Question about Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White
BFEF373JHS1" Circuit Board
Temparature digital display very dim
  • Official Brand Answer
  • 4,342 Answers
Hello Arie Sneep - If the display light is very dim, sounds like either the unit has a wiring failure or faulty EOC. Try reprogramming the range by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and restart unit. If it proves to be ineffective, contact a professional to assist with the repairs and to move forward accurately.
Posted on Jan 24, 2013
Range has a very dim display
I have a Jenn-Air double wall oven with a very dim display light. Replaced c3 capacitor 68uf 35w - with a 100uf 50w cost $1.60 closes size available at Radio Shack and works good as new. Requires soldering onto the circuit board. I price a replacement part for $276.00.
Mar 19, 2014 | Jenn-Air 27 in. Electric Single Wall Oven...
Display light board faded
Four years ago I had this problem (display goes dim, then goes out altogether) and fixed it per this post:
The circuit board for the display/touch panel is mounted on the back of the display panel itself and connected to the other circuit boards by two multipin connectors. When you remove the display panel (3 screws on top, 4 on the bottom) you will be able to GENTLY detach those connectors. They are low voltage and may be handled safety even when the oven is powered, but I agree that turning off the oven circuit breaker is good practice.
To remove the circuit board, GENTLY release the two black plastic tabs; the solder pads are underneath. I too used a 100 mf capacitor because no local supplier had a 68 mf hi-temp. Observe polarity; the (-) lead goes towards the center of the board (away from the edge connector.) You must use a high-temperature capacitor (105 degrees C, I think) or the problem will recur.
If your oven isn't put together the way mine is, this solution won't work - and I'm sorry to have taken your time.
Sep 16, 2013 | Jenn-Air W30400P Stainless Steel Electric...
Oven digital lighted display is dim
You need to replace the C3 capacitor on the control board
http://fixitnow.com/wp/2009/01/28/cheap-fix-for-a-dim-display-on-an-oven-control-panel/
You can replace only the C3 - it is 68uF / 35V and you can go to Radio Shack and get their part # 272-1028 - 100uF/35V one. It takes all but 10 minutes to re-solder the new one in place
May 31, 2009 | Jenn-Air JJW8530C Expressions Collection...
My clock and temperature display is dim
Hi, this will happen over a period of time and its just heat related. the control panel isn't insulated properly and , there has been a larger than normal transfer of heat to the inside of the control panel where the circuits are housed.
If this is a problem, i recommend replacing the control board. it will fix the dim issue.
May 22, 2009 | Jenn-Air JMW9527C Electric Double Oven
Dim light on oven display w30400b jennair
The circuit board is for the display/touch panel. It is mounted on the back of the display panel itself and connected to the other circuit boards by two multipin connectors. When you remove the display panel (3 screws on top, 4 on the bottom) you will be able to GENTLY detach those connectors. They are low voltage and may be handled safety even when the oven is powered, but I agree that turning off the oven circuit breaker is good practice.
BTW, I had exactly the same symptoms (display goes dim, then goes out altogether.)
Jan 16, 2009 | Jenn-Air W30400P Stainless Steel Electric...
I replaced the C3 capacitor on the circuit board and works fine. This was mentioned in a prior post and took 5 minutes and was under $5.00 for the part.
Nov 27, 2008 | Jenn-Air JJW8530C Expressions Collection...
Dim display.
The display sits on a circuit board. Pull the board out and replace capacitor C3. It is 68 micro farads. I used a 47 from Radio Shack and it works great. If you can find a 68, that would be ok too, of course!
Oct 12, 2008 | Jenn-Air WW27430P Stainless Steel Electric...
Oven's digital temp display too dim to read
The electronic control board will have to be replaced
Jun 07, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
202 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
