Question about Dell W4201C 42 in. Plasma HDTV
I have a Dell W4201C with a 4.5 inch vertical set of 3 lines
These lines are left of center, black, white, black. The tv has picture and sound. Is there a fix?
    New Friend:
  • 90 Answers
You may be able to adjust the y board located on the left side of the unit to bypass the h/v lines. otherwise the panel is defected. i repair the units daily usually, i just replace the panel and powerboard as well as update the revision code and update firmware. I will try to describe the exact location of the adj on the board tommorow
Posted on Jan 29, 2009
4 inch horizontal black bar across my 42 inch dell plasma. tv doesnt shut off and sound ok
The thick bar you are seeing could be a couple of things - either your HDMI or any other wire your connecting has been run too close to electrical lines, or your cable incoming needs to be grounded and/or filtered. It could also be a defect in the TV.
Sometimes it will just go away.... Its hard to tell without actually looking at your setup and television.
Feb 25, 2010 | Dell W4201C 42 in. Plasma HDTV
Tv goes to straight line in center of picture then
It happens when Vertical deflection stops as Vertical Out IC becomes hot or does not get vertical signal.
Please check electrolytic capacitors and dry solder joints in vertical out section in TV.
Aug 12, 2009 | Sanyo Televison & Video
Black vertical line about 3 inches wide from top to bottom on rig
See if you can center the picture in the setup menu. It sounds like it's just off center.
Jan 15, 2009 | Daewoo DSP4210GM 42 in. Plasma Television
42" Dell plasma TV
Y SUS and Buffers are usual culprit.
You can get it from guy at
plasmatech@gmail.com
He has everything for Dell TVs
Dec 11, 2008 | Dell W4201C 42 in. Plasma HDTV
Polaroid ttm-2401
To me, sounds like a picture tube issue. horizontal / vertical controls don't fix it. then its dead.
Jun 22, 2008 | Polaroid TTM-2401 TV
This is garbage
Send it for repair... It sounds like the Y-sus board and the upper and lower Y-drives... This unit uses the same panels as the Philips 42pf7320a so it shouldn't be that expensive for parts...
I wouldn't personally send it to Dell - instead look through the NESDA web site and locate a repair center near you and take the unit to them for an estimate.
Bill
Jun 11, 2008 | Dell W4201C 42 in. Plasma HDTV
31'sanyo tv analog has a white horizonal line thru it
There is a failure in the vertical amp section. This can be the main output IC, or any of the support components in this area.
An experienced tech can troubleshoot the set, and determine and service the fault.
Jerry G.
Apr 27, 2008 | Sanyo DS31590 31" TV
Dell W4201C 42 in. Plasma HDTV Logo
176 people viewed this question
Top Dell Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Dell Televison and Video Expert? Answer questions, earn points and help others
