Question about Home Main Vo Toys Vinyl Cursor Ball Dog Toy 3 In
Ball cursor download
Levani
    Sergeant:
  • 213 Answers
Sir I researched for quite a while. It appears the online method is not available. Contacting the chain who represents the maker at your local may be the best resource to voive your concern. Fare.Well.
Posted on Jun 24, 2014
I have a Dell laptop. I'm not able to control the
The cursor operated by the mouse?
Try using the cursor (arrow keys). If they work, try cleaning the mouse ball, unscrews from the underneath, or change the mouse if optical.
Sep 13, 2014 | Computers & Internet
Stop my cursor jumping about
That must be a wire mouse the cable might be getting a bit frayed inside the sheath if it's a ball mouse, try taking the ball out and cleaning the ball and all the rollers. And if it is an optical mouse on bad surface. Put a piece of white paper on your desk and try it on top of that.
Jun 28, 2013 | Computers & Internet
Mouse will not mover cursor but will right and
Does your mouse use a ball for movement?
Look at bottom of mouse. If so you could have a ditty unit. You can turn the ball cover counter clockwise and remove the ball. Clean the ball and the rollers inside the mouse. Replace the mouse ball and cover and retry the mouse.
Jan 28, 2010 | Computers & Internet
My mouse pad will not move my cursor on my computer
If your mouse is the older ball type hold the mouse level about 12 inches off the pad and move the ball on the underside of the mouse with your finger. If the cursor moves you may need to simply clean any dust from inside the device and clean the ball. Open the open to release the ball. Theres a round plate on the underside around the ball. Turn it to the open position a remove the ball. Clean any dust from inside with canned air or a soft brush. Clean the ball with a small amount of alcohol and let dry completely. Replace ball and plate and you should be ready to go.
If you have an infrared mouse, your mousepad may be too glossy. Dry a pad with a dull finish.
Jan 18, 2010 | Computers & Internet
Cursor jumps all over with a touch of the mouse why
trackballs and other ball mouses have an optical sensor inside the cup that holds the ball. dirt, lint and debris that falls into the optical sensor can make the cursor jump around - the sensor detects the debris as if it were a ball movement. Clean the inside of the cup and the jumping should stop.
Cleaning the cup -- first clean the three points that hold the ball up. They tend to grap whatever dirt or grease gets onto the ball from the user's hand. Clean the rectangular sensor window with a que-tip or by blowing into it. Get any stuck debris out of the corners. Finally, turn the mouse over, without the bal inside, and tap it on a hard surface. This can knock loose any remaining debris that can fall into the sensor window.
Dec 11, 2009 | Logitech Trackman Marble FX Trackball
Spin ball. Cursor barely moves on screen.
Have ya tried removing the ball and cleaning the infrared screen under the ball with a cue tip? Also get all the finger grease and gunk out of that area too. You can remove the ball with a pencil or pen, use the dull end of the pen or the eraser end of the pencil, so you don't divot/dent the ball.
Aug 17, 2009 | Logitech Trackman Wheel 904353-0403...
Dell ms intellimouse vertical movement of cursor
open the mouse remove the ball you should see two support shaft for the ball check whether they are rotating clean them if you can
if they rubber shield of shaft is damaged try replacing them with valve tube you usually use in a bycycle tyre
clean the transistors standing near the shaft flywheel using a soft cloth
it will be fine
Dec 14, 2007 | Dell Microsoft Intellimouse
Home Main Vo Toys Vinyl Cursor Ball Dog Toy 3 In Logo
909 people viewed this question
Top Home Main Vo Toys Dogs Experts
Ruth summersides
Thomas Perkins
Thomas Perkins
mpr9798
Level 1 Expert
Are you a Home Main Vo Toys Dog Expert? Answer questions, earn points and help others
