My neat receipt scans the images backwards. Almost a mirror image of what it should actually be. What do I do to correct this?
    Sergeant:
  • 241 Answers
I am unfamiliar with the 'My Neat Receipt' software (assuming it is software) but you could always just flip the image using an image editor like Paint.NET.
I appreciate it is not a good long term solution, but should get you out of a jam.
Posted on Jan 23, 2013
SOURCE: Printing Backwards like a mirror image
If your job printed out backwards then you must select Print as Image located in the top right corner of the print dialog box that shows up when you set your document to print:
Posted on Aug 25, 2008
sanjay_tech
  • 20 Answers
SOURCE: HP L7580 printer prints mirror image
Turn the mirror image option to on. If it does the same turn it off than uninstlall and reinstall the complete software.
Posted on Jan 26, 2009
SOURCE: Printer is printing job as a mirror image
go into the properties setting for the printer, go to advanced tab, then to the prinint defaults button on that tab. When you click on that - if you go to the advanced tab within there, you will see "mirror image" and i bet it says "ON" - click on the word mirror and it opens up the ability to set this back to off. Hope that helps!
Posted on Apr 21, 2009
  • 214 Answers
I would have said Gotta be setting in your print dialogue box, but if the test page comes out as mirror image, must be
a setting on printer control somewhere
Posted on Apr 25, 2009
bassplayer97
  • 154 Answers
SOURCE: How do I stop printin in mirror image? I already
go to the printer from the control panel on your pc and verify the defaults are set correctly. if you are changing it in word for example it may only do it for the one time you are trying to print. usually if you right click the printer and go to properties, you'll see the settings there.
Posted on Jul 12, 2009
Neat multi-page
The neatdesk software allows you to rotate the image as desired. Pay close attention to how you load the documents to determine the correct way to load.
Sep 05, 2014 | The Neat Company Neat NeatDesk Desktop...
Blank scan with neat desktop scanner
Connect the scanner to a different computer.
If you get the same result, then the scanner is "dead".
It's moving the scanning-head, but not detecting (or not transmitting) any "non-base-line" information.
Either that, or you have changed the CONTRAST and/or BRIGHTNESS settings to "wash-out" the image -- like looking at a "cream" coloured piece of paper in bright sunlight -- it may look "white".
Feb 03, 2014 | The Neat Company NeatDesk Desktop Scanner...
Why would my 'copies' be coming out black pages on Neat Receipts portable scanner; prior to cleaning they were heavily streaked with black lines...now totally/heavy black.
A high percentage of scanners that people use at home are made by Visioneer, although they may be labeled and sold by other companies. Xerox is one example. The Visioneer software drivers are sensitive to changes that routinely occur in MS Windows from software installations, updates, etc. On this Visioneer webpage the company says, in describing the problem, "Your scanner does not appear to be functioning normally; you are getting errors when attempting to scan, your images are not easily readable, or you are unable to access the scanner properties." and "Problems may arise after you have made changes to your Windows environment (e.g. you installed Windows Updates, you installed another scanning application, etc...).".
Instructions as well as some software utilities are available for free download on the same page. Of course this won't help if something has actually broken on your scanner, but they're pretty durable, and chances are you can fix it by closely following the instructions from Visioneer.
This answer should apply to several of the questions in this section.
Jun 22, 2013 | NEAT Receipts Mobile Scanner
PRINTING BACKWARDS
Go to Start>>Control Panel>>>Printers.
Select Printing preferences.
Go to Advance Tab.
Select Mirror images and turn it off or uncheck it.
Press Apply and OK to Apply the settings.
Also perform the same steps on Solution Center.
Open HP Solution Center.
Go to Settings>>Print Settings>>Advance Tab.
Mirror images=OFF
Jun 01, 2010 | HP PSC 2210 All-In-One InkJet Printer
Prints backwards
You have probably turned on the "Mirror Image" option.
When you go to print and the Print window comes up, select Preferences and then the Advanced tab. Look for the Mirror Image option and Disable it by clicking on the underlined option and change it.
(BTW, the Mirror Image is used to print iron-on images for t-shirts, etc.)
NOTE: If you don't see it on the Advanced tab, look on the Effects tab.
Nov 17, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
Printing backwards after installing vista service
click on start > control panel > printers or printers and faxes >
right click on the printer icon and select printing preferences.
click on advance and look for mirror image
turn off mirror image and click apply.
this should work
Oct 27, 2009 | HP OfficeJet 7310 All-In-One InkJet...
How print iron on transfers
Yes, you need to "MIRROR" the image. Go to printer properties and select the ADVANCED TAB. Click on the MIRROR setting then print onto the transfer paper. The image should print out backwards like you are looking at it in a mirror. When you iron it onto a shirt, it will come out correct.
Jun 17, 2009 | HP Officejet Pro L7680 All-In-One Printer
Images upside down and backwards
The ADF does nothing more than feed the document into a position to be scanned, and has nothing to do with print issues " stripes" on print? Can you provide more details.
Typically you will find an icon near on the tray of the ADF which will display the proper orientation for the item to be scanned. If this is correct, then your software is somehow manipulating the image to a different orientation. You may want to check the scanned image before printing, and check the printer settings. More likely a printer problem, than a scanner problem as I have understood the issue thus far.
Nov 19, 2008 | Xerox DOCUMATE 510 Flatbed Scanner
Television screen is showing mirror image not the actual image.
There's a button on the original remote control that does exactly that:
(Please vote or comment if my solution helped you!)
Adjusting PICTURE FLIP Settings
You can set the orientation of the picture.
Directly setting the PICTURE FLIP
Press PIC. FLIP to display the
PICTURE FLIP screen.
2 Press PIC. FLIP to change the
setting.
Setting the PICTURE FLIP on the
MENU screen
Press MENU to display the MENU
screen.
2 Press a/b to move the cursor to
PRESET, and press ENTER.
3 Press a/b to move the cursor to
PICTURE FLIP, and press
ENTER.
4 Press c/d to select the desired
picture flip setting, and press
ENTER.
5 Press MENU to return to the main
screen.
NORMAL MIRROR ROTATE
UPSIDE DOWN
A•
The PICTURE FLIP screen automatically
disappears in 3 seconds.
• [NORMAL]: normal image
[MIRROR]: mirror image
[ROTATE]: rotated image
[UPSIDE DOWN]: upside down image
Oct 22, 2008 | Sharp LC-15AV7U 15 in. LCD Television
You need to change the printer properties.
You can do this a few ways:
  • Click File , Print , then click the Properties button.
  • Click File , Print Setup , then click the Properties button.
  • Click File , Print , Setup , then click the Properties button.
  • Click Print , Properties , then click Printer Assistant .
  • Click the Taskbar Printer icon.
  • Right-click the applicable 3740 icon in the Printers folder, then click the Printer Preferences button.
Click on the "Basics" tab.
The 3rd option under "orientation" will say "mirror image".
Make sure this is un-checked.
Mar 24, 2008 | HP DeskJet 3740 InkJet Printer
35 people viewed this question
jasbo
jasbo
