Question about RCA DRC8300N DVD Recorder/VCR
RCA dvd-vrc combo model DRC8320N
I was playing a tape that was record on the Sony vcr. The tape changes speed from SP to SLP and SP and SLP over and over. It been that way for the entire tape. It does that on its own. I tried to change the speed and the tracking on the remote but it will not solve the problem. The model number is DRC8320N. Please advise. Gary
  • Anonymous Sep 28, 2008
    it wont play and the vcr wont come out
How do I rewind both vcr and dvd?
Posted on Jun 24, 2008
RCA MODEL DRC832ON..NEED REFERENCE # FROM SUPPORT TECH 1-866-775-0976 TO REPLACE PROCUCT..RAC SOLD TO AUDIO BOX..SEND DRC8320N TO: VENTURER ELECTRONICS, 203 EGGERT RD, BUFFALO, NY, 14215..WHEN YOU RECEIVE REF #..NEDD TO HAVE RECEIPT FOR PRODUCT LESS THAN 1 YR FOR WARRANTY TO BE EFFECTIVE
Posted on Feb 05, 2008
SOURCE:
When playing back vcr tapes on my magnavox ZV427MG9 A, i have a tracking problem with tapes recorded on slp. i get white streaks on the playback, and manual tracking does not help. tapes recorded on s
The VCR has at least four "heads" two are for 2 hr and two for 6 hour (sp and slp)
It is most likely one of the heads used in the SLP mode is slightly blocked with tape debris--heads need to be manually cleaned in the right way.
Jun 16, 2012 | Magnavox ZV427MG9 DVD Recorder VCR
My vcr tapes play too fast
If I remember correctly, VCR players had three speed settings. SP-short play, LP-Long play, and SLP- Super long play. The vcr is supposed to be able to tell what speed the tape was recorded at, thus playing it back at the correct speed. If your unit has lost the ability to sense the speed the tape was recorded then you will have to set the speed manually, if possible. Other than that I would have to say it's time to get a new vcr.
Feb 20, 2012 | Philips Magnavox MWR20V6 DVD Recorder/VCR
How do I change the vcr to 'SLP' - it seems to be stuck on 'SP'. (There is no "speed" button on my remote.)
Use the remote to get into the setup menus. There may be an option to change tape speed when recording. Alternatively, when you press record on the remote (or deck), you may have option to change the tape speed there.
The VCR part of your deck may be able to playback, but not record in SLP mode.
Searched around for the manual for your machine, and though there are references to it, it appears that a manual / information page doesn't exist for the model # that you listed.
Jun 11, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Hi - I can't switch my vcr speed from spl to lp.
On this combo, the vcr can play SLP, LP and SP but can only record SLP(6h) or SP(2h).
Apr 27, 2010 | Quasar VV-1311W 13 in. Combo
I purchased a RCA DRC-8335 DVD/VCR RECORDER COMBO
For anyone who has an RCA DRC 8335 with dvd Recorder, here is a suggestion.
If your tapes have been recorded in SLP Mode, om another player, I can tell you they will NOT play on this thing!!
So, merely take another VCR, and a blank tape, Place the blank tape into the RCA DRC 8335 VCR side, and then, go to its Set-Up Menu, and go to OUTPUT. On the "ACTION BAR"Change the the RCA's output to "FRONT" and then, play the VCRr you stuck on top of the RCA!!
When the inage on the "Source tape is shown,
Record onto the RCA, in SLP Mode, Now, it will play, just fine.
Hope this helps. Jon (Found BY Accident!!)
Jul 31, 2009 | Televison & Video
Vcr recording speeds
Yes. SP is "Standard Play" and LP is "Long Play", while EP/SLP are short for Extended Play/Super Long Play respectively.
Jan 19, 2009 | Broksonic CTSGT8118T 13 in. TV/VCR Combo
Dubbing from VCR to DVD
Dont use xp mode. Here are the definitions:
SP is short for Standard Play. Standard play allows you to record information onto the tape the way it was intended, with no quality loss. By default, VCRs and camcorders will record your footage as standard play. On a standard VHS tape, recording footage in SP mode will yield 2 hours of video.
LP is short for Long Play. Long play allows you to record much more information at the expense of quality. It accomplishes this by reducing the speed the tape is run through the VCR. As the tape speed decreases, the quality will also decrease. You’ll notice this effect when comparing a tape recorded at LP versus one recorded at SP, especially after years of storage. The LP tape will appear more blurred, have more tracking and color issues than tapes recorded at SP. A VHS tape recorded at LP can hold roughly 4 hours of video.
EP/SLP is short for extended play. Extended play is similar to LP, but actually provides you even more recording time. EP was primarily used to document long, continuous events without the need to change video tapes every 2 hours. Due to the fact that the video is not of optimal quality, many times this setting was not used in order to preserve the quality of your footage. Tapes recorded at EP usually are the most problematic after years of storage, displaying a wide variety of tape damage symptoms including color loss, audio loss, frame skipping, and tracking issues.
Sep 02, 2017 | LG LH-C6235 System
Rca tv/vcr combo model T13208
Recording speed is the last item on the timer programming. SP or SLP. Some remotes have a button that will allow you to change the speed, when recording manually.
Sep 12, 2008 | RCA T13208 13 in. TV/VCR Combo
Not able to copy entire vhs to dvd
What is the recording speed of your tapes and DVD? SP SLP, etc. on tape SP SLP XP on DVD? That will determine the length of th recorded tape and the recording time the DVD can hold.
Aug 10, 2008 | Samsung DVD-VR320 DVD Recorder/VCR
Codes
Those terms mean the speed that the VCR can record programs.
SP Standart Play >>> 120 minutes.
LP Long Play >>>>>> 240 minutes.
SLP Slow Long Play > 480 minutes.
May 06, 2008 | Funai FDRV90E DVD Recorder/VCR
RCA DRC8300N DVD Recorder/VCR Logo
993 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
