Question about ALCATEL-SWITCH AND ROUTER Oaw-ap93 Omniaccess Ap93 Wls Ap 802.11abgn D
ROUTER Oaw-Ap93 power led flashes - ALCATEL-SWITCH AND ROUTER Oaw-ap93 Omniaccess Ap93 Wls Ap 802.11abgn D
Reset tablet c
These steps came from the MSI website itself. link
Restore with reset button
1. First turn the powericon1.png off the router and press the "reset" button.
2. Power on the router and hold the reset button until M1 & M2 LED or Status start flashing.
3. Release the reset button. If the LED flashes eight times that means the reset is done but if theLED lighticon1.png flashes twice you need to repeat the steps.
Reset the router while the power is on.
1. Press and hold the reset button for about 5 seconds M1 should flash 5 times, release the reset button and the restore/reset process is done.
[Answer supplied by Aris C on Fixya.com]
Jan 22, 2014 | MSI Computers & Internet
WHAT LIGHTS ON LINKSYS ARE SUPPOSED TO BE BLINKING
Note that incoming traffic will cause the WAN (or Internet) light to blink even if it is 'probe' traffic trying to break in to your network. Such traffic is to be expected and is the reason you have firewall functionality in your gateway router.
On the inside, there is a bit of traffic on any LAN when the computers are turned on. Messages generated by the router itself are used to find computers and printers for a lot of different legitimate reasons.
Feb 25, 2013 | Linksys Wireless-G WRT54G Router
No wireless connection for laptop. Linksys router - model #wrt160n v2
you can run a direct line to that router and go to the cisco web site and get the information you need to run that router. its a pdf format and is 2.56 Meg. Try this
SecureEasySetup (Orange/White) The Cisco logo is the Router's SecureEasySetup button. It
lights up and will stay orange when the Router is powered on. The color orange indicates that
the Router is not using the SecureEasySetup feature, while the color white indicates that the
Router is using the SecureEasySetup feature. When the Router enters SecureEasySetup
mode, the Cisco logo will turn white and start flashing. After the Router has generated
the SSID and WPA Personal key, the Cisco logo will stop flashing and stay white.
To clear the SSID and WPA Personal key, press and hold down the Cisco logo for five seconds.
The Cisco logo will flash slowly as the Router resets itself. The Cisco logo will turn orange to
indicate a successful reset.NOTE: SecureEasySetup is a feature that makes
it easy to set up your wireless network. If you have SecureEasySetup devices, run the Router's
Setup Wizard CD-ROM and follow the onscreen instructions to use SecureEasySetup.
Power (Green) The Power LED lights up and will stay on while the Router is powered
on. When the Router goes through its selfdiagnostic mode during every boot-up, this
LED will flash. When the diagnostic is complete, the LED will be solidly lit.
DMZ (Green) The DMZ LED indicates when the DMZ function is being used. This LED will
remain lit as long as DMZ is enabled. WLAN (Green) The WLAN LED lights up when
the wireless feature is enabled. If the LED is flashing, the Router is actively sending or
receiving data over the network. 1, 2, 3, 4 (Green) These numbered LEDs, corresponding with the numbered ports on the Router's back panel, serve two purposes. If the LED is continuously lit, the Router is successfully connected to a device through that port. A flashing LED indicates network activity over that port.
Internet (Green) The Internet LED lights up when there is a connection made through the
Internet port. A flashing LED indicates network activity over the Internet port.
Good luck
Nov 26, 2010 | Computers & Internet
Power led solid red, internet led solid green
This is a sin of a bad unit already, first thin that you can try here is to reset the router by pressing the reset button of the device for 30 seconds , but after that and still the same light better contact your device manufacturer...
Sep 15, 2009 | Actiontec GT704WG Wireless Router...
Di-524
- Update the firmware of the router.
Feb 28, 2009 | D-Link AirPlus DI-524 Wireless Router
Forgot password and username
Yes there is.
1. First turn the power off the router and press the "reset" button.
3. Release the reset button. If the LED flashes eight times that means the reset is done but if the LED light flashes twice you need to repeat the steps.
Nov 24, 2008 | MSI Wireless-G RG54G3 Router
LAN led light alway on and flashing
Reset the router:
While the router is powered on press and hold the reset button for 5-10 sec. Release the button and wait until the router boots up (1 min).
If this does not work then you can try this
Try setting it into recovery mode and loading firmware:
Unplug power cable from the router and press the reset button. While holding the reset button plug the power cable in. Continue holding the reset button untill you will see LEDs on the router flashing rapidly.
You should be able to log into the router - you will see a prompt to load firmware. The firmware is available on our WEB site: http://www.dlink.com.au/tech/
Note - suggest you d/l the firmware BEFORE you reset router
Jul 05, 2008 | D-Link DI-704P Router
No power led, wlan led blinking
well, what you could try is unplugging the power source from the cable modem, and the router. wait about 1 minute. then plug everything back in and wait.
i remember having this problem as well, but i think the problem with me was that my wireless computer was too far away from the wireless router, not saying that your too far or not, but that what i had, so i just pitched the wireless adapter, and created an ethernet connection. just sharing my experience.
Feb 26, 2008 | D-Link DI 514 Wireless Router (DI-514)
Wireless LED blinking, normal?
Same problem here - wireless light starts blinking and I get a network interruption. At that point, I have to walk across the house and downstairs to cycle the power on the router to get it working again. What a pain - and the manual doesn't even mention a blinking status for that light. I'm thinking about hooking the router up to a automated power switch (X12) so I can remotely cycle the power.
Dec 17, 2006 | NetGear RangeMax WPN824 Router
ALCATEL-SWITCH AND ROUTER Oaw-ap93 Omniaccess Ap93 Wls Ap 802.11abgn D Logo
26 people viewed this question
Top ALCATEL-SWITCH AND ROUTER Computers & Internet Experts
David Payne
David Payne
Are you an ALCATEL-SWITCH AND ROUTER Computer and Internet Expert? Answer questions, earn points and help others
