Question about Sanyo HT30744 TV
No color on one channel
There is no color on one channel, i know it is not the channel because i checked it on another tv. what could cause this?
    Genius:
  • Sanyo Master
  • 1,690 Answers
Some models of TV's can remember the user settings for each channel programed. Go in to the user menu for the video setup and see if the colour (chroma) is turned down.
Jerry G.
Posted on Apr 19, 2008
FIX THE COLOR, IT HAS A GREEN TINT THAT DOESN'T GO AWAY WHEN TRYING TO ADJUST COLORS FOR DISPLAY DON'T KNOW WHAT CAUSED IT
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Jan 19, 2015 | Sony BRAVIA KDL-40EX523 40" LED TV...
Colored bars on Sony Bravia LCD Digital Color TV Screen
This is a screen tab fault and in most cases will require the screen replacing
Sep 13, 2017 | Sony Bravia KDL-40S4100 40 in. LCD TV
Black and White Channel
Check the fine tuning for that channel.Adjust + or - accordingly, see what happens?
Oct 02, 2009 | Apex Digital AT2708S 27" TV
No blue color on tv screen
Your welcome ! please comment. Thank you !
May 01, 2009 | Samsung SlimFit TX-S3082WH 30" TV
Have an RCA console, color, 26" screen. Over 30 years old. Hooked up to cable and DVD player. Overnight the color disappeared and reception is black and white. Did color guns go out?
If you can see white, then all the CRTs are functioning. Make sure that the channel is set correctly. If the DVD is sending out channel 3 and the TV is set to channel 4, you will see the picture, but in B&W, Check that first. Let me know if that does not resolve it.
Thanks,
Dan
Mar 06, 2009 | RCA Televison & Video
Rainbow screen then powers off
The degausser cricuit may be the fault. The degausser coil may be staying on, and thus forces a shut-down. It is also possible to have a power supply fault that can cause a similair effect.
The set will need shop service.
Jerry G.
Jul 22, 2008 | RCA TruFlat 27F520T 27" TV
Sony tv only loses color on digital cable premium channels
yes it is your tv since the tech ruled out the cable box.
1.possiable bad tv tuner cost of repair is 120.00
2, picture tube causes this sometimes but rear to be tube.
3.I would call a local tv shop and have them come out to look at find out how much they charge for road calls .
4.I like sony tvs i would keep your price around 225.00 for complete fix max
Thanks doctor video
May 11, 2008 | Sony KV-27S15 27" TV
Picture color
have JVC AV-32F702 TV. It's picture color is very red. unable to adjust colors through menu. Channel numbers are also in red now instead of normal green. any suggestion? please check red color cathode circuit 1 check red output from ic to red cathode ckt 2 check voltage on r output ckt& ic or tr. 3 check loose contact in red cathode ckt 4 check crt base for loose. 5 loose connector 6 chroma ic thanks
Sep 09, 2007 | JVC AV-32F702 32" TV
HELP! MY 42" PLASMA TV IS ONLY GETTING BLACK AND WHITE CHANNELS.
If you are connected to a HD cale box using component cables IE (G, R & B) then check if either the Red or the Blue has come loose or unplugged as this will cause most HD sets to revert to a black and white picture.
May 03, 2007 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Multiple problems, hoping for one solution
sounds like it is probably worth trying to degauss check this excellent site; http://woil.ws/fixmonitor/ for details of how to try this on the cheap - it works If it doesnt solve your problem, the fact that you are getting different quality from different crt s suggests that they could be the root cause - see if you can get the part number, and get a price you may find it is cheap enough to be worth trying - check also the power supply - poor voltage output can sometimes cause these type of symptoms. Hope this helps, if not post again - some of the other guys know tvs much better than me :)
Mar 08, 2007 | Sony KP-53S65 53" Rear Projection...
Open Questions:
Sanyo HT30744 TV Logo
66 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
