DG-HD8040 program is paused on channel 9 .I am unable to change the channel. Remote not working at all .I havechecked the batteries.
Problem started when I changed from 7 to 9 and for a short period continued to receive sound from 7 while picture was 9. It has now stuck on 9 in paused without sound.
  • 3,904 Answers
Try unplugging everything for 30 seconds and plugging back in. This should reset everything.
Posted on Jan 23, 2013
techman
  • 3130 Answers
SOURCE: Receiver not taking commands from the remote
Point the remote at a digital video camera to see if you can see the small blue infared light comming from the end of the remote when you aim it at the camera and press a button. if you do see the light then your receiver has a system control problem I'm afraid. You see your eyes cannot see the infared light but the camera optics can. Good Luck
Posted on Jun 07, 2007
  • 6 Answers
SOURCE: Can't view picture, but can hear sound
Are you trying to record TV signal onto a DVD, or are you playing back? What make & model is your TV and DVD player/recorder?
Posted on Dec 10, 2007
  • 6 Answers
SOURCE: Onkyo 605 loss of audio on HD channels only
on your directv box, go to menu, setup, setup again, then audio, then dolby digital on the right and turn it on. assuming you have an optical audio cable from your sat box to your onkyo.
Posted on Apr 27, 2009
smarthome2
  • 1114 Answers
SOURCE: Loose sound when changing channels
If your using HDMI. The HDMI technology in version 1.1 & 1.2 was riddled with problems. Check your owners manual for version.Or, try the Coaxial Digital or optical output from your sat receiver to your Yamaha receiver, go into "GUI" "Menu" not sure which on the HTR series and Lock the audio input to Coaxial or Optical on CBL/SAT. Then Test. If it still has issues, check the settings for Audio on the SAT receiver and make sure they are correct. If you still have a problem, use a standard RCA from the sat receiver to the Yamaha. At this point audio should be rock solid on analog. Look on the back of your DSS receiver for the model # & write it down. Then go into the units menu "SAT" and check it's firmware version for version and date. It may need an update. Go to your Sat's website, Directv or Dishnetwork and go to support, enter model # and look for any updates that may apply. Hope this helps
Posted on Jun 11, 2009
SOURCE: While wathching TV, the typical volume level
Cleared all AV settings and reprogrammed.
Posted on Jan 31, 2010
I'm using a Time Warner remote as a universal for my TV but when I go to change channels, it just lights up the CBL button and doesn't change the channel. Can I program it to my TV or will it
Hi, you need to de-activate the "programming channel control lock" option. You can see instructions in the manual for the remote. They are as follows:
  1. On the remote control, press CBL once; It will blink once, Press and hold SETUP until the CBL key blinks twice.
  2. Enter 9 7 3. The CBL key will blink twice.
  3. Press CH- once. The CBL key will blink four times.
    Now the remote control will provide TV and VCR channel-control capabilities while in the TV mode.
for any other information with programming this remote:
Download the 1056B01 operating manual with codes for free.
Nov 30, 2012 | Televison & Video
My television set is stuck on one channel....the audio changes with the channel but the picture stays blurred on one channel...whats wrong with it?
Lots of possibilities. If you are using the remote, try also using buttons on the TV to change channels. If TV buttons work, the remote is broken or perhaps try changing batteries and cleaning battery contacts on the remote. If neither work, lots of other things to try. You may need to set preselect channels, so your TV thinks there is only one channel out there until you do. If you are on a cable box you just need channel 3 and change channels on the cable box. I can't tell what you mean by "audio changes with the channel" ... if you mean that when you try to advance channels, it increases volume and moving down in channels lowers volume that would be strange -- if you are using a programable remote it might not be set correctly (try another programming code). The "blurred" picture is probably symptomatic of having the set on the wrong channel, and if you could set channel it might clear up ... I'd start with getting channels to change. If you need more help, give the brand and model of TV, say if you are using a remote (original or programable), and what the 'audio changes' comment means in more detail. Probably worst case is that your tuner circuit is fried, but don't assume that without more diagnostic.
Aug 29, 2011 | Televison & Video
TV is on one channel and will not work with remote or allow me to change channells from side of tv
I've run into this same issue. Although not a complete fix, I was able to program the tv with a basic universal remote. Try using the Goldstar remote codes. While I'm unable to use the channel buttons, I can change channels manually and turn the tv on/off and use the volume button. Again, not a fix, but a work around for now.
Jun 25, 2011 | Element Electronics FLX2211B 22 in. LCD TV
I am unable to go to menu on my televsion.
Some universal remotes do not correctly handle the features of the original remote. You can get an exact duplicate remote from remotes.com: http://www.remotes.com/remotes/servlet/rs?a=Search&o=c&uid=0&m=6509DD&uuid=12709186471510
Alternatively, get one of the higher end programmable remotes. The ones programmed from your computer are more likely to be trainable to do all the features of your original remot.
I hope this helps.
Apr 10, 2010 | Sylvania 6509DD 9 in. TV/DVD Combo
I need help finding the code for my tv. i have a Philmore universal remote pm-rc13. My t.v is a white-westinghouse
Here is the code for your TV 0154 along with the advanced codes.
Advanced Codes for TV_0154TVs ------------------ <TV Group>
0154 244 ACM 165 Fine Tune Up 251 SAP 167 Surround Mute
244 Auto Chroma 244 MTC 231 Speaker In 168 Surround Vol dwn
251 Bilngual 234 PIP Location 233 Speaker Out 164 Surround Vol up
169 Fine Tune Do 228 PIP Select 247 Stereo 129 Component 2 (discrete)
TELEVISION. Uses with:
TUNER/CD/TAPE/PHONO/AMP..CDs................AUX2 088
TELEVISION...............TVs..................TV 154
VCR......................VCRs................VCR 047
VCR......................VCRs................VCR 104
On some models,
100|AM/PM|1-- may be 100/Enter;
Func|Sel may be Digicon;
Level Up|R may be Control Right, Level Up/Minute or Menu Up;
Level Dn|L may be Control Left, Level Dn/Hour or Menu Down;
Review|Qck View may be CH Recall or Quick View;
SetTime Fast may be Stereo Matrix;
SetTime Slow may be Time/Day, Set Up, Clear or Menu;
TV/Video/AV may be TV/AV, Video Mode, Input or A/V;
Wide|TV|Loud may be Stereo Matrix, Surround or Mode;
MTC|OBC|Auto may be ACM or Auto Chroma.
181 0...............0 185 1...............1
120 ENTER...........1-- 120 ENTER...........100
183 2...............2 187 3...............3
180 4...............4 184 5...............5
182 6...............6 186 7...............7
053 8...............8 057 9...............9
185 1...............A 123 A/B.............A/V
120 ENTER...........AM/PM 059 CHANNEL DOWN....AM/PM
183 2...............B 187 3...............C
249 RECALL..........CH Recall 059 CHANNEL DOWN....Channel Down
055 CHANNEL UP......Channel Up 122 PROGRAM.........Clear
250 STOP............Control Left 246 PLAY............Control Right
250 STOP............Cursor Down 059 CHANNEL DOWN....Cursor Left
055 CHANNEL UP......Cursor Right 246 PLAY............Cursor Up
180 4...............D 055 CHANNEL UP......Day
184 5...............E 120 ENTER...........Enter
182 6...............F 121 SHIFT STOP......Fine Tune Dwn
117 SHIFT PLAY......Fine Tune Up 248 PAUSE...........Function
186 7...............G 053 8...............H
250 STOP............Hour 057 9...............I
123 A/B.............Input 181 0...............J
059 CHANNEL DOWN....K 250 STOP............Level Down
246 PLAY............Level Up 122 PROGRAM.........Menu
250 STOP............Menu Down 246 PLAY............Menu Up
246 PLAY............Minute 116 SHIFT PAUSE.....Mode
245 MUTE............Mute 230 SHIFT FFD.......PIP Freeze
235 FAST FORWAARD...PIP On/Off 232 SHIFT REW.......PIP Replace
119 POWER...........Power 052 DISPLAY.........Recall
249 RECALL..........Review 248 PAUSE...........Select
122 PROGRAM.........Set Up 118 REWIND..........SetTime Fast
122 PROGRAM.........SetTime Slow 056 SLEEP...........Sleep
116 SHIFT PAUSE.....Stereo Matrix 118 REWIND..........Stereo Matrix
116 SHIFT PAUSE.....Surround 122 PROGRAM.........Time/Day
056 SLEEP...........Timer 181 0...............Timer Set
056 SLEEP...........Timer Start 116 SHIFT PAUSE.....TV
123 A/B.............TV/AV 123 A/B.............Video Mode
058 VOLUME DOWN.....Volume Down 054 VOLUME UP.......Volume Up
116 SHIFT PAUSE.....Wide
Hope this helps. Let me know if I can help you with anything else.
JimmyC
Sep 29, 2009 | Televison & Video
I have a phillips universal remote and I need the code that matches to a Liteon dvd player and recorder. Model LVW-1101HC1
The codes that I have are for the LVW-1101 ( and possibly 1105). The remote responds to the JVC remote code [0623] but the individual command buttons are scrambled and need to be programmed in-unless you have the remote w/ learning):
266-play 286-TV (as source)
292-Fast Rewind 296-Cursor Rt.
301-Fast Forward 304-Record
316-1 325-7
326-Cursor/Channel Up 328-Timer
329-0 330-Menu
364-Setup 365-Select
367-Stop 368-Previous Track
369-Cursor/Channel Down 385 Commercial Skip
389-Source 390-Next Track
413-Cursor Left 416-Display
417-2 420-Open/Close
421-3 427-4
431-Top Menu 433-Navigate Menu
452-5 453-Easy Guider
454-9 455-Power
459-6 462-Tools
474-8 479-Pause/Step
500-Channel Editor
Finding the codes is not hard-just tedious.
Aug 18, 2009 | Televison & Video
I AM UNABLE TO CHANGE CHANNELS USING RMT D175A PLEASE HELP
Is this the first time you've tried using this remote with your TV or has this problem just started?
If it's a recent problem, be sure you put FRESH BATTERIES in it. Some remotes will forget everything if the batteries are weak.
Then, try this site:
http://esupport.sony.com/perl/model-remote.pl?mdl=RMTD175A
You can enter your TV brand and it should walk you through re-programming your remote.
Jul 08, 2009 | Televison & Video
Can not change TV channel on DVD Recorder.
some dvd/vhs tuners do have this locked issue and since poor qc or qa on the manuf. part , they think since items are low cost anyways buy another one.
Mar 27, 2008 | Sony RDR-VX530 DVD Recorder/VCR
Quasar vhq41m
Hi , set remote to auto program set enter /on sreeen will appera then stop if no channel appear ,then select channel.
Jan 21, 2008 | Quasar VHQ400 VHS VCR
65 people viewed this question
 Grubhead
Grubhead
