Question about Acer TravelMate 803LMi Notebook
Acer 3000 Will Not start
I was surfing the net when all of a sudden, the laptop just cut off. When I push the power button nothing happens. I unplug the ac adapter and try starting it battery only and nothing happens. I plug in the ac adapter and remove the battery and try to start it and nothing happen. I notice when the ac adapter is plugged into the wall only(not plugged into the laptop) there is a solid green light on the ac adapter. When I plug in into the laptop the ac adapter just blinks that with and without the battery.
I am looking for any and all solutions / tips to troubleshoot this issue.
Thanks in advance for anyone post to this issue.
Baysmax
    Master:
  • 461 Answers
From what you've described so far, it appears the motherboard has failed. Additionally you can remove any other components you can easily access such as hard drive, optical drive, memory and any cards. If there is no change with all components removed then it is most likely the motherboard.
Posted on Jan 28, 2009
Acer AM1100-E1304a do not start.
Try removing the battery. It may be the battery is eating all the power that the supply can produce, leaving nothing to run the computer. That could happen with a shorted cell or a completely dead battery. IF the power supply you are using is the correct one for your laptop.
Oct 27, 2014 | Computers & Internet
Okay, so I have an acer aspire 5335-2257. I've had it about two years now with no problems till today. It started cutting off for no reason and I had to reboot it each time. When it came back on it said...
Thanks for posting your problem in fixya.
I want to verify if you have tried turning on the laptop by just using the ac adapter without the battery on it. If it powers the computer, then it's battery which has a problem on it. Batteries usually die after two 2 years of usage. If using the ac adapter alone powers up the laptop then I suggest you buy a replacement battery for your laptop.
I hope this helps.
Jan 31, 2011 | Acer Computers & Internet
My Acer went into hibernation in the middle of
You can try this ... you probalby already have ...
Unplug the external power. Remove the battery. Come back tomorrow. Put the battery in. Reconnect the external power. Come back the next day. Give it a try.
If you are still under warranty, Acer has a pretty good Chat Support program. Give them a try.
Thanks for your interest in FixYa.com
Feb 05, 2010 | Acer Aspire One Netbook 8.9" Notebook
Acer Aspire One Zg5 will not boot up no indicator light come one
Hi there.
Try taking the battery out and booting it on AC power only, if it boots up turn it back off and reinsert the battery, turn the computer on, if it boots up all good, if not please post back.
Good luck
May 21, 2009 | Acer Aspire 5100 Notebook
Am trying to boot my laptop, its has a vista OS but i plugged in to the power and press the power button but nothing happens, what could be the problem
I removed the battery, plug in to the power, it boots and then after 5 minutes, unplugged from the power, put back the battery and plugged in to the power then power on and it boots. i activated my window vista through internet and now am comfortable.
posted by,
EdwinKairu. Kenya.
Dec 29, 2008 | Acer Aspire 3000 Notebook
I have a brand new acer aspire one. A moment ago, when I wanted to open it, I saw that the green light on its top right, that is, at its "start" button was on, and the battery was a bit displaced at one...
Most likely your laptop is going into sleep mode. Lots of them do not like sleep mode if nothing happens when you push the power button try to hold it down for about 5 sec. your computer should power off and then you can start as normal. If this problem persists change the options in your control panel to turn sleep mode off. That should solve it.
Dec 18, 2008 | Computers & Internet
Acer 5580: No lights, No turn on, no power up.
restart u r laptop and press f8 button when u r laptop start in starting press f8 and then restore u r system and again install u r driver after uninstalling
Oct 18, 2008 | Acer Aspire 5580 Notebook
Completely dead
Check the power adapter connection or the socket. Recently my power adapter socket gave me the same problem. When I check from the adapter using voltmeter it's seems to be working.
But when i plugged it in the laptop, nothing happens. So I google around for help and found this tutorial after following the suggestions I managed to revive my notebook.
Mar 20, 2008 | Acer Aspire 3000 Notebook
Acer Aspire 3000 Power Issues
In this case myself assume that your acer do a problem in the memory, try remove and clean the memory.
1. boot your acer without the memory. hear beep? if yes,
Only memory has a problem, if no, then;
examine the mainboard of your acer.
If you can hear a beep then fix back the memory and start the system.
if this not solve the problem, replace the memory.
In case that it hard for you to open the laptop let the repairman do it for you so that all your problem will be examine.
Jan 22, 2008 | Acer Aspire 3000 Notebook
Acer TravelMate 803LMi Notebook Logo
111 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
