Question about HEWLETT-PACKARD 500B MT E5700 3202GB 27 PC PC Desktop
How to slave the hard drive - HEWLETT-PACKARD 500B MT E5700 3202GB 27 PC PC Desktop
    Top Expert:
  • 12,223 Answers
You must go to BIOS setup and follow the steps.God bless youHowever follow this steps:
Instructions
Remove the screws on your computer case and slide the cover off of the machine. Notice the hard drive bays in the front of the machine. The existing hard drive is installed in one of these bays.
Use the tweezers to set the jumper pins to "Slave" mode. The jumper pins are white connectors located on the back of the hard drive. Above the jumper pin section on the hard drive is the schema to set the drive to "Slave."
Insert the hard drive into the computer case bay underneath the existing drive. Screw in the drive and mount it to the case using the screws included with the hard drive packaging.
Connect the hard drive cable from the main hard drive to the secondary slave drive. There are two connectors on the hard drive cable. The very end of it is inserted into the main hard drive. The middle connection is used for the slave drive. Insert this secondary, middle connector into your newly installed drive.
5
Insert one of the power supply cables into the back of the hard drive. This supplies electrical power to the device.
6
Replace the case cover back onto the machine. Ensure you replace the screws to properly fasten it to the computer case.
Posted on Jan 23, 2013
WD1001fals as slave
SATA Hard Disk as a Slave b> An SATA hard drive is an internal hard drive that connects to your computer's motherboard. It is even possible to connect multiple drives to the same computer; however, only one drive can be the master hard drive; the other(s) must be slave drives. This is because the master drive has the operating system installed and must be used to boot up the system. When installing a new SATA hard drive onto your computer, you must set it as a slave.
Power down your computer and disconnect the cables. Remove the Phillips screws from the exterior of the computer case and slide the case open to expose the interior of your computer. Identify the hard drive at the front of your computer, then slide the new SATA drive in underneath. Insert the smaller power cable into the power port on the side of the SATA hard drive. Follow the power cable running out of the current hard drive and insert it next to it on the motherboard. Pull out the ribbon cable, which has three different connection ports: one on each end of the cable and one in the middle. The connection port on the middle inserts into the slave drive and is slightly different than the other two ends (the pins built into the port are in different locations than the other ends). Insert the middle connection port into the ribbon port on the back end of the SATA hard drive. Plug one of the opposite ends of the cable (doesn't matter which one) into the SATA connection port on the motherboard (your current hard drive is inserted here). Once connected, this completes your slave drive connection. Second SATA 2 Hard Drive as a Slave b> Installing a second hard drive in your desktop PC or notebook is an option used to increase hard disk space without losing or transferring the data from your original hard drive. Using this method not only increases hard disk space, it also increases the virtual memory space for the Windows operating system, increasing operational efficiency. One of the ways in which a BIOS can recognize the second hard drive is to boot it as a slave drive, with the primary hard drive booted as a master drive.
Turn the PC off and remove the desktop chassis. Refer to the pin connector diagram. This is displayed on the sticker, on top of the hard drive, for the position of the slave pin. Place the plastic connector on the slave pin as detailed on the diagram. Connect the hard drive to the power and IDE/SATA cable. Ensure the other ends are connected to the motherboard. Use the screws to mount the drive. Replace the desktop chassis. Turn on the PC. Enter the BIOS, by default this can be done by pressing F2. If this does not work consult your motherboard manual. In the BIOS, press right until the boot device tab is highlighted. Set the slave drive to boot following the primary drive. Read the bottom line and use the relevant key to save the settings. Restart the PC.
Hope it helps.
http://www.pcmech.com/article/installing-a-hard-drive-step-by-step/ Installing a hard drive.
Jan 24, 2013 | Western Digital WD Caviar Black WD1001FALS...
How to set a toshiba hard drive to slave?
Power off the Toshiba laptop. Remove the power cord and the battery.
Turn the laptop upside down and remove the panel where the hard drive goes with a screwdriver.
Depending on the model of Toshiba laptop being worked on, this may include the entire bottom panel, a panel covering both hard drive slots or a panel covering the empty second slave hard drive slot.
Install the second hard drive by inserting it into the open slot.
Replace the opened cover.
Replace the battery and power cord.
Turn on the computer.
The second hard drive is automatically configured as the slave drive.
Depending on the operating system and previous status of the slave hard drive, it may need to be partitioned or formatted before being used by the operating system.
hope this helps
Sep 13, 2012 | Toshiba Computers & Internet
How to slave hard drive?
To configure the hard drive as a slave drive, you need to set a jumper on the hard drive to SL (slave)
The other jumper settings are MA (master) and CS (cable select).
Mar 19, 2011 | Samsung (MP0804H) 80 GB Hard Drive
Master/slave settings on sp411c samsung drive please SATA
The SATA hard drive did not have master/slave setting at the hard drive
if you want to make the hard drive as master just connect your hard drive to SATA 1 slot at Motherboard
and id you want to make the hard drive as slave just connect your hard drive to SATA 2 slot at *********** board
i hope this helpful
thank you for using fixya
Feb 09, 2011 | Samsung Computers & Internet
What happen if i dont put jumper in a hard a hard drive?
If you don't put jumper in harddrive is detects it as cable select means if you connect your harddrive to middle socket of ide cable and then it detects it as slave but if you connect it at the end of ide cable it detects as slave.But make sure that otehr device is not set as master only 1 device is set as master or slave .
Let me know if you need further assistance.
Thanks for using FixYa.
Jun 01, 2010 | Seagate U6 (ST340810A) 40 GB Hard Drive
How to make IDE slave hard drive?
You can make it slave with jumper settings check in back side of harddrive you can see jumper which is connected to 2 pin of harddrive.
Read instruction on harddrive you can read how to set jumper for make it slave.
Then you ca use it as slave.
Need master slave configuration
You should have a jumper configuration written somewhere on the front (up) side of the hard Disk ... Look there, or look just around the Pins... Look for M, S, CS (Master, Slave, Cable Select)
Darko, Serbia
Mar 20, 2009 | Western Digital 60GB U100 5400RPM 2MB...
How to detect the hardrive?
setup the first drive as slave ( sometimes No Jumper ) then the furthest away drive as Master.
If this fails, and you have 2 IDE Slots on the motherboard. ( Primary/Secondary ) Put 1 drive on primary as Slave. And DVD Rom As Master ( same Cable ) Then put second drive On Secondary IDE Slot. ( Set As Master Or Slave )
If none of these solutions Work For you, check to see if Both Channels are activated in the Bios.
Thankyou For Using Fixya.
Mike @ compurepair.
Jan 28, 2009 | Maxtor Hard Drive
Slave pin settings
hi frined
remove your hard disk jumper & u r hard will be slave
Apr 12, 2008 | Maxtor 20.4GB 7200rpm ATA-100 HDD p/n...
HEWLETT-PACKARD 500B MT E5700 3202GB 27 PC PC Desktop Logo
71 people viewed this question
Top HEWLETT-PACKARD Computers & Internet Experts
Michael Vincent Cruz
Are you a HEWLETT-PACKARD Computer and Internet Expert? Answer questions, earn points and help others
