How to change default memory transmission settings in Lanier LF312 Fax Machine
  • 7 Answers
SOURCE: How do you program the machine to only print out falied fax confirmations?
Yes. SmartDeviceMonitor for Admin and Web Image Monitor let you remotely view a device's transmission history as well as its saved destination data. You can install SmartDeviceMonitor for Admin from the CD-ROM that was included with your device, or download it from the device's website. However, SmartDeviceMonitor for Admin can only be used on a computer which has the TCP/IP protocol correctly installed. Once you have confirmed that SmartDeviceMonitor is installed, to confirm that your fax was transmitted properly, follow these steps: 1.Open SmartDeviceMonitor for Admin by clicking [Start] on the taskbar, pointing to [All Programs] and then [SmartDeviceMonitor for Admin], and then clicking [SmartDeviceMonitor for Admin]. 2.Click the device whose information you wish to display. 3.On the [Tools] menu, click [Load Fax Journal]. 4.When Web Image Monitor opens in your web browser, click [Job], click [Fax History], and then click [Transmission].
Posted on Jul 11, 2007
  • 59 Answers
SOURCE: Canon Fax L220
From previous experience it is a compatability problem stemming from propritary transmission modes. Not sure what model Lanier fax is but they can disable some optional transmission modes first. Otherwise if this person is important you can tell that person to force transmit to you at 9600bps.
Posted on Aug 10, 2007
SOURCE: Need to reset savin 3740 fax to factory defaults
How can I enter a new customer's id information on the top of the page, just the name of the company and fax number of the sender. Savin 3740.
Posted on Nov 06, 2008
firecontrol7
  • 6161 Answers
SOURCE: Instructions for setting up numbers in speed dial
call 1-800-432-9787
http://www.lanier.com/downloads/Default.aspx?hbn=manuals
did not see it on this web site so call the above number. It mite be legacy equipment
Posted on Aug 09, 2009
  • 239 Answers
SOURCE: don't want a transmission report after each sent fax
On the machine there is a menu button.
the menu can be printed out so you can see all the areas to select.
If you scroll to through the menu, you will find a set up or incoming fax menu.
You need to set confirmation to off.
This will take some time to find the right menu, so be patient with the machine.
Good luck.
Posted on Oct 17, 2009
Reset nvram
http://www.support.xerox.com/support/phaser-3300mfp/support/enus.html
Solution : Clear Memory and Restore Default Settings on the Machine NOTE:Clearing memory on the machine will remove information from the machine and restore factory default settings. Make sure that all fax jobs have been completed before clearing the memory, or jobs will be lost.
To clear the machine memory and restore factory default settings:
  1. Press the [Menu] button (located below the Display Screen on the Control Panel) until "System Setup" is displayed on the bottom line of the Display Screen.
  2. Press the [Enter] button.
  3. Press the left or right [Scroll] (arrow) button until "Clear Setting" is displayed.
  4. Press the [Enter] button.
  5. Press the left or right [Scroll] button until the option to be cleared is displayed. (Refer to the table below for additional information.)
  6. Press the [Enter] button. "Yes" will be displayed.
  7. Press the [Enter] button again to confirm.
  8. Repeat steps 3 through 7 to clear additional items.
  9. Press the [Stop / Clear] button to return to Standby mode.
Clear Memory Descriptions Options Description All Settings Clears all of the data stored in memory and resets all of the machine settings to the factory default settings. Fax Setup Restores all of the Fax options to the factory default settings. Copy Setup Restores all of the Copy options to the factory default settings. Scan Setup Restores all of the Scan options to the factory default settings. System Setup Restores all of the System options to the factory default settings. Network Restores all of the Network options to the factory default settings. Address Book Clears all of the fax number and e-mail address entries stored in memory. Sent Report Clears all records of sent faxes and e-mails. Fax Rcv Report Clears all records of received faxes. New Scan Report Clears the information about network scan sessions in memory.
May 21, 2014 | Xerox 3300MFP/X new 3300mfpx [a51t732]...
How to change memory transmission settings for lanier lf312
Sharp fax UX-84/ FO-90 probleme: sortie des papier ne fonctionne pas
Jan 23, 2013 | Office Equipment & Supplies
Fax out Memory Status 1. Fax out fail ( do i have to Re-fax again by myself Or the machine will Fax out by Memory and 2. HOw If I need to use the Same Memory Number to RE-FAX again ( which Key...
The machine will automatically re-fax documents to a pre set ammount, then give you the fail message. In that case you will have to re-fax yourself. It is possible to change the default number of times that the machine will try for you, but you will have to look in the manual for that.
Oct 06, 2010 | Office Equipment & Supplies
I want to program email addresses on a Lanier LD050 copier/fax/scanner machine.
On the keyboard......User tools> administrator tools>address book.
you make your changes\ additions here.
You also must have your network settings completed in user tools. DNS, SMTP SERVER, GATEWAY ect....
Jan 25, 2010 | Lanier UNKNOWN
Unable to enter faxes while the machine is either sending or rece
turn off
Real Time Transmission
When you are sending a fax, the machine will scan originals into memory before
sending. Then, as soon as the phone line is free, the machine will start dialing and
sending the fax. If memory becomes full, the machine will send the document in real
time (even if REAL TIME TX is set to OFF).
Sometimes you may want to send an important document immediately, without
waiting for memory transmission. You can set REAL TIME TX to ON.
1 Place the original face down in the ADF.
2 Press Menu, 2, 2, 6.
3 To change the default setting, and then
press or to select ON (or OFF) and
then press Set. Go to Step 5—OR—For
the next fax transmission only, press or to select NEXT FAX ONLY,
and then press Set.
4 For the next fax only, press or to select ON (or OFF), and then press Set.
5 Press 1 if you want to select additional settings. The LCD returns to the SETUP SEND
menu—OR—Press 2 if you are finished choosing settings, and then go to Step 6.
6 Enter fax number and then press Fax Start.
May 23, 2009 | Brother IntelliFAX 4750 Plain Paper Laser...
The screen keeps on showing " memory full".
I can advise you on the 'memory full' problem, mate.
If you get a MEMORY FULL message while scanning the first page of a fax, press Stop to cancel the scan. If you get a MEMORY FULL message while scanning in a subsequent page, you’ll have the option to press Start to transmit the pages scanned
so far, or to press Stop to cancel the operation. In this case, send the fax by the Manual Transmission.
Depending on your typical faxes, MEMORY FULL errors can occur frequently. If this happens, change the Memory Transmission setting back to OFF.
To do this:
Press Function/Set, 3, 9.
This should take you to MEMORY TX
and MEMORY TX: ON?
Then press either the left or the right arrow (< or >) to switch on or off, and press Function/Set.
For the next fax transmission only, press < or > to select
NEXT FAX ONLY and press Function/Set.
This will mean you don't add any more to the memory and may be able to send faxes. There is a possibility that you will only be able to fax using manual transmission, but at least you should be able to use the machine to fax at all!
I apologise if the jargon is confusing, just try to go through the process one step at a time and you should be fine.
Hope this helps :)
Chris (ziraffa)
Dec 21, 2008 | Brother IntelliFAX 560 Plain Paper Fax
Job waiting message appears on screen.
You can selectively clear information stored in your machine’s memory.
1. Press Setup on the control panel. The display shows the first menu;
FAX NUMBER/NAME.
2. Press ➛ or ❿ until ‘MEMORY CLEAR’ appears, then press
Start/Enter. The display shows the items you can choose to clear.
• FAX NUMBER/NAME : your fax number and name are cleared from
the machine’s memory.
• DIAL/SCHEDULE : clears the one-touch, speed dial, or group dial
numbers stored in the memory. In addition, all
the Schedule Job operations you have reserved
are also cancelled.
• JOURNAL : clears all records of transmissions & receptions.
• DEFAULT SETUP : restores all the option settings to factory default.
Only clear de Journal, don't clear the other.
Try this if it resolve the problem.
Nov 20, 2007 | Samsung SF-5100 Plain Paper Laser Fax
Canon Fax L220
May 11, 2007 | Canon FAXPHONE B640 Plain Paper Bubblejet
101 people viewed this question
jasbo
jasbo
