Question about Nautilus Exercise & Fitness
Nautilus t518 treadmill grade error 1
My tread mill stops in the middle of a workout and Grade Error 1 on the screen. Anybody know what this means?
SOURCE: error codes
I get a 51 code on the treadmill, I think the relay is bad, Can I get parts for this? Pat please respond to dme@gmx.com
Posted on Jan 30, 2009
SOURCE: the treadmill will stop and brings up error 1.
Hi, E1 is speed sensor or motor related, you could try changing the speed sensor, you should check wires from speed sensor to board and check wires from motor to board, yoou can check you motor by plugging the live and earth onto a 9volt or 12volt battery to see if it turns. i suggest you check and clean the brushes in the motor, hope this helps.
Posted on Oct 08, 2009
SOURCE: What does code 22 mean?
Error 22 - No Motor Pulses at Start Up
Description
Error 22 indicates that the drive motor (running belt) has been instructed to start, by either
manual or program control, and the monitoring system has not received any response from the
speed sensing system indicating that the drive motor has started.
Possible Causes
1. The treadmill utilizes an optical (infrared) speed sensor and the line of sight between the
speed sensor and the speed sensor target is obstructed.
2. Drive motor brushes are bad.
3. The speed sensor position relative to the speed sensor target is incorrect.
4. The speed sensor potentiometer adjustment is incorrect (when equipped).
5. The speed sensor is inoperative.
6. The lower PCA is bad.
7. The lower PCA to upper PCA interconnect cable is bad.
8. The upper PCA is bad
Posted on Feb 12, 2010
guru_fixya
  • 944 Answers
SOURCE: Vision Fitness T9450 Treadmill error code "E4."
E4 means
- Elevation parameters out of range
- Recalibrate it
If you want to calibrate it see the manual page no 5.
Click here to download the manual
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Posted on Sep 25, 2010
SOURCE: My NordicTrack EXP 1000 stops in the middle of a
my nordic track 1000 stops several times during the workout. I can step to the side and the belt may or may not start back up. The display continues to display the set machine. any suggestions?
Posted on Jan 23, 2011
I have a fuel fitness tread FT94 and an errow code keeps coming up E6. What does this code mean and how can it be fixed ? tread mill will not start up
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.Check for treadmill error code
http://electro-medical.blogspot.com/
Mar 08, 2016 | Exercise & Fitness
Tread ajustment
under the shroud cover there is a bolt that loosens the tension on the belt...be sure the belt sensor "sees" the belt as that is why you have an E-1 error code
Dec 03, 2013 | Exercise & Fitness
How the error e02 on fit king treadmill be repaired
Dear sir,
I am having a treadmill of Fitking model no. W590 it is showing error code e02.
Kindly suggest what to do. I am eagerly waiting for ur response
Rgds
Yash Pal
Jul 15, 2013 | Exercise & Fitness
Stairmaster quinton 612 plus error code e201
Quinton Error E201 Probable Cause Grade Over Limit Fault. Turn jackscrew counter clockwise to get within range.
Corrective Action
  1. Use Up or Down arrows to bring grade into range.
  2. If error persists, replace grade actuator or VSD. NOTE: Belt and display may continue to be used during fault conditions by pressing clear.
Quinton Treadmill Error Codes E201
Mar 16, 2012 | Startrac Fitness Products Exercise &...
Corrective Action
Mar 16, 2012 | Exercise & Fitness
Lubed belt but display still says lube belt and I cant do anything how do i clear the display I have the horizon gs950t
After lubrication you have to reset your treadmill settings. Then only the message will go off. To reset the tread mill do the following.
1. Hold the "Stop" button for three seconds to reset the treadmill and clear the current workout selection or screen. The console will reset but will save any accumulated data
2. Press and hold the "eTRAK" button for 10 seconds to reset the console date. This permanently deletes any previously accumulated data
3. Press and hold the "Stop" button while pressing the Speed "+" button. Hold for five seconds to reset the console after applying lubricant to the machine. Lubricant application is usually only necessary when you receive the "LUBE" error
ok
May 04, 2011 | Horizon Fitness Horizon T90 Treadmill -...
I recently purchased a Bowflex treadmill and while I was walking on it, it stopped working and shows the error message "Safe Out" on the console. The safety button is in place and I tried...
hi,
i think ur tread mills motor controlling circuit have some problem. may be its motor controlling igbt faulty. check it. proper care should be taken will working in tread mill. all the circuits are live . chances for electric shock. do any thing only after removing the power.
ok
Dec 26, 2010 | Bowflex Exercise & Fitness
Tread mill is on incline. how can i adjust to a flat position
I am assuming this a Icon product and this is the calibration sequence.
1) Press the Stop and the Speed Up keys down while inserting the safety key. Calibration Codes” for key sequence instructions to enter calibration.
2) Press the Stop key one time. The Time window should read EP:2P. Some newer models may also say FP, Pass, or the like. This means that it passes the EPROM test.
3) Press either incline key and the incline will calibrate automatically.
4) THIS IS A VERY IMPORTANT STEP BECAUSE YOU WILL GET AN ERROR MESSAGE IF THIS STEP IS SKIPPED.After completing calibration of incline, press the Stop key and then remove the safety key.
Jun 27, 2010 | York Exercise & Fitness
My tread mill looses speed during my workout. the
If you haven't adjusted the belt refer to your owners manual for the proper procedure if you still have the same results then it could be caused by a lack of lubrication under belt or a worn belt.
Apr 10, 2010 | Proform Exercise & Fitness
Exercise & Fitness Logo
139 people viewed this question
Top Nautilus Exercise & Fitness Experts
David Payne
David Payne
ray gallant
Techmotionusa.com
Techmotionusa.com
Are you a Nautilus Exercise and Fitnes Expert? Answer questions, earn points and help others
