Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
My Whirlpool refrigerator model no. ED5FHEXNS01 lower crisper pan freezes veg. Any suggestions.
The lower crisper pan freezes vegetables. It's been like this since I bought it. I've fiddled around with all the controls to no avail.
  • 38 Answers
I believe there is a air vent / hole .. if you remove the crisper drawer on left you should see a small mechanical vent if so close it.
Posted on Jan 30, 2013
  • 41 Answers
SOURCE: vegetable draw is freezing the vegetables
if you pull out the vegetable drawer, you will notice a vent on the left side in the back. get some tape ( I use aluminum tape ) and cover the bottom half of the vent, that will help keep your vegetables from freezing. that should solve your problem. Joe
Posted on Dec 12, 2008
lojacksdad
  • 121 Answers
SOURCE: Water collects in bottom of refrigerator and gets in bins
there is a cup in the back wall of the fridge that is the drain pull it out gently and clean it plus take a small hose and blow through the small hole if there is no cup check under the crisper to see if the drain hole is there
Posted on Apr 17, 2009
  • 226 Answers
SOURCE: Vegetables freezing
Most side by side refrigerators use the freezer to supply cold air to the refrigerator side. They use a duct through the wall between the two sides to let COLD air come into the refrigerator. That cold air will be blown upon the drawers at the bottom, where you are storing your vegetables.
There are two adjustments - or three, depending that will change how the air comes through. The freezer control will set the base temp for the freezer, and thus the temp of the air coming into the reefer to cool it down. The reefer can have a movable vane that increases or decreases the amount of air flowing in from the freezer, the vane being operated at the command of the refrigerator temperature control. Some have a movable plate that limits the flow of air on a fixed basis.
Set the freezer for 0F. Adjust the refrigerator setting, starting in the middle of the range, until a thermometer on a middle shelf, will read at 40F. Take your time, and check once an hour or so, to let it stabilize.
Make sure that you are not blocking airflow in the refrigerator, as the air must circulate to avoid too low a temperature in spots, such as you are experiencing.
Posted on May 21, 2009
SOURCE: FREEZER BUZZING NOISE - Whirlpool refrigerator Model# ED5FHEXNS01
My whirlpool side by side makes a vibrating noise when in cool cycle I press at the back of the panel in the freezer side and it stops
Posted on Apr 27, 2010
heatman101
  • 43501 Answers
SOURCE: My Whirlpool 25.6 cu. ft. Side-by-Side
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Posted on Dec 16, 2010
Water in veg crisper freezing
You have a white cover in the back of your fridge it says twin cool on it. Behind that cover is a drain for your defrost cover that is probably frozen and water is leaking through that cover. Wrap a piece of copper wire around the heater and fish it down the drain and it
will fix the problem
May 09, 2014 | Samsung RF265AA Bottom Freezer French Door...
Why do my vegetables freeze
Do you have frost buildup on the rear wall of your freezer? What is the model number for your Whirlpool? It is important that you provide the model number so I can see what may be causing the freezing temps in the fresh food section/crisper. Thanks JT
Feb 06, 2013 | Whirlpool Refrigerators
Fisher and Paykel E402B beeping, freezing symbol flashing, crisper bins freezing.
sounds like a sensor faulty will need a tech to recify the problem.
Nov 29, 2012 | Fisher and Paykel Refrigerators
Fridge freezing items in veg draw
Usually the thermostat stuck closed but can sometimes be drain water freezing after defrost due to blocked drain. Fully defrost and check water drains away.
May 09, 2012 | KitchenAid Whirlpool Kitchen Aid...
My vegetables are freezing in the vegetable/meat bin. How can I keep them from freezing?
Check your settings for your thermostat. Turn it down in increment's one letter or one number at a time. Higher letters and numbers normally mean lower temperature. Also, the veg bins have settings also.
Feb 13, 2011 | Kenmore 57029 Side by Side Refrigerator
I have a GE side by side refrigurator model Gss201epc ww serial Tf220054 and am having a problem with stuff freezing in the crisper, I do not see any type of adjustment any ideas here? Thanks
initially, set the refrigerator compartment control at 5 and the freezer control at 5 and allow 12 hours for the temperature to stabilize.
Several adjustments may be required. Adjust the controls one increment at a time, and allow 12 hours after each adjustment for the refrigerator to reach the temperature you set.
Adjustable Humidity Crispers and Snack Pan (on some models)
HIGH LOW
HIGH LOW
Normal
Coldest
Slide the control all the way to the High setting to provide high humidity recommended for most vegetables.
Convertible Meat Pan (on some models)
The convertible meat pan has its own cold air duct to allow a stream of cold air from the freezer compartment to flow around the pan.
The variable temperature control regulates the air flow from the freezer compartment.
Slide the control all the way to the Low setting to provide lower humidity levels recommended for most fruits.
Dec 20, 2010 | GE GSS20IEP Side by Side Refrigerator
I have a problem with items freezing in the refrigerator. I have the setting as warm as I can put it. It even freezes lettuce in the vegetable crisper.
You need to change the cold control. Call Bi Coastal Appliance Parts @ 1-800-673-1262 give model and serial number.
Nov 16, 2010 | Whirlpool Refrigerators
Vegetable crispers freezing my vegetables
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Dec 17, 2009 | Refrigerators
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
233 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
