Question about Encore ENHWI-2AN34D Wireless N300 3-in-1 Router & Repeater & Access
Is the Encore N300 Extender compatible with a Linksys Router? We can't get the Extender to connect with our wireless network
We can set up the Encore device by using the wizard, but when we select the Wireless Extender mode and find our network, it will act as if it is connected, but it doesn't boost the signal at all
kakee
  • 1268 Answers
SOURCE: I have encore enhwi-n router;
You need to clone the MAC Address of the PC that can go online directly to the Smartbro connection. Make sure the connection is correct. Your PC should be connected to port 1 on the router and the ethernet from smartbro to WAN or Internet port.
Posted on Dec 19, 2008
  • 100 Answers
SOURCE: how can i put a connection password on my Encore IEEE 802.11g ?
go to -
Start -> Run -> type CMD and press enter
when the box opens type
IPCONFIG/ALL and press enter
scroll down to the header Connection and look for Default Gateway
Copy this number down - make sure you write it down correctly
now type exit and press enter
open your web browser and type that number into the address bar and press enter
this will take you to your routers setup
enter your password if prompted. if you never set one the defsult Name=ADMIN and default password=ADMIN. if this doesn't work you may have to reset your router by holding in the reset button for thirty seconds and reconnecting to with the same i.p. address you used before.
go to Authentication Security
you can choose WEP or WPA i strongly urge you to use WPA. WEP is a very weak security type
let me know
Posted on Dec 25, 2008
SOURCE: Encore ENUWI-G2 802.11G won't connect after installing SP2
Well, i had this same problem (it's specific to SP2, does not happen with SP1) and this is is the way i fixed it (I don't like it very much, but at least it worked):
1) Unistall Realtek USB Wireles LAN utility
2) Go to Control Panel -> System -> Hardware ->Device Manager->Universall serial Bus Controllers
then choose the one with the word "enhaced host controller" or similar (usually the last one), right clik->Disable
3) Install Realtek USB WLAN Utility and everything should work fine.
The problem (a quite annoying one) is that now your usb flash disks will work slower than it could. For small amount of data (<100M) it doesnt matter. When you have to work with huge data transfers to you USB you can enable the controller for the moment.
I know it's not the greatest solution ever but if it's your only way to get internet connection it worths a try.
Best Regards,
Luciano
Posted on Mar 11, 2009
  • 114 Answers
SOURCE: I have Wimax wireless internet and I connected a
You can the CD that came along with the Wimax, if there is. it will teach you how.
If not, you can look for the IP in the manual which you will encode in the address of your browser so you can enter the Wimax configuration.
There you will find options on how to have security on you router.
If there is a manual it will help you a lot on how to configure it.
Posted on Apr 03, 2009
  • 96 Answers
SOURCE: Problem with Encore 802.11n Wireless Router ENHWI-N2
Are you able to access internet when you are connected with a cable netween your laptop/desktop and router please check if yes then with the same connection go to http://192.168.1.1 default username admin and password "admin" and then check in the wireless tab is there any security on the wireless the same code needs to be entered on the laptop also in wirless network connections
Or the issue can be conenctivity between your service provider and router you may need to do some settings as per your service provider on the router for that again you need to open the 192.168.. page
let me know if this help, the below link will help you to check your connection once by one
Posted on Dec 01, 2009
I want change my liksys roter password E900.can any help me please My no is 0506327008
Please click EDIT and remove your phone number. No one here phones anyone except the 'crazies' who are tuning in!
All the information is online. videos in the main link at the bottom.
  • Linksys E900 Default Password - About.com Tech pcsupport.about.com > ... > Linksys Default Passwords 2016-04-07 · Find the Linksys E900 default password, ... your Linksys E900 (N300) router. ... on the bottom of the router. Be sure to change the default router ...
  • Linksys: Changing the Wireless Network Password for Your ... kb.linksys.com/Linksys/GetArticle.aspx?docid=67993c06bf0c4b1f... We would like to show you a description here but the site won't allow us.
  • Linksys Official Support - E900 Frequently Asked Questions www.linksys.com > Home > Support E900 Frequently Asked Questions. ... Username and Password of the Linksys Wi-Fi Router, E900? ... so you do NOT have to call your ISP to change the registered MAC ...
  • Linksys Official Support - Linksys E900 N300 Wireless Router www.linksys.com > Home > Support Linksys E900 N300 Wireless Router ... Login & Password. Changing the router's wireless network name and password using ... Changing the Linksys router's ...
  • Linksys Official Support - Changing the router's wireless ... www.linksys.com > Home > Support ... E1550, E1700, E2000, E2100L, E2500, E3000, E3200, E4200 v1, E800, E8350, E900, ... Linksys router name or password. ... change your wireless network's password ...
  • Linksys E-Series Routers User Guide downloads.linksys.com/.../E_Series_UG_E900Rev_3425-01486_Web.pdf · PDF file Linksys E900 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . ... How to change your router's name and password . . . . . . .
  • Solved: Linksys E900 router - Page 2 - Linksys Community
  • Go to Bing homepage
    Jul 10, 2016 | Cell Phones
    How do I set up a Belkin N300 model F9K1015 V1 range extender?
    Its very easy just follow these steps-
    1. Restart Your Modem First than Restart your Router And Extender
    2. Please Your Extender With in 30-35 Yards Of Your Main Wireless Router .
    3. Make Sure All Lights Are Blinking On Router And You Have Internet to your Router
    4. Try Connecting The Extender Again See if That Works
    For more details kindly visit
    Belkin Range Extender Won Connect to Internet Belkin Range
    Good luck.......
    Mar 01, 2015 | Belkin Computers & Internet
    Why doesn&#39;t my netgear extender ask for name and password when I try to use it to connect to internet. It tells me that there is an authentication problem
    Hi there! smile.gif Please note that the Tenda 150mbps Wireless Range Extender A3 uses a default IP address of 192.168.0.254 - you must set your IP address to the 192.168.0.* range (* = any number between 2 and 253) to login.
    The default access username / password (if required) are admin and admin.
    Once you've logged in, you can configure the access point to route through your existing wireless router as the default gateway (eg. if your wifi router is 192.168.1.1, then you would route through that, and set your Repeater (Extender) IP to 192.168.1.2 so that you can connect to it and then "relay" your connection through the repeater. It doesn't mirror the connection details for the existing wifi router, it simply creates an "additional" access point to connect through to your existing wifi router - creating a bridge, essentially.
    The extender can be linked to the existing wifi router via LAN cable or WDS. For WDS, you will need to set the IP's 1 digit apart in the last segment (see above IP difference), and switch them both in the Wireless menu to ""Wireless Networking Mode: Network Bridge (WDS), but the SSID must remain the same (eg. "Tenda1") for both of them (it doesn't cause a network loopback), and any wireless security authentication must be identical (password / pass phrase / key + encryption algorithm) on both devices. Again, as with the above point, remember to set the gateway of the extender / repeater to that of the primary WiFi router.
    For extra information and disambiguation (if required), see the following page, and scroll down: http://www.enjoypad.com/wireless-access-point/96-tenda-...
    Oct 26, 2014 | NetGear N300 Essentials Edition Wi-Fi...
    Mywifiext login
    Do you have the range extender set up on the same live in the fuse box? If you have the one side on a breaker on the opposite side of the fuse box from the othrr side, it will not work well at all. That is why I encourage people not to waste their money on these things and get a decent wireless system so that you dont have problems.
    Aug 19, 2014 | NetGear N300 Wireless Router
    Can I move my n300 range extender once I've completed the setup? I need to plug it into an outlet closer to my patio. How do I do that?
    After it is configured you can move it to any outlet as long as it can still connect wireless to your router. It saves the configuration.
    Jul 04, 2014 | Linksys N300 Dual-Band Wireless Range...
    How to hookup N300 wireless extender
    You should just have to plug the N300 into a wall outlet, and plug an ethernet cable into the ethernet/network port. Access the N300 by typing 192.168.1.1 into your web browser's address bar to access the N300. It has been a while since I set one up, but if I recall correctly it should just ask you to choose the wireless network taht you want to repeat, select your home network and enter the password for it and save settings.
    Feb 20, 2013 | Linksys Wireless-N WRT150N Router
    Wireless g range extender
    Hi there ....
    before anything else, can you please what is the version of range expander is is wre54g v1,v2,v3?
    1) either which, please do verify your wireless settings of your DLINK router
    -- the network name or ssid
    -- security if you enabled any on your router
    -- wireless channel
    -- please check the default gateway of your router if it is 192.168.1.1
    ** please take note also that the best location for your expander would be inbetween your router and your computers
    2) once you have gathered the wireless settings
    -- you would need to manually configure your expander coz it didnt work .. Please remember that the LINKsys expander is designed to work with linksys routers, so it may or may not work.. I just need to set your expectations on this ...
    3) once you have verfied the default gateway of your DLink router ... please reply to this thread and let us proceed in configuring your wre...
    Thanks and good luck!
    Oct 31, 2008 | Linksys : WRE54G Wireless Range Extender...
    Encore ENHWI-2AN34D Wireless N300 3-in-1 Router & Repeater & Access Logo
    52 people viewed this question
    Top Encore Computers & Internet Experts
    Prashant M
    Prashant M
    Are you an Encore Computer and Internet Expert? Answer questions, earn points and help others
