Question about Singer 7436 - INGENUITY
Upper thread keeps breaking - Singer 7436 - INGENUITY
  • Singer Master
  • 7,365 Answers
The needle thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
Posted on Jan 23, 2013
4 Suggested Answers
SOURCE: thread keeps breaking
Upper thread breaks
needle may be in backwards
Raise the needle bar to the highest point then loosen the clamp screw to remove the old needle, place the new needle in the clamp with the flat side to the back of the machine
Push the needle all the way up to the stop or as far as it will go, then tighten the needle clamp screw
upper tension may be to tight
the needle may be bent or damaged
thread may be hanging up in bobbin case--check area for loose threads or lint
Posted on Sep 17, 2012
  • 240 Answers
SOURCE: Machine is jamming
You need to remove the bobbin from the "race" by following the instructions in the manual. Give it a good clean and remove any bits of fluff and thread. Remove the upper thread also andmake sure that the tension wheel is clear of any broken threads and is on the correct setting. It may have been threaded wrong. The hand wheel not turning sounds like the bobbin area is jammed also.
Posted on Jun 11, 2009
WonderTech
  • 268 Answers
SOURCE: skipping stitches and upper thread breaking on JCPenney 6600
Here are a few things to try.
* Raise your feed dogs if your machine has this feature.
* When you start to sew a seam, hold the upper and bobbin thread tails. Hold them back and out of the way as you sew your first couple of stitches. This will keep them from getting caught in your machine.
* Your fabric may require a different needle. Generally, heavier fabrics require larger needles and thinner fabrics, smaller needles. You may also need a larger needle if you're sewing through many layers of fabric. And make sure to use a ballpoint needle for knit fabrics and a sharp needle for woven (or a universal needle for either). And make sure your needle is appropriate for the type of thread you're using.
* Adjust the pressure of your pressure foot, it may be too light for your fabric.
* If your upper thread and bobbin threads are different types, try using the same thread for both. And use a good quality, brand name thread.
* Change your needle plate. Try switching to a needle plate with a smaller hole (a straight stitch needle plate).
Important Note: If you change your needle plate, check to make sure your needle aligns perfectly with this smaller hole before starting to sew. A misaligned needle could hit the plate and break, which could be dangerous. And make sure to change your needle plate back for zigzag and other wide stitches.
I hope this helps.
Posted on Mar 23, 2010
I have a Janome 1600P and the top thread keeos breaking
There are several common reasons for upper thread breakage.
Check that the needle/thread/fabric are compatible.
All About Needles
Remove the upper thread from the machine, install a brand new needle, ALWAYS RAISE the presser foot, and rethread from the beginning. Verify the thread path is correct. Set the upper tension to the midway point.
NMSU Checklist of Common Machine Troubles
Sewing Machine Problem 1 Thread Breakage
Sewing Machine Thread Keeps Breaking
Why Does My Thread Keep Breaking While Sew
Oct 29, 2016 | Janome Sewing Machines
Kenmore mini ultra The top thread breaks off from needle after a few stitches. The bobbin seems to Be catching the top thread. Thank you. ??
If the top thread sews a few inches and then breaks, something is catching the top thread and holding it until it breaks. Usually, this will happen when using the old style thread cones with the slit in the edge to keep the thread from raveling off the spool. To prevent the thread from hanging up, turn the thread spool over so the slit is at the top instead of the bottom. Sometimes top thread breaks will happen if the thread becomes looped around the thread spool pin.
Remove the thread, ALWAYS RAISE the presser foot and then rethread the upper thread. Verify that the thread path is correct and that the thread has not looped around a guide.
If the thread is fraying at the needle eye, the needle/thread are not compatible. Also, the tension may be too high.
Check that the upper tension disk is clean--no gunk buildup or thread pieces stuck.
If the thread is actually breaking when it penetrates the needle plate hole, there may be a burr or nick somewhere below that is catching the upper thread. You can wrap your finger with a piece of fine fabric, like an old pair of hosier, fine knit fabric, etc. and running your finger around in the bobbin area, under the needle plate. If you get snags, then you have a burr or nick. If it is small, you can sometimes smooth it with a fine emery board. If it is a large burr, you may need to purchase a replacement part.
Why Does My Top Thread Keep Breaking Sewing Machine
Sep 05, 2016 | Kenmore Sewing Machines
Why the thread cracked with when i sticked with the machine
Thread breakage could occur for several reasons.
First, try a brand new needle.
Second, use only good quality thread--NOT old thread or bargain bin varieties.
Third, when threading the upper thread, be sure to ALWAYS RAISE the presser foot throughout the threading process.
Verify that the thread path is correct (consult the owner's manual). Incorrect threading will usually break the thread.
Check that the upper thread tension is set at the midway point between the high & low numbers.
Aug 27, 2016 | Brother ES2000 Computerized Sewing Machine
Juki TL2200
Check thread routing
Jul 20, 2016 | Juki Sewing Machines
Top thread keeps breaking
Upper thread breaking is usually a sign of incorrect threading or tension too tight, although there are other possible problems:
Industrial Garment Printers Sewing Machines
When threading the upper thread, be sure to ALWAYS RAISE the presser foot so the thread will seat properly in the tension disks. Avoid old thread or bargain bin thread. If the thread is fraying and breaking at or near the needle eye, then try a different type of needle with a larger thread groove that will protect the thread from fraying on rough fabric. Also, check that the thread is not hanging up on something, ie the slit on the side of the spool where the thread tail is stored.
Jul 02, 2016 | Brother XL-2600I
My thread keeps breaking, Ive checked and changed my needle, re-threaded bobbin and upper but every time I try to sew the upper thread breaks.
Have you tried loosening the upper tension? Remove the upper thread, RAISE the presser foot and rethread from the beginning (make sure it follows the correct thread pathway). Sometimes the upper thread jumps out of a thread guide or wraps around something. Or try a different brand of thread? Avoid old or bargain bin threads--use good quality thread. Could also be the incorrect needle for the thread/fabric, ie thread too large for the needle eye.
Apr 03, 2016 | Sewing Machines
Upper thread keeps braking
Usually thread breakage is a result of incorrect threading or the thread tension set too tight.
Install a brand new needle.
Remove the upper thread. RAISE the presser foot and rethread from the beginning (verify the threading sequence is correct).
Check that the tension is set at the midway point between the high and low numbers.
Retest. If still breaking, there are other less common problems (thread/needle incompatibility, burrs or knicks catching the thread, etc) that may be the cause. Check the following web sites:
Why is my thread breaking
Feb 11, 2016 | Brother Sewing Machines
Instructions for threading
search on Google make, model,manual or threading instructions
Dec 07, 2015 | Sewing Machines
the tension is too tight give it a little slack on the top.good luck.
Feb 28, 2010 | Brother LS-2125 Mechanical Sewing Machine
Singer 7436 - INGENUITY Logo
70 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
