Question about Procom Heating & Cooling
THERMOCOUPLE FOR A MODEL SSQD250T
PRO COM HEATER MODEL: SSQD250T SERIAL: 4117399 IN NEED OF THERMOCOUPLE FOR THIS UNIT
SOURCE: ProCom 300 Heater
need thermocouple for MN300TBA Serial # 3531907 where do I find one in Chattanooga, TN area
Posted on Dec 05, 2008
protek480
  • 1714 Answers
SOURCE: Need a replacement thermocouple for my DynaGlo Pro
All thremocouples have a number on them which tells what 'millivolt' output it has. Try to match that up or call a HVAC company and ask them for one with that number.
Posted on Oct 05, 2009
SOURCE: Where is the model # located on my Comfort Glow propane heater?
Usually it is a metal plate stamped to the unit.
Most common places to find it is usually located where the gas
valve and burner is located, it could be hooked to a chain.
Sometimes it is located on the side.
-Good Luck
Posted on Jan 08, 2010
kel1guy2002
  • 3740 Answers
SOURCE: I need to know that
The manual is here:
http://www.desatech.com/manuals/Construction%20Heaters/000122-01.pdf
The 13" thermocouple with junction box is PN 6654 or PN 113884-01 (Same exact one)
(picture ref)
http://cgi.ebay.co.uk/Thermocouple-113884-01-Reddy-Desa-LP-Heater-6654-Unvl-/260537344722
Here are several sources:
http://www.google.com/search?hl=en&safe=off&rls=com.microsoft%3Aen-ph&q=113884-01&btnG=Search&aq=f&aqi=&aql=&oq=
Thanks for choosing FixYa,
Kelly
Posted on Apr 04, 2011
I have a pro com 30000 btu vent free heater.it keeps shutting off.how do I fix it.
If the thermocouple is bad, the pilot light will not stay lit. Sometimes the pilot will stay lit but when the unit turns on the gas for heat, things change a bit and the nearly bad thermocouple doesn't see the flame it should and causes the gas to shut off.
You can google the make / model of your unit with the word 'thermocouple' and see replacements for sale. Usually not much more than $25. Thermocouple Wikipedia the free encyclopedia
Feb 08, 2015 | Heating & Cooling
I have a All-PRO 30,000 BTU/HR propane heater Model Universal 30-fas All Pro SPC-30 that needs a thermocouple. The part number on the burnt thermocouple is H08F, 315, e2 W-R 0020 made in Mexico. I need a...
Master Parts Distributor carries all the parts for the now defunct DESA International, who manufactured your All Pro heater.
The following link will take you to them http://www.allproheaterparts.com/
Hope this helped you.
May 01, 2011 | Heating & Cooling
My all-pro propane heater will not stay lit for over thirty seconds after I release the red fuel start button,before the flame goes out it makes an air hissing noise right before it shuts off.Heater will...
This sounds like a problem with your thermocouple.
Just remove the end of the thermocouple from where is goes into the gas valve and leave the end that goes into the flame in place.
Clean the end of the thermocouple connect by scraping off just a little metal from the end just about there the nut tightens the thermocouple into the gas valve. After you have exposed some new metal do the same inside the valve where the thermocouple seats into the gas valve.
Use a small pic or similar item to scrape inside the gas valve to expose some new metal there also.
Now reassemble the thermocouple into the gas valve and see if the heater works.
Here is a link with some more instructions.
http://www.msservice.net/ts/reseat_thermo-clean_pilot-ODS.htm
If this does not solve the problem you may need a new thermocouple and you can find that at www.desaparts.com
Thanks
Jan 04, 2011 | All-Pro Propane Garage Shop Heaters - All...
My name is Larry and I have an older model Vanguard natural gas wall heater. Igniter works and pilot lights, but pilot will not stay lit no matter how long I keep the control pushed down. As soon as I...
The part is ordered by Model number, a serial number is no help, and yes there is a part called the flame sensor that allows the gas to stay on, I am sure if you contact a local supplier they can provide a suitable substitute gas valve or sensor if it is a stand alone part, on most the sensor is part of the gas valve. I think you will end up having a local shop try and match up the valve.
Dec 03, 2010 | Vanguard International VN30B Infra-Red...
I have a 40 galon GE Smart shield water heater, Model: SH40T12AVH00, Serial # GELN0805V13908. The pilot light is lit but the burner will not stay on for more than 2 secods and then shuts-off.
I believe this unit does not have a standing pilot light and lights each time? Have you reinstalled all doors back into the heater? It sounds like the main burner is blowing the pilot off the thermocouple. You might try replacing the thermocouple. You can download a manual here: http://products.geappliances.com/ApplProducts/Dispatcher?REQUEST=SpecPage&Sku=SG40T12AVH00
Aug 02, 2010 | General Electric GE SmartWater Household...
I need to find a thermocouple for a mr heater Model mh35fa propane. mr heater does not have them in stock
Why not take out your old thermocouple to a store that sells furnace parts for propane fired units?
The important thing is unit length and the right fastener and the rest should take care of itself right?
Good luck and be careful!
Feb 09, 2010 | Mr. Heater Thermocouple
ProCom 300 Heater
got mine from Guadlupe Gas www.guadalupegas.com 830-606-1877 New Braunfels Tx 78130
Nov 01, 2008 | Procom ML300TBA Heater
Heating & Cooling Logo
109 people viewed this question
Top Procom Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
john h
Are you a Procom Heating and Cooling Expert? Answer questions, earn points and help others
