Question about Garden
I have a older jiffy I have gas that comes out of the muffler is that a carb problem.
  • 2,239 Answers
Could well be the needle valve leaking in the carb, or if you have been cranking the engine for some time and it has not started this will also pull fuel into the engine and blow out of the muffler, a pressure test of the carb will quickly tell you if the needle is leaking.
Posted on Jan 24, 2013
Carb full of gas
sounds like the float is sticking inside the carberator might need new needle and seat as wel as a float check to see if float is gas logged
Jul 06, 2012 | Parks Optical 13.5hp Briggs And Stratton...
My weed eater sounds like its ready to die, looses power runs like it ca,nt get eithr gas or air
if it's an older unit start with pulling the muffler and cleaning exhaust port and spark arrestor. while muffler is off sta.rt the unit and check for improvement. if no improvement clean & adjust carb. if improved with no muffler, test again with muffler installed. if unit goes back to running poor replace muffler.
Jul 12, 2011 | Stihl Ts 510 760 Cut Off Saw Repair...
My toro gas trimmer does not produce enugh power. when squeez for more gas it will stall. It will restart ok, but won't give power. squeee more gas and stal.
You haven't said how old this unit is. Older units sometimes face carbon build up in the engine and muffler. Maybe pull the muffler off and see if the exhaust port of the engine has buildup of carbon and the spark arresting screen in between them is clogged? If it is, clean it and inspect the muffler for clogging too. The muffler can be soaked in a solvent of your choice to loosen and break up carbon accumulation. Other than that, the carburetor may just need an adjustment. Many carbs dont't always function well in the climate they are used in as the initital set up of the carb is a "standard" setting that is mandated at the factory. See if you can adjust it. Here is a tutorial for a typical 2-stoke carburetor, assuming that is what this machine has.
http://www.zamacarb.com/tipspage.html
Mar 20, 2011 | Toro& Electric String Trimmer
Jiffy ice auger won't start if cold.
I
Hello. I'm kind of "out on a limb " here but my older chain saws and my Jiffy auger's the same. I use the highest octain fuel I can get (at the pump) and I think it helps. These old motors were made to run on real gas.
builderdale
Jan 08, 2010 | Omega Eskimo 39 In Ice Fishing Auger 8 In...
I have a Stihl BG55 Blower Gas comes out of muffler.
you have a piece of trash/debris under the inlet needle of the carb and or a welch plug has come out, ive seen this many times on zama carbs, if its within warranty bring it back to your service center for a new carburetor.
Nov 18, 2009 | Garden
Won't start. Has compression. backfiring through
On many riding mowers there are two wires that at the bottom of the carb bowl, these wires go to a solenoid which closes a valve so gas will shut-off when the start key is turned off. When this solenoid is bad it will not close which let gas keep going to the carb so the eng will bang through the carb or muffer. Hope that this will Help. Hugh Lyon
Jul 30, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Replaced gas line and primer bulb. cleaned carb, but not sure which direction the diaphram goes in. Machine idles but spits gas from top of carb and dies when throttle is pushed. Gas line routing? Seems...
If the engine dies when you try to speed it up chances are your muffler is the problem. Any equipment that uses a gas/oil will eventually have a stopped up muffler due to carbon buildup. This restricts the air flow and the engine won't run or open up. First take the muffler off and see if you can start and adjust the carb with it off. Turn both the air and the gas adjustment screws all the way in, then back them both out one and a quarter turns. Start from there.
Unstop the muffler by throwing it in an open fire for 10 to 15 mins or using a torch to burn the carbon out. There is a screen in the muffler that I would toss out (unless you live in California) for the only purpose it serves is catching carbon. Let the muffler cool on its own, don't cool with water or you will warp it and it won't seal right. Also while the muffler is off check the muffler port and scrape off any buildup there with a knife. Hope this helps.
Jun 18, 2009 | Ryobi Cultivator
Slow starting tiller
Anytime an engine uses a gas/oil mix there is a possibility that the carbon this mix produces clogs the muffler making air flow next to impossible. First check to see if it will run better without the muffler. If it does you will need to clean the muffler by removing it and burning the carbon out with a torch. If this isn't the problem, then it may by your carb. Remove it, clean well with carb cleaner, replace the diaphragm if needed for as the diaphragm gets older it becomes stiff and will not pump the gas to the engine. When you reinstall the carb, turn the adjustment screws all the way in and the one and a quarter turns out to start with, making further adjustments from there after it starts. Hopefully one of these is your solution.
Jun 17, 2009 | Garden
Homelite zip start 2cycle trimmer.
I had this same problem, would run a couple of seconds, stop, and you couldn't start it again.
Had good gas/oil mix 50:1 and 25cc Homelite. Had replaced the fuel filter, gas, spark plug, and took carb apart and cleaned with carb cleaner and primer bulb worked fine. None of that fixed it. What did? Take the muffler off and see if it will start and run with the muffler off. If it does, chances are the muffler is clogged. Also check the exhaust ports and clean them out if plugged with black oil carbon residue.
My muffler was clogged up, took it off, cleaned out the exhaust ports, there was some oil that was in the muffler(oil that didn't burn during combustion). It now starts and runs like a champ on first or second pull.
Mar 27, 2009 | Homelite Mighty Lite Lawn Trimmer
Garden Logo
26 people viewed this question
Top Garden Experts
Jay Finke
Jay Finke
Dennis Key
Dennis Key
john h
