How to change memory transmission settings for lanier lf312
Sharp fax UX-84/ FO-90 probleme: sortie des papier ne fonctionne pas
Posted on Jan 23, 2013
Lanier 024c toner cartridge setting error black toner cartridge is not set properly, how to i set it
Hi! ok, try to clean the contact with alcohol. If it is a refilled cartridge the you have a technical problem in the cartridge. You have to bring it back to the seller.
You can not solve it, you have o change the body of the cartridge.
Dec 07, 2010 | Lanier UNKNOWN
I want to program email addresses on a Lanier LD050 copier/fax/scanner machine.
On the keyboard......User tools> administrator tools>address book.
you make your changes\ additions here.
You also must have your network settings completed in user tools. DNS, SMTP SERVER, GATEWAY ect....
Jan 25, 2010 | Lanier UNKNOWN
Just started using Lanier model VW 260 transcriber for work. The counter display does not change. The top of the screen shows "Inst", "Length", "Unit No.", Total Units", and "Level". The only numbers it...
Hello the Display work like this insert the tape on the Lanier VW260 with the unit on rewind the tape to the end when you press play the Display start to count
Nov 13, 2009 | Lanier VW-160T
How do you program the correct time of day into a Lanier LD016spf?
You can change the time setting by pressing "UserTools" the selecting "System Settings" and then selecting "Timer" settings. There you will find the time setting.
If you do not have a manual for your copier you can download it here:
http://www.lanier.com/downloads/Default.aspx?hbn=manuals
Oct 20, 2009 | Lanier Office Equipment & Supplies
Need to delete address folder from the scanner screen on a Lanier 225. Thanks
Should be as follows:
"User tools"
"system settings"
"key Operator"
"program/ change/delete address"
Then select the appropriate function /address, etc. to change
Please let me know
Apr 02, 2009 | Lanier Office Equipment & Supplies
I cannot find a manual for my Lanier 5025 copier/scanner (Ricoh Aficio 200) and am unable to figure out how to change the identification settings for the fax. i.e.; put my id name and number on faxes. Does...
I'm going by my own memory here, so you may have to fool around a bit, but this should help. Manual is hard to come by for this old beast.
"user tools"
"fax"
Scroll to "key op. settings" (i believe you have to press "yes" or 'Ok" immediately after selecting this to access this feature??)
In there you should see settings for RTI/TTI. This is what you program for your Identifiers (use the 'quick dial' keys for entering text).
Good Luck ;)
Mar 05, 2009 | Lanier Office Equipment & Supplies
Lanier copier won't scan to computer
IF you're scanning to folder, check your security settings in file sharing. Try allowing all permissions to each listed and apply.
If you there is a computer that you know definately works already, have a look at their settings in security tab of file sharing - and change permissions to allow full control (for now). See if your scanning works.
Oct 24, 2008 | Lanier Cquence M3
Canon Fax L220
From previous experience it is a compatability problem stemming from propritary transmission modes. Not sure what model Lanier fax is but they can disable some optional transmission modes first. Otherwise if this person is important you can tell that person to force transmit to you at 9600bps.
May 11, 2007 | Canon FAXPHONE B640 Plain Paper Bubblejet
51 people viewed this question
jasbo
jasbo
