Question about Maytag Bravos X Series MVWX700XW
Washer goes from sensor to wash and does nothing else
  • Maytag Master
  • 17,129 Answers
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows though the inlet then the flow pressure should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Test a pressure switch: Click on : http://www.youtube.com/watch?v=HZZ2bDMspj8
Check this link to replace the inlet valve:
http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the dry spin with the drain valve/pump activated so as to drain off all the water from the clothes during the spin.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help
Posted on Jan 24, 2013
What is the issue with LG washer
LG WM2277HSW XL Front Load... Repair Questions - Fixya
www.fixya.com/.../p95436-lg_wm2277hsw_xl_front_load_stackable
Recent LG WM2277HSW XL Front Load Stackable Washing Machine questions, problems & answers. ... My frontloader washmachine will not turn on · LG ...
LG WM2277HSW XL Front Load Stackable Washing ... - Fixya
www.fixya.com/search/p95436-lg_wm2277hsw_xl_front_load.../open
LG WM2277HSW XL Front Load Stackable Washing Machine, open related issues. Get free ... Wait 5 secs after turning off door release should open. If this does not ... OE error message won't open door, won't spin out water What is filters & open it are my problemsDue to that I cann't ... Where is it sticking and how do I fix it?
LG Tromm WD 12270 RD washer and dryer 'LG ...
Dec 19, 2015 | LG WM2277HSW XL Front Load Stackable...
Does not Wash
first check if there was an object that obstruct the motor, try to clean that area, and run again the unit, if the problem was still there, then could be the washer motor was broke.
Aug 07, 2008 | Whirlpool 24 in. GU1500XT - Multiple Color...
I turn on washer then it kicks off. I noticed sensor light goes off also
you have short between switching contacts most of them are faulty since water got inside
Sep 15, 2015 | Frigidaire Washing Machines
My washer is not working it has power but it wont wash it wont rince it dose nothing
Would love to help you but I need to know if it is displaying any error code?
Feb 18, 2015 | Kenmore HE2 Plus Front Load Washer
My kenmore washer will click on and off but will not start
It is a problem in the electronic control board. It must be replaced by a technician.
Dec 15, 2013 | Kenmore Washing Machines
Kenmore washer does not fill first ,goes right into washing.Replaced timer ,same problem.
Hello Sue,
The reason your washer starts agitating instead of filling first is shortted water level sensor switch that should be replaced.
The part number for that switch is W10177795
GENE
Nov 11, 2011 | Kenmore Washing Machines
FILLS WITH WATER THEN NOTHING
There is a water level sensor switch inside the washer. This sensor
needs replacing. It tells the washer to start running when the level
of water reaches the correct amount for you load size.
You will need to call a service repair man to change the sensor.
Feb 25, 2011 | Kenmore 24032\24036 Top Load Washer
MY PROBLEM IS THE FABRIC CONDITIONER IS NOT BEING WASHED AWAY THE WATER GOES INTO THE COMPARTMENT BUT WHEN THE CYCLE IS FINISHED THE CONDITIONER AND WATER IS STILL IN THE TRAY?
Hotpoint Aquarius WMA42 Front Load Washer
This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question..
Jul 30, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Frigidaire Washer HELP
check for a sensor switch located underneath the door , its a safety device to ensure that door is tightly closed . hope it helps
Apr 18, 2008 | Washing Machines
Maytag Bravos X Series MVWX700XW Logo
63 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
