Question about Samsung LN-S4051D 40 in. LCD Television
Samsung LN-S4051D goes on and off by itself. Repeatedly.
We have TV hooked up to cable box, which seems to be okay. I unhooked it and TV had the same symptom w/o cable box. I have tried various way of powering up. No difference. Also plugged directly into the wall skipping the power strip. No difference.  We were shutting the power strip off to save power as the TV is only on a few hours in the evening.  The television set goes on and off repeatedly and without any control.
  • 335 Answers
1 Bad inverter circuit (used for back lighting the LCD panel)
2 Bad secondary power supply too the inverter circuits
Especially if its a switch mode power supply connected to twin phase inverters. This problem almost always happens under that particular engineering scheme. Switch mode power supply's are horrible at sustaining high voltage CCFL back lights.
Your tv needs professional servicing!
e-mail me if you need more info or advice....
Posted on Jan 29, 2009
Samsung LN-S4051D slow to turn on.
You are likely to have a module bad....part number BN94-00864A and if you take it out (unpluggs) you should inspect it for capacitors that may be domed or pooched up at the top. If so they should be replaced first before getting the module as the capacitors are about $1.00 each. Do a search for Samsung parts online if you need the module and call them toll free
Mar 16, 2008 | Samsung LN-S4051D 40 in. LCD Television
I need a instruction manual for samsung lcd tv model # LN-S4051D
You can download or view the manual at may need internet explorer 8.0 for downloading.
Apr 07, 2010 | Televison & Video
Can I replace a blown speaker in the Samsung LN-s4051d? If so, how?
You have to take the TV rear panel out and just install a new one, you can get it here.
Are you sure the speakers are bad, not the amplfiers?
Nov 12, 2009 | Samsung LN-S4051D 40 in. LCD Television
Samsung 32 lcd tv backlight off after 4 sec. audio ok
If your TV is staying on and you hear audio after the picture goes dark, then you have a problem with a CCFL or the inverter circuitry that drives them.
Most likely an inverter problem.
Like a bad xformer (usually fogged up plastic wrapper)
Or a bad cap (bulged, swollen, cracked)
Or maybe a shorted IC or transistor (test for short circuit between the different pins of the device)
Oct 08, 2009 | Samsung LN-S4051D 40 in. LCD Television
I have a Samsung LN-S4051D. Power on delay?
Is probably that the power supply is having issues with a component, it might be something very simple, since tv still turns ON, is probably that is just one capacitor or another component. If you can have someone to electronic sabby to check the oiwer supply they might be able to determine where is the issue, if not just take it to a shop, it shloudnt be expensive
Jun 25, 2009 | Samsung LN-S4051D 40 in. LCD Television
On HDM1 "No Signal" cannot get anything!
check the cable once more then nothing different?
replace the Main Board
Jan 07, 2009 | Samsung LN-S4051D 40 in. LCD Television
Samsung 40" 1080P power flux
Try to replace the Power Supply board first.
Feb 01, 2008 | Samsung LN-S4051D 40 in. LCD Television
Samsung LN-S4051D 40 in. LCD Television Logo
102 people viewed this question
Jerry Greenberg
Jerry Greenberg
