Question about Philips Magnavox TS3260C 32" TV
How to fix fan on magnavox tv
Fuse blows fan is off
    Top Expert:
  • Philips Master
  • 74,136 Answers
If fuse must blow up, surely there must be a short circuit with inside circuit board. Check it, and rectify it first, before confirming the fan is bad.
Posted on Jan 24, 2013
Blowing fuse on tv
hi there's dead short in the power supply somewhere could be a number of components usually diodes or transistors cause this fault
hope it helps
regards
shaun
Jan 04, 2014 | Magnavox 32MF301B/F7 32 in. LCD TV
Magnavox mwc20t6 doesn't turn on
Hi
If you have a friend that is keen on electronics, your tv set may be open and checked for a blown fuse, as a firt step of troubleshooting. This is applicable when no light in the front panel is on or blinking. If this do not work or the fuse blows again, there is a short circuit or a bad component that need to be replaced. But this task require another approach.
Please follow the instructions on dealing with high voltage parts of the tv set.
I shall be glad if this is helpful.
Sully
Sep 22, 2013 | Philips Magnavox MWC20T6 TV
Funai magnavox model#37md359b-7 when turned on for amp fuse blows on circuit board
Could be 100 things. Do you see any burnt components or burnt spots on the board? Probably no way for you to fix this unless you have the electronics repair skills unless you visually spot a short on the board like a loose screw that ended up laying on a couple of components etc.
Feb 18, 2013 | Funai Magnavox 19" Class 720p 60hz LED TV...
MY MAGNAVOX TV MODEL#30MF301B FUSE BLOWING UP AS SOON AS I PLUG IN
The power suply board has a severe short and will most likely need replacement. You can get replacement power boards fom www.tvcircuitboards.com
Feb 06, 2013 | Magnavox 32MF301B LCD TV
Magnavox 37MF437B/37 keeps blowing fuses
Either a short somewhere---which fuse? The one at the power cord or what?
Other possible reason is wrong fuse----many of the fuses in these sets are special-----if you go and buy some Generic ones--hardware store or Radio Shack the fuse even with same amperage/voltage rating may blow at turn on instantly for no reason------
Dec 08, 2012 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Magnavox Television
There is an 8amp 250v 5mm x 20mm ceramic slow blow fuse on the power supply board inside the TV. The picture below shows the board with the fuse circled in yellow. If you had a big enough power surge it may have damaged other parts of the power supply beyond the fuse. Look for burn marks on the power supply board when you replace the fuse. If you need additional information just let us know tech@ccl-la.com
Jul 25, 2012 | Magnavox 40MF430B LCD TV
Need the board of an philips magnavox model PTV910
Which Board are you needing? Let me know and I can assist you.
Jan 02, 2010 | Philips Magnavox 9P6034C 60" Rear...
Power board in magnavox 37MF231D blows fuse right away. Caps are good on board and fuse still goes when disconnected from TV.
Then you have a shorted regulator circuit. the best bet is to replace the power supply board itself. The part number is 313815864961. Please take a few moments to rate my answer, Thank you.
Nov 17, 2009 | Philips Magnavox 27MS343S 27" TV
It Wont turn On
I have the same problem with my MWC20T6A (from Walmart), and I keep blowing fuses. I read somewhere that it's in the motherboard which is about $150 to fix. I'll never by a combo again.
Apr 29, 2008 | Philips Magnavox 20MC4304 20 in....
27' magnavox tv model 25e503
you need to check the primary input ac connection e.g fuse and then measure if you have 330 volts across the filtering capacitor..if this is ok or the fuse blows then disconnect ac-line and check pwer supply eg smps swiching transistor...probably gone to heaven..and replace it and optcoupler..i.e. refere to eventual kit from philips they have repair kits for your tv!...it may be a "standard" problem..if you can get a copy of servicing the smps...in technical manual for your tv it is best...ron
Mar 03, 2008 | Philips Magnavox 27MS343S 27" TV
Philips Magnavox TS3260C 32" TV Logo
29 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
