Question about Home
Replacement kitchen sink sprayer will not fit
Please help! The unit already had an old existing sprayer that was malfunctioning. The old one unscrewed from inside a fixture. The new is a different size and it appears to fit over not inward. Do I need to convert it or what converter do I need. There also a nut that I can take off but it still does not fit.
    President:
  • 2,692 Answers
It might be easier just to take the sprayer back and get the corrct brand to fit your faucet. The other option is to takke the two missmatched pieces to the hardwareor plumbing supply house and let them match us the transition fitting.
Posted on Jan 28, 2009
  • Thomas F. Schneider Jan 28, 2009
Fitting extensions to 1/4 turn taps
There is an air gap that is causing the problem. I had the same problem. Replace the sprayer. Try first cleaning the head of the sprayer by taking it apart.
Jan 22, 2013 | Grohe 32 999 KD0 Alira Pull-Out Spray...
Kohler a112.18.1 diverter will not spray
Generally the sprayer trigger assembly will unscrew from the hose. You can then point the hose toward the sink and turn on the
water. It should flow freely through the hose when either the hot or cold is on. Generally there is a aerator on the spray head. You can access it by unscrewing the tip of the sprayer assembly and clean out any mineral deposits. There may also be an inline type filter in the handle where it screws onto the hose that can be removed and cleaned. If this doesn't help I would guess the on-off triggering assembly is broken and you would have to replace the sprayer head.Hope this helps.
Jan 05, 2013 | Kohler Plumbing
How to replace a price pfister kitchen faucet sprayer
The sprayer should have a threaded fitting on the end of the hose. Unscrew old one from valve, pull hose out the top, feed new hose back down into cabinet and screw in to where old hose was attached.
Sep 23, 2012 | Price Pfister Pfister T26-4ypu Rustic...
I need a replacement handle, including all the parts and hoses, on my Price Pfister Marielle kitchen faucet model # T26-4NEE
Most new kitchen faucets feature single-handle control levers and washerless designs that rarely require maintenance. Additional features include brushed metallic finishes, detachable spray nozzles, or even push-button controls.Connect the faucet to hot and cold water lines with easy-to-install flexible supply tubes made-from vinyl or braided steel. If your faucet has a separate sprayer, install the sprayer first. Pull the sprayer hose through the sink opening and attach to the faucet body before installing the faucet.
Where local codes allow, use plastic tubes for drain hookups. A wide selection of extensions and angle fittings lets you easily plumb any sink configuration. Manufacturers offer kits that contain all the fittings needed for attaching a food disposer or dishwasher to the sink drain system.
Jul 26, 2012 | Price Pfister Marielle Kitchen Rustic...
How do I replace the flange on the side sprayer? The sprayer and hose are intact but the part of the flange that screws broke and has to be replaced. Quesiton is where do I disconnect the hose so I can...
The hose that goes to the Sprayer has to be disconnected under the sink at the main connection there, then it can be pulled up and out of the top of sink. the you can unscrew the nut under the sink on the flange and remove and replace.
Aug 28, 2011 | Price Pfister Marielle Kitchen Faucet with...
Have Kohler diverter, GP 75878 but no instructions as to how it should be installed. Is it under sink where sprayer hose is attached?
Shut off water supply Under Sink: · Unscrew brass connector for spayer hose · Disconnect single water line to faucet bysqweezing lever on connector and Gently pulloff. · Loosen two screws on faucet base washers thenunscrew the washers on thebrass faucet shaft ( NOTE: Have someone hold the fauct so it does Not accidentlyfall in sink when the support washers are removed) · Take faucet out of sink · Unscrew brass collar at base and remove · Remove Set Screw on lower body of faucet · Pull out Brass Mechanism from faucet · The Diverter is located in the Brass mechanism · Remove the Washer · Pull off the small top valve in center of theDiverter, if still there · Using a large wood screw that fits/screw intothe exposed hole In the center of The plasticdiverter, screw it in and pull out the remaing part of the old diverter · Flush out Faucet to remove any remaining debrie · Replace with new diverter and replace washer · Grease all areas that where greased when mechanismwas removed Remove & clean the faucet Airrater and replace only afterEVERYTHING has been Completed soyou can flush the faucet out again into the sink, then replace.
Dec 20, 2010 | Kohler Model 10430: Fort® Single-control...
We are having trouble taking out a 5 year old danze faucet with sprayer. We purchased a kitchen faucet with sprayer and we cannot remove it. We bought a basin wrench which cannot go around any it...the...
You did not mention a model number of the faucet you want to remove, so I dug this up for reference. Going by the attached PDF link, it looks like the sink may have to be removed to get at the retaining ring that this particular manufacturer uses, it's kinda odd that there is no standard retaining nut visible.
http://www.danze.com/products/pdfs/D421058_ip.pdf
Jun 18, 2010 | Plumbing
Replace button on pull-out sprayer
With your faucet in the off position pull the sprayer out. Unscrew the hose that connects to the sprayer. This lets you take the sprayer to someplace where you can sit down. The front of the sprayer where the water comes out unscrews as well. You may need to use a nonslip mat or a piece of rubber but you can undo this by hand. Once you have this off a small piece (airator) can come out that helps control water flow into a steady stream instead of the way water comes out of a garden hose with no nozzle. form here you'll be able to see how the old button fits into the sprayer, pop it out and replace with the new one. Assemble in reverse.
Feb 16, 2010 | Grohe 32 999 KD0 Alira Pull-Out Spray...
I have a faucet/sprayer combo and the hose came off when I was using it and now I can't seem to thread it back up....what do I use/do? p.s. I don't know what brand or model...just had to pick something so...
Disconnect hose from sprayer unscrew nut on sprayer head remove washers and you will see a small c shaped clip get that apart then remove hose and thread it back on under sink and feed it back up through sink and reconnect to sprayer
Oct 28, 2009 | Delta 2402 Classic Single Handle Kitchen...
Home Logo
161 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
