Question about Blue Wave Pool & Spa
I have a blue wave inflatable spa. the ground fault blows when I turn the heater on. Is it possible to replace the heater element? If so, where can i purchase the part?
    Spread the Word:
    An expert who has shared 5 answers on their Facebook wall.
  • 52 Answers
Mark
I am not familiar with the Blue Wave inflatable spa however the ones we sell are replaceable so I would imagine that the Blue Wave one would be.
Rod
www.uspartscenter.com
Posted on Feb 01, 2013
EasyPak 1000 Flex-Fit Air Spa Control System. Everything works fine, except, when plug in heater power. Gfci trips. When unplut heater power, everything works
GFCI blows because you have a short to ground. Check your wiring for loose connections and your heater core element.
Mike
May 29, 2017 | Pool & Spa
I have fractional spa pump with 1000 watt heater. the spa was on but no water was in it while it ran overnight. did this burn the heat elements out of it and can I fix it?
It should be OK. These units should have a flow switch to prevent activation of heating element without water flow. Yes, heating elements can be relatively easily be changed if needed.
Dec 08, 2014 | Comfort Line Products Spa2Go Inflatable 4...
GFCI keeps tripping when I turn on the pump
shorted heater element try with it disconnected if ok then replace heater
Jun 13, 2014 | Hayward Super Pump 1 1/2 - Hp for In...
My Therapure four person inflatable suddenly stopped working. electrician says outlet and breaker are fine. I can get the plug to blink red but then it throws my breaker. no luck with 1 800 #
It is more than likely your heating element. Not sure what style they use but if you send me a pic of your equipment, spa pack w/ the cover removed, I can walk you thru how to test it.
If you have a good grasp of electricity, find the heating element and with the power off remove the leads. Try to plug it back in, reset the gfci, and give it a minute. If it doens't trip and everything runs fine replace the heating element. With most spa packs it is possible to replace only the element, some like watkins you have to replace the whole heater. If the spa still trips with the heater disconnected start unplugging your equipment starting with the ozone, then blower, then pumps, one at a time until your braker stays on.
Oct 18, 2013 | Therapure Four Person Inflatable Round Hot...
Emerald spa
Dead short on the heater element will need to be replaced.
You will need to get the model number off the silver sticker located on the stainless stell heater tube.
Rod @ US Parts Center
Apr 30, 2013 | Pool & Spa
Jacuzzi hot tub, Water is too hot. Heats until it trips the system. I have replaced the analog temperature control,
1) Safety question first
Why hasn't the GFCI tripped.
If your spa is not protected by ground fault., then you are at serious personal risk.
http://waterheatertimer.org/How-to-wire-GFCI.html#arc-fault
2) Replace the element.
http://waterheatertimer.org/How-to-test-water-heater-element.html
3) If element is cracked, it can continue heating to ground wire, causing runaway heating.
This applies to spas, and water heaters of all type.
Dec 08, 2012 | Jacuzzi Pool & Spa
50amp breaker for spa heater gets hot after about 45 minutes and then trips. does it need replaced?
MUCH more likely that your heating element needs to be replaced. Check all connections for heat damage, due to resistance. If you ever stop water flow, the heater MUST be turned off, or you can kill it. Fortunately, it costs tons less than the breaker.
Mar 05, 2011 | Siemens 50 Amp Ground Fault Circuit...
I have a Jacuzzi Z 145 spa. I was constantly getting an FL error. Purchased a new switch, put it on and when I turn the spa on I immediately get a circuit blow. What could be causing this problem?
Its possible your heater has a ground fault. If the old pressure sw was giving the FL code the system would not send power to the heater. Now with the new sw working power is being sent to the heater.
Oct 23, 2010 | Jacuzzi Pool & Spa
Pool & Spa Logo
Top Blue Wave Pool & Spa Experts
Steve Slater
Bill Jordan
Robco Water
Robco Water
Are you a Blue Wave Pool and Spa Expert? Answer questions, earn points and help others
