Question about Leviton Electrical Supplies
Can I use the leviton 15A-125V adapter to a 220V wall socket?
I have a digital alarm clock and it has a spec of 110V-6W. Can I use the Leviton #274 15A-125V adapter and plug it into a 220V wall outlet? Because we are using a 220V here in our country..
Not an adapter. You need a voltage converter to convert 220Vac to 120VAc.
Posted on Sep 01, 2014
SOURCE:
Wiring on an electrical house outlet
If you are looking for colors and what goes where then the
Mar 08, 2015 | LEVITON MFG CO., INC Leviton 7599-Sgt 15a...
How do I wire double elrctrical switches?
i assume both switches are single pole? How to wire depends on what wires you have in the box (i.e. the circuit they are in).
Aug 10, 2014 | Leviton White Double Wall Light Switch...
Leviton programmable timer switch problem
Connect timer white wire to bare ground wire. This will complete circuit to 3 watt timer mechanism, and while this action is not 100% code, it will not pose much risk since the wattage is so low.
Copy following link for illustrations and information:
http://waterheatertimer.org/How-to-wire-timers.html
http://waterheatertimer.org/Leviton-timers.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Aug 05, 2012 | Leviton Electrical Supplies
How do I hook up a Leviton Decora no 5601... I have a white, a red, and a black wire
Wiring is unclear without more information.
Question posted under 4-way switch.
Wiring sounds like 3-way switch is possible.
And Leviton 5601 is single pole switch.
Add a comment and say what load the switch controls. Load means light, fan, motor, etc.
Say if another switch controls same load.
And include what type of device you are replacing.
Include what screws and screw colors are on old device.
When you add a comment, it sends email, and I will respond to comment.
Sep 01, 2011 | Leviton 112-05604-2WS 15A 4-Way Decora...
Where are the wires in my leviton switch I just bought?
There are no wires on the switch. There are 2 screws. The hot wire goes under 1 screw and the switch leg goes under the other screw. The green wire , or ground wire goes to the green screw. If you don't have a ground wire in the box just forget about the green screw.
Jan 16, 2011 | Leviton 15a 120v Sp Switch
I have a Leviton Combination Switch and Tamper Resistant OIutlet. Switch is on top. 15A-120V AC/CA 15A-125V and want to install it. Not sure how to connect with wires from wall so that the on/off...
Do not break off fin.
FYI: Tamper resistant outlet must have prong in both outlet-holes before there is power.
This prevents child from sticking something into one outlet-hole and getting shocked.
You are installing combo switch and plug.
Device has dark screws (with break off fin), and 1 brass screw and 1 silver screw
Electricians don't guess, they test.
Let's test wires using ordinary tester.
Separate wires, turn on power.
Do not untwist wires that are twisted together.
Test each wire to bare ground wire. Tester lights up on hot wire.
Hot wire goes to dark screw.
Hot is identified.
Test Hot wire to all wires except bare ground wire, but including white wires that are twisted together,
Tester lights up on Neutral.
Connect neutral to silver screw.
If you do not have Neutral, then you do not have wires needed to connect outlet part of device.
Outlet can be powered using ground wire in silver screw, but this is not code and I am not recommending this action.
There is one wire left that does not light up when testing,
This is wire goes to load (lights, fan, motor) ... connect this wire to brass screw.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on switch or any do-it-yourself project.
Jan 13, 2011 | Leviton 15a 120v Sp Switch
Do I connect the black and red wires coming from my first 3 way switch to each of the black IN screws on my 4 way switch and connect the other black and red wires to the gold OUT screws going to my last 3...
http://www.leviton.com/OA_HTML/ibcGetAttachment.jsp?cItemId=sPOj1y4-FvozD26dzcf2mQ&label=IBE&appName=IBE&minisite=10026
Here is the wiring diagram.
It looks like you connect the black & red wires on the sides as you state.
The black coming from one 3-way connects to the top terminal on one side, the red coming from the same 3-way connects to the bottom terminal on the same side.
The black going to the other 3-way connects to the top terminal on the other side and the red going to the other 3-way connects to the bottom remaining terminal.
Dec 27, 2010 | Leviton 112-05604-2WS 15A 4-Way Decora...
I'm in need of an inexpensive timer, preferably mounted in a wallswitchbox, which has two output circuits, one from a n/o and one n/c contact. Can you recommend a model? Thank you
Instruction sheet
Sales sheet
Deihl spa-and-pool timer shows a 15A DPST NC NO timer in sales sheet
Wiring diagrams show DPST.
However most 880's sold are 125V SPST.
Deihl makes 125 V, 24V and 240V models ... but I don't have product sheet that shows all models
I don't see any NO NC wall-timers while looking at: Woods, GE, Intermatic, Aube, Hagar, Leviton, Lutron, Paragon, Pass and Seymour, Swilight, Sylvania, Timex, Tork, UPM, Utilitec
Box timers by Intermatic offer NO NC:
T1900 series
T171
Ordinary 3-way switch is NC NO
Ordinary 4-way switch is NC NO can be wired to control 2 independent circuits
There are heavy load NO NC contactors (relays)
Item 2cg37
You can wire ordinary wall timer to control the contactor
Oct 08, 2010 | Hardware & Accessories
Leviton wireless switch fails to work all the time
50 feet is the maximum range for the switch, per manufacturers spec. Range is diminished somewhat for walls, doors, etc.
IIRC, there is a plug in transceiver available from Leviton, however, if the price of the booster for the main panel is included in the $100 installation, then I'd say that's a fair price. You may try to keep fresh batteries in the switch.
Jan 15, 2009 | Leviton #601-6696-I Ivory Wireless 3WY...
Electrical Supplies Logo
604 people viewed this question
Top Leviton Electrical Supplies Experts
jdthefixer
Gene Haynes
boomanfoo
Level 1 Expert
Are you a Leviton Electrical Supply Expert? Answer questions, earn points and help others
