a loud noise while going through final stages of wash. Sounds like pump motor whineing.
Hello
When an appliance such as a dishwasher starts making a new noise, you need to isolate the cause of the noise so that you know whether or not it is damaging the machine. Several things can cause a noisy dishwasher.
Motor
Dishwashers are driven by an internal motor that gets quite noisy when defective. The problem occurs when a seal breaks down and allows water to access the bearings in the motor, removing the grease needed for proper lubrication and creating a loud motor noise when the dishwasher runs. The seal or bearings need to be replaced in this situation quickly or more extensive damage to the motor may occur.
Inlet Valve
If the inlet valve on your dishwasher is broken or breaking, you will hear a distinctive thumping or clattering noise whenever a load is run. A thumping noise doesn't always indicate this problem, however, depending on when you hear it. If you hear a noise like this when the water is filling up the dishwasher at the start of the cycle, the noise likely points to an inlet valve problem.
Squealing
A high-pitched squealing noise is an indication that something is wrong with the fan. Fan bearings that are worn out indicate that the fan apparatus needs to be replaced. If the noise you're hearing is in fact coming from the fan, it will only occur when the dishwasher is drying the dishes. Dishwashers use a fan to generate and distribute heat to dry the dishes quickly.
Minor Concerns
Sometimes even a minor concern can cause a great deal of noise. The thing to watch for is whether or not the noise repeats itself on multiple loads. A loud noise on a single load that doesn't repeat could be caused by things like a loose utensil or small implement rattling around loose in the dishwasher. Also inspect the bottom of your dishwasher. Hardened bits of old food can become rock hard under the heat in the dishwasher and cause noise when the unit runs.
Sep 11, 2011 | Fisher and Paykel 23 in. DD603H SS...
When turn on blows cold air but makes loud whining noise like rubbing on something. almost a whine sound
sounds like your bearings are out on your fan motor. Some of the older fan motors have places where you can oil the bearings but most newer ones do not. Unless you have a place to oil the bearings and they are not already too far gone you best bet will be to replace the motor. Once the bearings start howling in the way you described it is time to start looking for a replacement. It is also possible (although unlikely) that the noise you hear is (a) the fan blade hitting part of the frame. (b) the bearings in the compressor.
Jun 05, 2011 | Heating & Cooling
My side by side has a LOUD whining noise coming from behind the freezer area that lasts for up to an hour.
This noise is most likely comming from the fan motor. The main board often causes the fan to be noisy but it could be a bad fan motor as well. http://www.appliance-repair-it.com/refrigerator-fan-motor.html
Sep 10, 2010 | GE Refrigerators
When i start up my 98 cadillac deville there is a loud whining noise from the ac compressor. Will my car run without the ac compressor or will i need to spend the money to replace it?
The car should run okay without the compressor, you just won't have A/C. The cooling fans should still operate with the Engine Coolant Temperature sensor. It is also possible that you just need to charge the A/C system. A loud whining noise is indicative of low charge to the compressor.
Jul 03, 2009 | 1998 Cadillac Seville
When running it makes a loud noise
Your bearing are failing. Replacing them and the seal at a local electric motor repair shop will likely cost around $50.
Jun 02, 2009 | Polaris Pb460 Polaris Booster Pump...
Model # 795.75286.402 Motor running load
The evap fan motor most likely is running loud due to a ice build up around the fan and the fan blade is hitting it and making a loud , irriting noise. Shut the ref off. If you are mechanical, remove the draw and the back cover, clear out the ice. Also, the ice may have been caused because the sensors-- thermistors--- are not located properly. look at the ceiling of the freezer and you see a small holder piece. the part is located there. tahke the cover off and take the thermistor that may be buried in the ceiling and pull it down and locate it in the holder, reinstall the holder. Not also, there is another one in the ref section to do the same thing
Sep 04, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Loud Whining/Humming noise while washing
It's noisy If your dishwasher seems noisy, check these:
Water-inlet valve
Motor
Heater fan
Pump
Water-inlet valve An aging water-inlet valve can sometimes fail slowly, rather than all at once. It can shudder on and off rapidly, causing the incoming water lines to shake, rumble, and rattle--sometimes violently. If yours is doing this, replace the inlet valve.
Motor If it's the motor that's noisy, either of these may be the "culprit:"
  • As motor bearings wear out, they can become quite loud when the motor runs. They wear out quickly if they frequently get wet, because the water washes away the motor bearing grease. Bearings can get wet if the spin seal is defective. Then there will also be water leaking onto the floor beneath the dishwasher. Replace the seal if it leaks (read about the main tub seal in the "It leaks" section, later).
  • If, from beneath the dishwasher, you can see a round, plastic disc that's mounted to the top of the motor (a "slinger"), it may have broken free of the motor shaft. If so, it could be rattling around the shaft while the motor is running. If that's the problem, you need to replace the motor.
Heater fan If the heater fan bearings are rusted or worn, they may squeal, or scrape loudly during the drying cycle. If this is the problem, replace the fan motor. Alternatively, the fan blade may be loose. If so, you need to replace it.
Pump Small fruit pits, toothpicks, and fragments of glass sometimes get stuck in the pump. When this happens, open the pump and remove the debris. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher.
To get to the pump, you usually need to remove the lower rack, the spray arms, and the spray arm support from the inside of your dishwasher. A dishwasher pump isn't obvious. Look for an impeller--a round, plastic fan blade-type device that spins around and pushes the water toward the drain. When you can see the drain impeller, you should be able to see the clogging debris.
Feb 13, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Dryers Logo
Top Cabela's Dryers Experts
Are you a Cabela's Dryer Expert? Answer questions, earn points and help others
