Question about Kitchen Appliances - Others
I have a fleetwood slicer gl300 need to break down to clean
Can not break the blade down to clean the the inside of the blade
3 Suggested Answers
SOURCE: Globe commercial Meat slicer
Hi, I have working on meat slicer my whole life and can help you.
What normally happens is this. The bearings in the knife hub (this is the unit that the knife attaches to and spins) is starting to fail.
The gear on the knife hub is made out of a fiberous material and the worm gear on the motor is made out of metal, so when the bearings start to fail and cause resitance in the hub, the metal motor gear starts to eat the fiber gear on the hub and eventually wears a big chuck out of it. Then the motor spins free and doesn't make contact with the hub gear.
How you can check if this is the problem is this. You need to keep the power switch on machine in the off position and turn the blade a 1/4 of a revolution. Then turn the machine on, what should happen is that the blade will spin some and stop again.
The proper fix for the machine would be to rebuilt the knife bearing unit and replace the hub gear, motor gear and hardware.
In regards to the Chefmate. This is a design flaw of Globe and I told them about this when the machine first came out! The know is on a steel shaft that goes thru the aluminum body. The steel shaft starts to corode and also rust, then it freeze in the frame. What has to be done is this. This assembly needs to taken about sanded, lubed and put back together. The best way to permently fix this is have a machine shop machine the frame out and install a Oilite Bushing, these are impregnated with oil and it will never lock up again.
Where are you located? Let me know if I can answer any other questions for you.
If you have any other questions, you can call me on my cell 201-274-6274 or e-mail me at njrealestate@earthlink.net. Thank you
Best regards,
Scott
Posted on Dec 27, 2008
SOURCE: Rival Meat Slicer Model 1037 Pin for blade
i too need a pin for this modle. has anyone solved this problem for that person?
Posted on Sep 15, 2010
The blade is wobbling on my Fleetwood meat slicer EF12 Slices look like waves.
check that the problem is not from the way the blade is mounted on the shaft
any thing between the blade and the backing hub of the shaft will make the blade wobble so check for burrs , bad fitting parts or the like at the blade center
new bearings , shaft and hub are new but is the hub on the shaft straight
Dec 17, 2015 | Home
Where can I get gears for Gourmet Living Shopko meat slicer?
Unfortunately meat slicers in this price range are throw away items if they break. Neither Gourmet Living or Shopko actually make this slicer so it is nearly impossible to find parts for. It is probably made in China.
I would suggest you spend a little more money (90.00) and get something like Nesco FS-140r. It has a one year warranty and you can buy parts for it thru Nesco.
Mar 26, 2014 | GOURMET LIVING Shopko Meat Slicer NO...
Meat slicer: when slicing our pork loin the meat will stick up under the blade at the bottom causing the meat to spin off the slicer?
The blade may require cleaning in between usage as the oils and sugars are solidifying on the blade from previous usage causing the meats to adhere to the blade when sliced.
Dec 22, 2013 | Kitchen Appliances - Others
We have a meat slicer with no manual and no brand name anywhere on it! The only information on it is a plate at the back that says "MATR 32, TYPE 220M" My husband can't figure out how to...
Hi if he has to remove it , never heard of someone removing a blade to clean it , he needs to use a inpact screw driver with a hamer, I see so many louse fingers not knowing what they are doing
Oct 02, 2011 | Berkel 827E Gravity Feed Deli Meat Slicer
Do not have model #...older slicer. need to remove blade to clean behind
there is a thru bolt on the left side of the slicer if you are facing it to use it, that holds the plate on, unscrew it, its usually red
Sep 07, 2011 | Berkel 827E Gravity Feed Deli Meat Slicer
Guard
I'm not certain this is the same model I'm thinking of, but I think there may be a knob on the back side (behind the blade) which clamps down on a shaft coming off the blade guard. Loosen the know and the guard should pull straight off. Maybe I'm thinking of a different model slicer, but the photo looks correct.
May 19, 2010 | Berkel 827E Gravity Feed Deli Meat Slicer
Globe Meat Slicer Model # 500 motor runs blade not turning
Fiber gear on blade hub stripped. deep socket required to remove hub. DON'T CUT YOURSELF!! remove motor, used food safe solvent to clean grease out of housing. Fiber gear held on with snap ring. Replace gear, repack housing, put hub and motor back and start slicing. Routinely check to make sure gear is lubed.
Oct 30, 2008 | Berkel 827E Gravity Feed Deli Meat Slicer
Kitchen Appliances - Others Logo
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
