Question about Garden
Why is oil coming out the side of my pump, I just changed the oil and it started doing this? I own a Porter Cable 4,000 PSI.
Please tell me some things it could be. Can I put a stop leak additive in the pump itself to stop oil from coming out. It leaks when machine is on. I still have good pressure. This leaking just started when I changed oil. Can I put a thicker oil so it won't leak?
  • 885 Answers
You didn't state your model number so I don't know exactly which type pump you have. With that; there is no 'oil pressure' in power washer pumps. The internal parts work in an oil bath/splash environment and the pump body is vented, usually at the oil fill cap. Thicker oils and stop leak will only mask the problem and make the pump work harder. Where the oil is coming out is key to the problem. Clean the pump well with something like dish soap to remove all excess oil to find exactly where it's leaking. If it's leaking at a part joint, like the pump body to the valve body or at a bolt, you may have a bad gasket or cracked part. If it's coming out the oil cap a likely cause is there is too much oil in the pump. When oil gets hot it expands and will find a way out. If you have an oil site glass, make sure the site glass is only half full of oil. If it has a dipstick, make sure you have the right dipstick and only fill it to the full mark. Most pressure pumps only need to be half full but that is dependent on your particular pump. If you have it consult your owner's manual. If you don't have the manual you can go to http://servicenet.dewalt.com, search for your model number and see if the manual is still available.
Posted on Jan 23, 2013
  • 1 more comment
  • Michael Longway Jan 23, 2013
    My model # is PCK4040SP. I have both a dip stick with 2 holes in it and an oil site glass. I think I have too much oil in it. I'm filling it almost to the 2nd eye of the dipstick. I will clean all oil off machine, run it, and then see where it leaks. I need to know how much oil to put in.
  • Repair Ahjoshe Jan 24, 2013
    The manual says to fill it with 18.54 oz of 30W non-detergent oil. Go by the site glass, that's your most accurate measurement. Fill until the oil level is half way up the site glass. If you want a copy of the manual, you can down load it athttp://servicenet.dewalt.com. Just search on your model number in the find parts box.
  • Michael Longway Jan 25, 2013
    Thank ou Very Much!!! I did all that you said concerning oil fill level & IT WORKED
Why does the safety valve go off before the pressure switch on a porter cable 80 gal air compressor
The maximum pressure on most small compressors is 10 bar or 1000kpa which is about 145 psi in the old language most safety valves are set to 150 psi. I suggest you get some one to reduce the pressure switch setting. Running a compressor at elevated pressures does not give you any more air. A reasonable pressure for small compressors is 120 psi
Jan 17, 2013 | Porter Cable C2002-WKR 150 PSI, 6 Gal....
My porter cable 200 psi air compressor will not run
The curcuit breaker on the motor. Probably a little round button that's about the size of a screw head.
Jan 04, 2013 | Porter Cable Air Tools & Compressors
Porter Cable pancake rated at 150 PSI stops at 135 PSI. It has done this since it was new.
If it's pumping up to 135 psi, shutting off and then restarts at the same pressure point since it was new, the pressure switch may have been set low at the factory. I don't know which model you have but most pressure switches have directions inside their cover as to how to adjust the cut-out and cut-in pressures. Be careful doing this, overpressuring the tank is dangerous. There is an adjustment screw or bolt that changes the pressure on the switch spring. Some pressure switches have two screws, one for cut-in and one for cut-out pressure. A few have one that adjust both pressures. If you do adjust the cut-in/cut-out levels, do it slowly and cycle the motor a couple times between each adjustment to see where it turns off and on. If the compressor is doing what you want it to, only pumping to 135 psi, it will live longer than if you adjust it up to 150 psi. Those last 15 psi of air are hard to get and will mean the motor will be running longer and more heat will be building up in the head.
Oct 01, 2012 | Porter Cable Air Tools & Compressors
Porter-cable compressor stops and restarts at about 60psi
You prolly have a leaky gasket in the main valve. Air is leaking and causeing it not to go about 60psi, you probably have it set to reach a high PSI but since the leak is not allowing it reach above 60 it keeps cycling trying to get above it
Aug 27, 2009 | Porter Cable C2002 Wk 150 Psi 6 Gal. Oil...
Trying to wire up my porter cabel cplc7060v for power
DeWalt is the new owner of PC contact your local servicenter for advice or to get the schematics.
Jun 29, 2009 | Porter Cable Cable 135 PSI, 60 Gal. Oil...
Won't start -Porter Cable Cable 135 PSI, 60 Gal compressor
ARE THE POINTS BURNT IN THE PRESSURE SWITCH? DO YOU HAVE A LEVER ON THE SWITCH SET TO ON OR AUTO? IF YOU THINK ITS THE SWITCH JUST BYPASS IT AND TIE THE WIRES TOGETHER TO SEE IF IT RUNS. BEWARE YOU HAVE NO PRESSURE PROTECTION EXCEPT POP-OFF VALVE. MOST P.O.S. COMPRESSORS LIKE PORTER CABLE HAVE 3500 RPM MOTORS AND HAVE A THERMAL RELEIF BUTTON ON THEM. JUST PUSH TO RESET. MAKE SURE YOUR WIRNG OR DROPCORD IS LARGE ENOUGH GAUGE. SMALL GAUGE DROPCORDS KILL COMPRESSORS.
Jan 17, 2009 | Porter Cable Cable 135 PSI, 60 Gal. Oil -...
Garden Logo
856 people viewed this question
Top Garden Experts
Jay Finke
Jay Finke
Dennis Key
Dennis Key
john h
