Question about Sharp EL-2630P Calculator
SHARP EL-180V RIBBON INK - Sharp EL-2630P Calculator
  • 329 Answers
SOURCE: Sharp EL-1197 piii
printer out of time marks look like scuff marks right? Heavy job to retime.
Posted on Jun 24, 2008
SOURCE: ribbon installation
I searched this online, and have found the following instructions:
1) Set the power switch to OFF
2) Remove the printer cover
3) Remove the ink roller by turning it counterclockwise and pulling it upward.
4) Install the correct color new ink roller and press it in the correct position. Make sure that the ink roller is securely in place.
5) Put back the printer cover.
Posted on Dec 29, 2008
SOURCE: Need new ribbon
The ribbon code is BR80C. Nu-Kote has a version with a part number of NUKBR80C. You should be able to order it on line at Staples.
Posted on Mar 27, 2009
  • 566 Answers
SOURCE: WHAT KIND OF RIBBON DOES THE SHARP EL-1801V USE
Ink roller type EA-772R
You can find it in any good (refer your machine make and model). There are compatible roller with different references. Also check online (do a gGoogle search or check Amazon.com and you will find several links fopr different seller.
Note that the same type of ribbon is use by diffrent calculators, evem from different brands, so lok for the image of the print roller to see if it looks like t he roller of your machine)
Posted on Jul 25, 2009
SOURCE: sharp caluulator EL-1701C out of ink..lost manual
found solution. thx.
Posted on Nov 16, 2009
Sharp EL 1197p will only print red ink not black??
If I am not mistaken the EL1197 is the ink roller type. It has the red/black and it's the IR40T. If that's the one replace the ink roller. If it's a ribbon type then replace the ribbon. It's about $5. Email me if there is any problem
Apr 05, 2015 | Sharp Office Equipment & Supplies
Sharp EL-1197PIII Calculator won't print using the blank ink. Ribbon is correctly installed.
I still have to believe that your ribbon is not quite seated properly on this. I would check that again. If this is not a "cartridge" then Check to see if it is upside down.
Jan 15, 2015 | Sharp EL-1197PIII Calculator 12-Digit...
Can you change the ribbon
Yes you can. That type of calculator has two separate ink rollers, one black & one red. They are easy to remove by putting your finger around the little ink roller & sliding it out towards you, the new one will lightly click into place. You can buy the sharp brand of ink rollers or a generic brand that will fit your calculator.
Jan 25, 2011 | Sharp EL-1701C Calculator
How do i change the ink cartridge
No ink cartridge - the ink is on the ribbon. Replace the ribbon if out of ink.
Dec 14, 2010 | Sharp EL-1801P Calculator
I cant find where the ink cartridge is on the sharp EL-180P
Not familiar with your model but others I have serviced used an ink-impregnated roller rather than a ribbon; you may be looking for the wrong object. They were generally rolling directly on numeral roller.
Apr 15, 2010 | Sharp EL-1801C Calculator
I cannot replace the ribbon correctly. I have
You may download a copy of the manual here. The ink ribbon replacement instructions are on the first page.
Sep 30, 2009 | Sharp EL-1197P Calculator
What ribbon does the sharp 1801p use?
It uses SHARP Ink roller Type EA-772R.
You may find compatible ink rollers with different other references from other makers.
If you want to download the operation manual for your digital printer calculator, click here:
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000003765.pdf
Jul 29, 2009 | Sharp EL-1801P Calculator
WHAT KIND OF RIBBON DOES THE SHARP EL-1801V USE AND WERE DO I FIND IT?
Jul 16, 2009 | Sharp EL-1801P Calculator
Sharp EL-2630P Calculator Logo
70 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
