Question about Relic By Fossil Bella White Resin Womens Watch ZR11898
How do i replace the battery in a relic watch zr11898
SOURCE: Watch Band Adjustment
I just got this watch for a gift and was able to remove links myself after doing some research. It really isn't difficult if you are patient, have a little mechanical experience, and have some very basic "tools" available.
Tools:
  • 1 push pin like you use on bulletin boards with a plastic head
  • 1 small hammer like a tack hammer
  • 1 pair of small pliers. Needle nose pliers would be best but I used diagonal wire cutters (be careful not to cut the link pin)
  • 1 small block of wood
Try to pick a well lit table in a room where you will not be interrupted.
Procedure:
1. Lay the watch and band sideways on the block of wood so that a pin for the link you would like to remove is just hanging over the edge of the block and pointing down. You need the block to brace the band while you hammer lightly on the pin. Someone to hold the watch in that position would be helpful, but it can be done alone. Only try to remove pins that have an arrow on the back of the band pointing at them. It does not matter with this watch band which way you go with the pin.
2. Carefully line up the push pin point with the top of the pin.
3. Slowly, lightly and carefully hammer the plastic side of the push pin so that the pin in the link just emerges from the band on the bottom side enough so that you can grab it with the small pliers.
4. Slowly and carefully pull the pin straight out with the pliers. You can pick up the watch from the block of wood to get a better grip. Be careful not to bend the pin since you will need to replace at least one of the pins you remove.
5. Repeat steps 1 - 4 until the band is the correct length. I needed to take out 3 so I removed 2 from one side and 1 from the other side of the clasp.
6. To fasten the watch back together again, gently insert the pin back in the hole it came from it. You will probably need to use the tack hammer to make the top of the pin flush with the band.
Posted on Jan 09, 2008
escapement
  • 2334 Answers
SOURCE: Mens Relic watch stopped working after battry change
I suggest that your watch has an oxidized contacts and electricity can not reach the movement.
Do as folloes:
Take out the batttery,
Clean (scrape) all battery related contacts till they are shiny (use hardened steel needle for that),
Use the dust blower to get rid off any tiny dust and dirt particles after cleaning,
Refit the battery back.
Now your watch should work again.
If all written above do not help, then there is a problem with your watch and you will need the help of the watchmaker.
Do not forget to rate, please.
Posted on Feb 10, 2009
SOURCE: how to set the time on relic watches
I had to go to the Sears counter to fix mine. The sales person had to use TWEEZERS to pull the serrated knob up. He had to really work at it. Once it is pulled up you can twist the knob to set the time and then push the knob back down. What a stupid design.
Posted on Mar 13, 2009
disap1
  • 98 Answers
SOURCE: How to adjust Relic ZR15539 watch band
Depends on the type of band. Is it a twist-o-flex or solid link? Your best bet is to seek out a local watch repair business and let them adjust it for you! Unless you do these often it can be frustrating and you could lose small parts!
Posted on Jan 09, 2010
escapement
  • 2334 Answers
SOURCE: set the date on my new relic watch
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all RELIC watch manuals.Rate me, please
Posted on Mar 23, 2010
What is the battery size relic zr15610?
Take your Relic watch to a jeweler who, for a reasonable sum, will replace the battery.
Dec 03, 2016 | Relic Watches
What is battery number for relic watch zr11811
Just replaced the battery in my colleague's Relic ZR11811. The battery is a 371. Equivalents include AG6 and SR920.
Apr 09, 2013 | Relic Watches
What kind of batery need for relic zr 15490? i don't know because i lose my old batery.
mcdevito75 Here, Your in a spot, Looseing the old battery to your Mens Relic watch, you can look for a small watch repair shop in your area, they may have an idea of the battery number, but will most likely tell you they need the watch to know for sure. You can also try battery 364 or 371 but even I can"t be certain. You can also try online at Contact Relic Watches.com Reic should have a website. You may be left with only 1 choice, have the watch repair shop replace this battery for you, you"d have to buy and try a couple of different batteries and each battery in the store runs about $5.00 each, at the watch shop let the Jeweler figure out the battery number for your watch for 1 price. I think this is your cheapest and best option.
Feb 11, 2011 | Relic Dial ZR15528 Watch for Men
I can't find a replacement battery, I have 2 3
Go to "http://relicbrand.com/pdf/Service_Form.pdf" and you will find an order form with prices for repairs and battery replacement.
It may seem expensive for a replacement battery but if you see the number of people who can't get their watches to go after battery replacement, you wouldn't hesitate to send them off.
Mar 17, 2010 | Relic 0504648FA
Need battery number for Relic watch model ZR15477--old battery was lost.
Take your watch to a good watch shop and they will be able to replace the battery for you.
Feb 01, 2010 | Relic 0504648FA
Does not run. does this watch have a battery in it?
There are two types power sources for watches. Automatic and battery.
Automatic needs to be either wound by the crown (winder on the side) or wound by the movement of the wrist while it is worn.
The battery powered is self explanatory.
Since you didn't include the model it's difficult to say for sure because Relic makes both automatics and battery powered watches. Although I can tell you is most automatics will clearly labeled. If your watch say automatic somewhere on the face or back you need to contact Relic for service because your watch has a 12 year warranty.
To prevent violating your warranty a jeweler should be the one who replaces the battery if it is battery power.
I included the link to Relic watches below for info on the warranty and instructions.
Hope this helps.
Nov 13, 2009 | Relic Multifunction Watch
Relic Watch Battery
http://www.apexbattery.com/relic-watch-battery-watch-batteries-relic-watch-batteries.html ... I've had 2 different sources take me to this same battery, although the Relic model I'm using is a ZR11586. "This battery is for ALL Relics," is what they keep saying.
Apr 22, 2008 | Watches
Relic By Fossil Bella White Resin Womens Watch ZR11898 Logo
289 people viewed this question
Top Relic Watches Experts
Ansel Alberto
Ansel Alberto
Jim Parker
Jim Parker
Are you a Relic Watch Expert? Answer questions, earn points and help others
