Question about Canon Pixma MG5220 InkJet Printer
My canon mg520 it has a printer error c000 please help me
I don't have the Manuel for this printer ive tried downloading the manuel online but that did not work and I've turned it on and off quite a few times it says printer error has occurred turn off power and then back on again . if the problem persists see the Manuel
SOURCE: error c000
Please look at
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=116&modelid=17406
Posted on Jan 02, 2009
komguy
  • 2306 Answers
SOURCE: Canon MP480- 5011 - Printer Error Has Occurred After Scan/Prt
You need to carefully clean the encoder strip. It's the clear strip behind the carriage that runs all the way from right to left. A damp Q-tip should remove any grease or fingerprints.
Posted on Jul 16, 2009
  • 33 Answers
SOURCE: Error Message C000
Purge cam sensor error [5C00] An error occurred in the purge unit. - Purge unit
- Logic board prbelom
Posted on Sep 10, 2009
pineworks
  • 4041 Answers
SOURCE: Error message 6A00 says:
Hi there
This answers with a titch more detail.
The 6A00 is a Canon generic code for paper path jam.
Some where in the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 code.
As a Canon tech, I usually find the code, almost 90% of the time, is related to the purge unit being jammed with something and not being able to move.
Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
And yes I have found all those things in a purge unit.
The offending item needs to be removed or the purge unit needs replacement.
Incidentally, the 6A00 error pertains to all Canon printers made in the last several years, its not just used in one model.
And it’s always a paper path error or purge unit.
The purge unit, called a spittoon assembly in an HP, Lexmark, and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Also clean the purge unit out make sure all is clean.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 24, 2010
pineworks
  • 4041 Answers
SOURCE: service error 6000
Hi there it is ink error.
You can try to reset the cartages this may do it Please call back let us know if it worked for you, PLEASE.
  1. Start with printer off
  2. Press and hold resume Button (triangle in the circle) and click “Power” button. Green led should be on
  3. While holding the Power button, release the Resume Button.
  4. Without releasing the Power Button, click “Resume” button for two times and release Both Buttons.
  5. Click “Resume” for four times then soon click “Power” button, to confirm the selected action (reset counter absorber).
  6. Turn off the printer and turn on again
Posted on Apr 26, 2010
Canon mx860 - had an error code C000 and now a day later 306A
Error code C000. Cancel printing, and turn off the machine. Then clear the paper jam or foreign object that is preventing the Print Head Holder from moving.
For more information about the error code C000, can be read here Canon Support and Downloads
You read, the bottom of the page
Sep 23, 2011 | Canon PIXMA MX860 All-In-One InkJet...
Hello, I hope you can help me with my printer CANON MP530 On the screen say CHECK INK. The ink is okay new once and the lights on the ink does not blink. I switch of the printer unplug it and still the...
Your printer must shown Error No. like E03 .. to solve the problem please press Stop/Release button for 5 seconds.. after all your will start functioning... If it doesn't help you please check the Error No. shown on your Printer LCD and send us... I 'll try to help you as much as I can... thanks
Aug 28, 2011 | Canon PIXMA® MP530 All-In-One Printer
I just don't know how to run the ac . When I bought it they never gave me a Manuel . I looking on line to see if I can find a online Manuel ?? Its a Simplicity Danby 700 btu portable ac
Bonnie, sinc you didn't mention a model number, it's a little hard to help you. I did find an Owner's Manual for a Danby 7000 btu Portable AC, that may be the one you have. I have included a link to it that you can download and print for future reference. If this is not your model, contact Danby Customer Support 800-263-2629 and they can provide one to you.
http://www.danby.ca/cms/uploads/products/en_manual/dpac7099_web.pdf
I hope this helped you. Please let me know. Thanks.
Jun 28, 2011 | Heating & Cooling
I do not have a manuel and don't know how to use the scanner. Are you able to help? Thankyou
Most all programs have a manuel built in.Open your scanner program and go th help. you should be able to find all the info you need
Jun 22, 2011 | Canon PIXMA MP530 All-In-One InkJet...
I have bough on eBay a used Canon Pixma850 Multi Function Printer. There is no manuel or cd. Where can I purchase these from. ( I have a manuel & cd for a Pixma700 printer would these be compatable...
You can find the drivers and the manual on this Canon link:
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mx_series/pixma_mx850#BrochuresAndManuals
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jan 31, 2011 | Canon PIXMA MX850 Multifunction Printer
Bought a canon mx300 but didnt come with manuel book
Hi
Please click on the following link for the free manual.
Canon MX300 All in One Printer User Manual
Please do rate the solution as FixYa and revert for further assitance.
Thanks
Rylee
May 25, 2009 | Canon MX300 Office All-In-One Printer
Canon Pixma MG5220 InkJet Printer Logo
349 people viewed this question
old marine
old marine
