Question about Motobecane Nemesis
Seat post won't stay up - Motobecane Nemesis
    Problem Solver:
  • 18 Answers
Either your post is not correct size, i believe it take a 27.2 but if you need quick fix make a sleeve to go around outside of seat post out of anything that will take up space like sandpaper or a peace of rubber. make sure you get it around the seat post an slide it down the seat tube the tighten seat post clamp, and it should hold you until you friends notice it and kid with you about not having the proper sea tpost.
Posted on Jan 24, 2013
Seat back won't stay up
Probably has a broken or jammed lock When you position the seat try pulling/pushing the handle instead of relying on the spring to engage the lock. If the seat frame is broken remove it for repair or replace with another seat back
Feb 22, 2013 | 1998 Toyota Corolla
Devices won't connect or stay connected
That's two issues, can't connect to what? Make, Model of computer and the OS you are using. Staying connected may be many things, from interfererence, distance, ISP signal, Belkin settings, cabling, software settings...etc. Is your Belkin Securied with a Security password? Post more info.
Dec 27, 2012 | Belkin Share N300 Wireless Router...
Polan 14.5 rifding mower won't stay running when clutch released
Either a problem with the seat switch, or just make sure the block connecter that gose to the switch is fully pushed into the switch if its even slightly off it will stop the engine.
Jun 17, 2012 | Poulan Garden
Pw50 fires but won't stay running
Hi, Jj9871 and the usual suspects are:
1. Fuel cap or fuel tank is not venting properly.
2. Fuel filter clogged.
3. Fuel line pinched or kinked.
4. Float needle and seat sticking.
5. Float level too low.
6. Carburetor bowl vent line clogged/blocked/pinched.
7. Idle adjusting screw set too low.
8. Air/fuel mixture screw set too lean.
9. Idle port, transfer ports, slow air jet clogged.
10. Slow fuel jet clogged.
11. Faulty fuel pump.
For more information about your issue and valuable "Free" downloads that you will need please Click on blue links below. Good luck and have a wonderful day.
pw50 won start please help
My Son Has Yamaha Pw50 That Will Start But Won Stay Runn
https://books.google.com/books?id=ozV8-Aer4N8C&pg=PA84&dq=pw50+manual&hl=en&ei=TCS2TcbdJ4PW0QG0z9jmDw&sa=X&oi=book_result&ct=result&resnum=1&ved=0CGUQ6AEwAA#v=onepage&q=pw50%20manual&f=false
OEM parts for Yamaha
Yamaha PW50 Owner Manual
Apr 14, 2012 | 2004 Yamaha PW 50
Why won't the driver's seat on my 2006 XJ8L won't adjust in height?
You have a problem with the power seat transmission. The 1st thing to do is make sure that nothing under the seat is impeding the movement of the seat, if that is OK you will need to try and find a used power seat transmission, the parts are not sold separately, just the whole assembly.
Feb 13, 2012 | Jaguar XJ8 Cars & Trucks
Have a 89 jeep Comanche starts but won't stay
If is fuel injected try checking the fuel regulator and if is has a carburetor possible bad choke or needle seat / worse case jump timing
Dec 19, 2011 | 2006 AMC Comanche
How to get a giant trinity a1 tt seatpost?
Bicycle seat posts are pretty standard items and you could just use a generic replacement if you want as long as you get the right size diameter.
If you still have at least part of the old seat post, then just use some precision calipers to measure the outside diameter of the seat post and that will tell you what size replacement you need to get.
This needs to be a pretty acurate measurement, within a tenth of a millimeter, so eyeballing it with a ruler just won't do it.
Otherwise, if you are missing the old seat post entirely, then you can try just measuring the inner diameter of the bike frame where the seat post slides into your bike tube and you should get the same measurement.
The easiest way by far is just to bring the bike into your local bike shop and get them to measure your seat post size with a special seat tube measuring tool they have. Then you can just order a new seat post based on that size from wherever you want, either right at the store or online.
Good luck and take care.
Joe.
Dec 14, 2011 | Giant Bicycle Inc. Trinity A1
Hi, I have a Craftsman Eager-1 5.3 3-in-0ne solid state enigine lawn mower..got it used but in almost new condition. worked great cutting 1 1/2 ft of very wet grass for a few hours (couldn't get to it...
Drain the fuel or when you remove the float bowl bolt (also the main jet), then hold up on the float to keep the needle on the seat so gas won't go everywhere. When you have that brass bowl bolt off, clean it! Use nothing metal on it. Pay close attention to the small hole in the bottom and along the smooth unthreaded part at the other end. Use carb/choke cleaner to blast gum and dirt out of those very small fuel orifices. I recommend installing an inline fuel filter also. A shut off valve is recommended too, that way if the needle in the carb sticks open, the crankcase won't be polluted with gas. Usual symptoms on a clogged lawn mower main jet though, are after pushing primer bulb, engine runs about 3 seconds. Try the brass bolt cleaning and post back if needed.
Jun 14, 2011 | Garden
Heated seats in 2007 Lincoln MKX not working. I puch the button to turn them on and they light up for a second then go off. What would be the cause and solution. If it was a major problem would effect...
Help anybody?
I have a 2010 Lincoln MKX with heated and cooled front seats. However, when I try to turn them on (85% of the time) they don't work. Primarily when it's cold the heated seats won't stay on... The light turns on for a fast count of 1-5 and then turns off. This has happened since the car was new and I've had it into the dealer 4 times to have it fixed (with no resolve). In their defense they suggest it's fixed each time because they test the heated seats when the vehicle is warm in the shop. Unfortunately, this is nearly the only time it stays on.
I would love to recommend a suggested fix to the dealer as they don't seem to be able to repair it... Any ideas???
Mar 14, 2011 | 2007 Lincoln MKX AWD
Motobecane Nemesis Logo
Top Motobecane Cycling Experts
Jerry Kramer
Jerry Kramer
Tom Chichester
Donald Ayers-Marsh
Are you a Motobecane Cycling Expert? Answer questions, earn points and help others
