Question about Jabra (BT620SA125S) Wireless Headset
Jabra BT620s firmware and updates - Jabra (BT620SA125S) Wireless Headset
Updater hung
I have had this problem on two modern Dell laptops with 64-bit Win7 (issued by my workplace), and in both cases I used a slow AMD laptop (with 32-bit Windows) and that solved my problem. So try running the updater on a different machine. I have been unable to find a better solution. Maybe safe mode with networking would work? I haven't tried it, but think some driver might be interfering due to a high interrupt-rate.
Apr 19, 2012 | Jabra BIZ 2400 USB Bluetooth Headset
Hi, I have a GN8120 USB and want to use it with Windows 7. With Windows Xp it was installed automatically. With Windows 7 I got an error during installation. Do you have a solution for that? Thanks Best...
To enable Windows 7 support for the GN8120 USB headset, you need to make sure it's it has Firmware Version 11.0 or newer. The version 11.0 firmware updater can be found at http://www.jabra.com/sites/Jabra/GNimages/Software updates/GN8120_Update_790.zip or http://headsetplus.com/PDF/GN8120_Update_790.zip. Other headset updates and more info can be found at http://headsetplus.com/faqdesk44/faqdesk_info.html. Note that the firmware update must be performed under Windows XP, not Windows 7.
May 20, 2011 | GN Netcom GN 8120 USB Headset
I have got a Jabra BT620s and connected it with usb to Windows 7 64 bit pc. The drivers automaticly were installed and ready to use. But there is no sound trough the headset, only trough the speakers. When...
Does your computer have built in bluetooth? if yes,make sure you press and hold the stereo bluetooth till its steady blue,,not blinking blue. then on your pc, go the bluetooth section in control panel and search for devices. then you should see the Jabra Audio device.click on it to connect to the Jabra and use the passcode 0000. After it connects, the steady blue should now be blinking blue. Then go to control panel, sound and you should see the Jabra there.Right click on it and click on set as default device. Now play any song and see if you still have it playing in your speakers.Let me know if it works.I have the same Jabra and its really works great.Especially when im working out and dont want no wires around me
May 06, 2011 | Jabra BT620 BLUETOOTH STEREO HANDS-FREE...
Jabra Cruiser software update
Your tidbit about the reset pinhole is awesome - - fixed my non-responsice Jabra Cruiser. 10 seconds, no mess! Thanks
Jun 26, 2010 | Cell Phones
Jabra bT260s Pairing problem...
You may need to change your output sound device. The method may vary depending on your software and hardware, but go to Start -> Control Panel -> Sound (I think. Doing this from memory, so might be slightly off). There should be a Devices or Output tab. Change that to your bluetooth headset. You will probably need to restart WMP before you hear music, too.
Jan 18, 2009 | Jabra BT620s Consumer Headphones
Jabra BT620s pairs to laptop but unable to switch sound output.
I had this same problem with my sony vaio (vista). But at first for me, after BT enabled the device, I couldnt find it in the device manager. I cycled on and off the headset a couple of times and once my vaio began to automatically connect the device, I was able to locate it in the device manager. Next, I went through the contol panel, hardware/sound, "manage audio devices". Here the bluetooth headset was located. After sucessfully testing the headset, I set it to default. Now whenever I fire up the headset, I have total mobile sound...awesome
Jan 05, 2009 | Jabra BT620 BLUETOOTH STEREO HANDS-FREE...
How to pair Jabra BT620s Bluetooth headphone with HP Laptop?
Hi
• At your computer Right click on the Bluetooth icon on the task bar.
• Select “Explore my Bluetooth places”.
• Click on “View devices in range” to see all available devices.
• Right click on the Jabra BT620s and select “Pair device”.
• Enter the four digit passkey: 0000 (4 zeros).
• Right click on the Jabra BT620s and select “connect”.
• The connection will be established automatically, otherwise if the Jabra BT620s is ringing,
press the answer/end button to confirm the connection.
Good Luck
Aug 10, 2008 | Computers & Internet
HTC Mogul does not accept passcode 0000 for Jabra Bt 620
try 00000 (five zero's) or 1234 or 12345; the first should work the others will work as well
Jul 27, 2008 | GN Netcom GN Jabra BT620s Bluetooth Stereo...
My M1 from Sayno and my jabra b260s
Go to this site, and it will walk you through each step to connect your particular Jabra headset with your cellphone. Choose the headset, and then at the next page, choose your phone. Moving your mouse over each step will change the picture to what you should be seeing on your phone at each step.
http://jabra.pairx.co.uk/ Pls come back and let us know if this solved your problem.
Dec 31, 2007 | GN Netcom GN Jabra BT620s Bluetooth Stereo...
Pairing problem
Before you use your Jabra BT130, you need to pair it with your mobile phone.
1. Put the headset in pairing2 mode Make sure that the headset is on. Press the answer/end button and press the volume up (+) button at the same time, until a solid blue light comes on.
2. Set your Bluetooth phone to ‘discover’ the Jabra BT130 Follow your phone’s instruction guide. This usually involves going to a ‘setup,’ ‘connect’ or ‘Bluetooth’ menu on your phone and selecting the option to ‘discover’ or ‘add’ a Bluetooth device.
3. Your phone will find the Jabra BT130 Your phone then asks if you want to pair with it. Accept by pressing ‘Yes’ or ‘OK’ on the phone and confirm with the passkey or PIN3 = 0000 (4 zeros). Your phone will confirm when pairing is complete. In case of unsuccessful pairing, repeat steps 1 to 3.
Dec 23, 2007 | Radio Communications
Jabra (BT620SA125S) Wireless Headset Logo
61 people viewed this question
Top Jabra Radio Communications Experts
TO Lady
Greg Cann
Greg Cann
Michael Vincent Cruz
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
