Question about Crosley Audio Players & Recorders
I got given the Crosley CR6009A turntable as a gift. Very stupidly I plugged it in to the wall, turned it on and something went 'pop'. It's from the US (120v) and I'm in the UAE (240v)
More info on the turntable here: http://www.crosleyradio.com/Product.aspx?pid=2015
  • 77 Answers
SOURCE: Why do you over charge?
Newegg is better!
Posted on May 27, 2008
pgh_pa_guy
  • 2992 Answers
SOURCE: would this motherboard fint in
Yes, the board would physically fit in the 5000 series case. In fact, any micro-ATX form factor board would fit. But you will need a new power supply as well. Motherboards used in those computers did not need the 4-pin power cable required on new boards. You should also consider cooling if you are building a high-performance system. The 5000 series case doesn't offer much room for adding cooling fans - only one place on the rear panel. But they are nice cases. I've built several systems in them.
Posted on Feb 11, 2009
  • 3 Answers
SOURCE: JBL on stage II speaker doesn't work
If your 120v unit is not marked for use with 220-240v and you plugged it into such a socket (even once), you probably fried the AC adapter and will need to get a replacement.
Posted on Sep 26, 2009
  • 1082 Answers
SOURCE: I am going to list
The NewEgg reviews are mixed for the second unit. I generally lean towards the larger PSU but it depends on your future plans. For the little difference in price, I'd do the 850.
Very subjective question & answer. :-)
I don't get paid for advice so if this answers your problem, I would appreciate 4 thumbs.
Jim
Posted on Sep 22, 2010
SOURCE: http://arcade.reflexive.com/redirect.aspx?rra&...
I WANT FISH TYGOON UNLOCK CODE
Posted on Dec 04, 2010
What is signal to noise ratio
The noise is that produced by the working circuits of the item in question. If this is too high the signal (what you want to listen too) will become overwhelmed by noise (generally in the form of hiss). Therefore the higher the signal and the lower the noise the better. This is expressed in a ratio between the two.
Apr 28, 2015 | Crosley Audio Players & Recorders
Audio is quite muffled
Well this question takes me back a long ways. I would suggest the following
1- Clean the records with a micro fiber cloth just to make sure they are not the problem
2- Check your needle for something stuck on it, use a magnifying glass since if there is something probably to small to actually see.
3- Check that your needle is set with enough weight on it to keep it from skating and that the wight is keeping the needle in the groove and not skating the along the edges.
4- Check the wires from the record player to your amp, since they can wear out on occasion and this will affect the sound quality that you get.
Beyond this, not really sure
Feb 21, 2014 | Crosley CR6009A Advance Turntable - Belt...
Crosely won't play usb
If it's a turntable with a usb connector, those connections are usually outputs only. USB on a turntable is used to output the audio to a computer to rip albums to digital audio.
Jun 17, 2013 | Crosley Audio Players & Recorders
My Crosley CR49-TA won't revolve. It turns on, and
Most turntables are belt driven. Suggest you take a look inside but remember to unplug the deck first. Usually it's a simple case of slipping the belt back on.
Apr 26, 2013 | Audio Players & Recorders
Crosley CR24 transformer rating
As transformers are Safety parts they must be replaced by the excat same part or one that is approved by Crosley. You should not attemp to use another transformer unless it's approved by Crosley. Otherwise it could become a fire hazard.
You can contact them here:
http://www.crosleyradio.com/Support.aspx
Nov 17, 2012 | Crosley Cr42 Turntable
How can i slow down the turn table on a crosley cr 66 multiplayer with no control speed and it don't work pulling the arm to the right I tried that not helpful
The problem is in the motor of the turntable, the regulator is not putting out the correct voltage to the motor, and the circuit is often built into the motor making it impossible to service. The only option is motor replacement.
Mar 12, 2012 | Crosley Entertainer CR-79 Turntable, CD,...
Haven't used the turntable in years. Went to use it today and the turntable doesn't begin turning when the arm is lifted. Everything else works. Thanks, Al
If this is a belt driven turntable, then you have to replace the belt, as this units gets old the belts loosen up as well.
Aug 20, 2010 | Crosley CR74 Turntable
Turntable will not rotate when in "Phono" mode
I recently was given my Father's CR78CD and, assuming your unit is in working order, you turn on the turntable motor by lifting the tonearm off the post and moving it away from the turntable about one and a half to two inches. You should hear a soft click as the switch for the motor activates.
Jun 20, 2010 | Crosley CR78CD-P CD Shelf System
USB Device Not Recognized
uninstall driver then turn off the PC then unplug the power cord from power socket, short its legs then leave it unconnected for 5min, then reconnect it to power socket and turn on PC and install driver it should work :)
Aug 28, 2008 | Crosley 0187SST Turntable
54 people viewed this question
Top Crosley Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Crosley Audio Player and Recorder Expert? Answer questions, earn points and help others
