Question about Nikon COOLPIX Cameras
Hot do i get to mode 2 - COOLPIX Nikon Cameras
    Genius:
  • 1,019 Answers
You really need to stop posting the same question when you fail to give the make and model of the camera !!!!!!!!!!!!!
Posted on Jan 25, 2013
I have a 2008 Chevrolet Silverado and the warning lights keep coming on telling me AC not working/engine hot ,, ??
ENGINE HOT TURN A/C OFF
Cooling System Description and Operation
ENGINE COOLANT HOT
The instrument panel cluster (IPC) displays ENGINE COOLANT HOT message when the IPC receives a class 2 message from the powertrain control module (PCM) requesting illumination of this driver warning.
ENGINE OVERHEATED
The IPC displays ENGINE OVERHEATED message when the IPC receives a class 2 message from the PCM requesting illumination of this driver warning.
DTC P1258: Engine Coolant Over temperature - Protection Mode Active
Have it check
Mar 03, 2017 | Chevrolet Cars & Trucks
My spa is at 89 and its set for 104 and the pump will not cut on what is the problem
You may be in economy mode. Economy only heats the water during a programmed filter cycle. You want it to be in standard mode which turns on the hot tub once the water is 2 degrees below the desired temperature. There should be a mode or program button on your topside. One some systems you'll have to hit prog/mode button then the temp up button to change the mode. There is also a sleep mode. Never used it not sure what it's for.
Apr 12, 2015 | Dream Maker Spas Dream Maker Ez Spa Hot...
I have a 1999 jeep grand Cherokee limited edition my heater only throws out cold air why is that?
this is easy. (are you moving or parked) ill assume stopped.
first is the blower working, (seems so)
ill guess that no heat in all vent modes, and re-circ, on.
next is the engine fully hot, hot means at 180F or more holding
(we measure it with a pyro gun)
next, are both heater core hoses hot/ at the fire wall? and equal at 180f?
yes, good. then the damper is stuck closed i the heater box.
no , then there is heater core blockage. (skipping every 2 year flushes are you, sure...)
it only takes 2 things
hot water ,p[assing through the heater core
and air passing through its fins to get hot cab air.
just 2.
Nov 14, 2014 | 1999 Jeep Grand Cherokee
Hot tub stuck in 'SL' mode
Need to know what buttons your topside control has... depending on the model, some have a mode button which you press and release and then immediately press the temp up or down, to select SL for sleep (no heat), ST for standard (heat as needed) or EC for Economy (only heat during filtration). If the mode button is not present, and you have a single temp button and light button, try pressing and releasing temp and then immediately pressing light button, repeat until choice appears, then wait, it will hold last displayed mode.
Jul 09, 2010 | Jacuzzi Balboa R574 System for 1 2 Speed...
How to Get Hot tub off sleep mode
press temp button and then the light button in sequence.
Nov 14, 2009 | Jacuzzi Balboa R574 System for 1 2 Speed...
Pump is running ever 5 minutes. The heat in the
Sounds as if the 'mode' for the tub is set to sense the temperature of the water. see if there is a setting on the control box to a 'timed' setting for filtering and heating instead of controlled by the temperature setting. the problem is the the control box is away from the water and when it calls for heat it is because the water is cooler there than in the hot tub. so when it calls for heat and the water starts to circulate it gets the hot water from the body of the hot tub and then shut down because it senses the 'hot water'. make sense?
Feb 23, 2009 | Blue Wave Aruba 15' Round 54" Resin Pool...
Christie DS+60 projector turns off spontaneously
Here is a list of error codes for your unit:
12 Software bug. Contact dealer/factory.
13 Flash memory corrupted. Download new software.
14 Engineering only programming is complete. Call Christie, replace TIPM.
15 Attempting to download code without being in boot mode
16 Invalid interrupt. Power off/on. If it persists, contact dealer/factory.
17 Forced boot mode. Keys held down too long.
18 Attempting to program boot mode without jumper
LAMP FAILURES
21 Lamp compartment too hot
25 Lamp 1 not installed
26 Lamp 1 Interlock: door open, lamp not installed
27 Unable to turn lamp 1 ON
28 Lamp 1 shut off unexpectedly
29 Lamp 1 driver overheated
2A Lamp 1 driver operation error (e.g. too hot can’t start)
2C Lamp 1 driver UART communications failure
30 Lamp 2 not installed
31 Lamp 2 door open
32 Unable to turn lamp 2 ON (unknown reason)
33 Lamp 2 shut off unexpectedly
34 Lamp 2 driver overheated
35 Lamp 2 driver reports operation error (e.g. too hot can’t start)
36 Lamp 2 driver UART communications failure
37 Lamp Watchdog Tripped – Unless lamps turn on again after 3 minutes, assume software hung.
Jan 16, 2009 | Christie DS+60 Multimedia Projector
94 4.6 deville coolant hot,eng hot ,limp mode
pull codes from on board diagnostics turn key on not running press and hold hot button on temp and off at same time till dash lights up write down codes respond with all computer codes i will help you determine prodlem and try to fix
Aug 21, 2008 | 1995 Cadillac DeVille
Cameras Logo
12 people viewed this question
Top Nikon Cameras Experts
Greg Cann
Greg Cann
Are you a Nikon Camera Expert? Answer questions, earn points and help others
