Question about Dryers
My Frigidaire Gallery electric dryer, model number GLEH1642050 won't heat
Won't heat
thaurfen
  • 623 Answers
SOURCE: Dryer not heating
  • There are two house circuits/fuses in an electric dryer's circuit.
    If one of them is tripped/blown, the drum may turn, but the heater will not operate. Reset the circuit breaker or replace the house fuse.
  • Outlet wired incorrectly.
    Have a qualified electrician verify that the supply voltage is correct.
  • Gas supply valve to a gas dryer is not open.
    Open the gas supply valve. See Installation Instructions for details.
  • LP gas supply tank is empty or there has been a utility interruption of natural gas.
    Refill or replace the LP tank. Call your natural gas utility company.
  • Dryer does not have enough air supply to support the gas burner.
    The dryer needs space around it for proper ventilation. Do not stack or place laundry or throw rugs against the front or back of the dryer. See Installation Instructions for details about installing a dryer in a closet or alcove.
  • Incorrect cycle or temperature has been selected.
    If the Air Fluff cycle or temperature is selected, the dryer will tumble without heat. Each cycle ends with a Cool Down period during which the load tumbles without heat. Check the location of the indicator on the Cycle Selector knob.
Posted on Jan 08, 2009
  • 16 Answers
SOURCE: My Frigidaire Gallery front loading
Check to make sure you have 220V. Make sure you have no blockage of air flow (lit glogged up). Unplug dryer, Check your thermostats. If they are good check your heating element and take it out and visually inspect it.
Posted on Jan 09, 2009
TheMobilian
  • 8220 Answers
SOURCE: no heat
You gotta pop the top and remove the front which is very easy. Access the idler and remove the belt and get the tub out.. Here is a quick guide
Posted on Jun 09, 2009
SOURCE: My Frigidaire Gallery Dryer, model
dryewr is not getting hot
Posted on Aug 17, 2010
SOURCE: I have a Frigidaire Gallery Electric Dryer Model #GLER642AS3
The identification label from a Frigidaire Gallery Commercial Heavy Duty Moisture Sensor drier has come off. I need to download operating/user manual. How can I get the serial no. or model no. The drier is 4 years old.
Posted on Jan 17, 2011
Model #ALFRIGLEGLIS152ES Frigidaire gallery series won't heat. It stays on for a while and sometimes cuts off. When you set the time on it and press start all the lights start blinking on the o
Hi Robert Burch - From what you have described the unit could possibly have a communication problem with the control panel. However, if the unit is not producing any heat please have a professional diagnose the heating element and the blower assembly as well. Either, or, could be faulty at this time. This is not a typical DIY job so please consult a professional.
Oct 12, 2012 | Frigidaire Electric Dryer
My dryer is tumbling & blowing & all the cycles seem to work but it won't heat.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 04, 2011 | Frigidaire AEQ8000FG Dryer
Frigidaire gallery series electric dryer/washer. Dryer won't start
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 10, 2011 | Frigidaire Dryers
The dryer won't stop running & will not heat
heatman101
Jul 28, 2011 | Frigidaire AEQ6000ES Electric Dryer
Hello, I have just purchased a frigidaire gallery series stackable combo 2004 model glet1142cso after hooking it up i am having problems. It won't fill unless dryer door is open..won't spin out...
Probably an auto tec installed the recepticle on the wall or in the electric pannel. in home electric the black wire and the red wires are hot. In automobiles the black is ground. You should have 240 volts between the two flat connectors on the plug when its pluged into the recepticle.
Dec 20, 2017 | Frigidaire FEX831F Top Load Stacked Washer...
Frigidaire gas dryer, gallery series model GLGQ2152ESO - no heat,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jul 27, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
Frigidare gallery not heating. possibly heating element is gone out how hard is it to replace
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jul 01, 2010 | Frigidaire FER231A Electric Dryer
Frigidaire gallery model # GLG0642AS4 won't
If you have a gas dryer...
If your dryer is electric..
heatman101
Apr 15, 2010 | Frigidaire FGQ332ES Gas Dryer
Gas Dryer blowing cool air and will not heat up.
Look inside door and get the model number for me. Could be igniter, gas solenoids or temp control switch inside. Let me know, Thanks Sea Breeze
Mar 19, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Dryers Logo
37 people viewed this question
Top Dryers Experts
