Question about Superpad 10.2" epad SUPERPAD3/Flytouch Froyo Google Android 2.2 tablet pc
SUPERPAD3/Flytouch Superpad schematic
Touchscreen
How do i reboot a fly touch v10 tablet
Tony, you mean reset, Right ?
Check the attached links, to see how to reset.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to do Manual Factory Data Reset on Superpad Tablets Android 4 0
How to reset the SuperPad Flytouch 2 Google Android OS 10 inch
How to Do Manual Factory Data Reset on Flytouch Tablet The Classroom...
Superpad VI How to reset to factory defaults FlyTouch 3 Superpad 2
Mar 08, 2016 | Tablets & eReaders
How i recover my infotmic tab
Depending on which version you have please see the following notes:
How To Factory Reset/Recover the systerm On Your Tablet PC(Flytouch 2/SuperPAD 2/Infotmic tablet 2)
1. Press "Power" and "Home" button at the same time, hands off until you see the words on the screen.
2. Select:"wipe data/factory reset" with the "volume" button, and then press "menu" button.
3. Select:"Yes -- delete all user data", and press "menu" button.
4. Wait until you see" Enter erase_cache Data wipe complete" .
5. Press "reset", calibrate it and set the language.
How To Factory Reset/Recover the system On Your Tablet PC(Flytouch 3/Flytouch 4/SuperPAD 3/Infotmic 3)
1. first press the "MENU" key, keep pressing the "MENU" key while you press the "POWER" key, remove your hands when you see "recovery" from the screen.
2. Wait a few seconds until it is done. And then the system will start..
Precautions
A power failure during the firmware writing operation may disable the tablet PC.
* Use a fully charged Battery or dedicated AC Adapter for the firmware update.
* Do not shut off the power during the firmware writing operation
Feb 04, 2015 | Tablets & eReaders
Frozen screen
hold the re-set button down until the tablet shuts itself down if you have already done this and it does not work and you have had your tablet for less than a year usually the company will fix it for free or send you a new one free of charge because it is a problem with tablet not something you did.
Nov 11, 2013 | Flytouch 8 Superpad VIII
Up not only is the android screen
please explain your problem its not clear what the issue is
Oct 17, 2013 | Flytouch 8 Superpad VIII
Flytouch superpad 9 sticks on android logo,i need instruction on how to reset
Doing a hard reset will delete all your saved files and application. Press and hold the POWER, MENU AND BACK buttons while turning the power on After doing that action it will automatically hard reset your device, no confirmation, just wait for the proess to be completed and thats it
Sep 17, 2013 | shop-fun 10 Flytouch 9 GPS Tablet PC...
Super pad vi tablet problem connecting to wifi
This may be a router problem or a Tablet problem. Your router may be a 5 GHz model and your tablet is most probably 2.4 GHz. or it could be that you have entered the incorrect password into your tablet.
Nov 17, 2012 | Superpad 10" flytouch 6 Android 2.3...
Android 2.2 superpad 3
user manual can be found here. (Green download button below the text "click here to start download") https://hostr.co/download/B2seFgu/superpad.doc
superpad is the same thing as a flytouch, I have one of each.
Feb 05, 2012 | Android Cell Phones
Superpad 10.2" epad SUPERPAD3/Flytouch Froyo Google Android 2.2 tablet pc Logo
Top Superpad Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Superpad Audio Player and Recorder Expert? Answer questions, earn points and help others
