Sometimes notebook's display flickers and goes stand by
Doel basic 0703 notebook have assembled in Bangladesh, under government project. I have one. It has following problems: When power on, display flickers and goes to standby mode. after several tries , it runs properly. It has following specifications: System model : to be filled by OEM Bios version : American Megatrends Inc. 080016 date 08/31/2011 processor : Intel atom n455 1.66GHz with ddr3 2gb ram os tried : windows 7, currently using windows xp sp2 tested: overheated - no, cooling fan running properly- yes, hdd tested -yes and ok, battery and power supply- ok, Motherboard and display both replaced with new one by the manufacturer (Telephone Silpa Sangtha, Bangladesh) Current environment temperature :14c. Now what else would it about be? Please help. I have tried 2 different version of os and so far drivers tried different versions too. I am using latest version of driver "intel graphics media accelerator 3150 " and installed properly!
2 Suggested Answers
leecom72
  • 4806 Answers
SOURCE: i need sound card driver
Hi there.
Go here to ECS support and download the drivers you need >>>>
http://www.ecs.com.tw/ECSWebSite/Downloads/ProductsDetail_Download.aspx?detailid=277&DetailName=Driver&DetailDesc=&CategoryID=1&MenuID=6&LanID=9
Good luck and thanks for choosing FixYa!!
Posted on May 27, 2009
Sometimes notebook display flickers and goes stand by
it shows the display drivers does not load properly, re-installation of video driver may solve the issue
Jan 11, 2013 | Computers & Internet
About application download
sounds to me like the people of Bangladesh are blocking the windows market place. Some foreign governments block certain apps from getting out on the internet. I don't think it's a phone issue. Try finding it with a computer and see if you can download it there. It might also be the local cell company.
Nov 07, 2012 | HTC Excellent Unlocked Hd7 T-mobile Hd 7...
My trusty laptop's monitor has begun to flicker. It's most noticeable on battery power. It hasn't progressed to anything beyond a slight but annoying flicker. Do you have any ideas?
The could be a problem with the power on the motherboard, or the inverter board for the backlight system or it could be a loose connection. Does it flicker when you're not touching it? Move the display slightly, wiggle it gentle and try pinching it on the bottom outside edges (NOT hard) and see if it flickers then. If it does that could be a loose connection.
Unfortunately you can't really tell if it's the invertor until it totally goes out.
Jun 25, 2011 | Toshiba Satellite A105-S4074 Notebook
Screen flicker
I personally would reinstall the video driver to see if its the culprit. Also see if there is any drivers for the display as well. I also realize you said it goes away when you run an AVG scan, this is because when AVG does a scan it activates files, so essentially if your video or monitor driver is no active, then when activated it would stop the problem.
Apr 14, 2010 | Compaq Presario Notebook
I have a hitachi 42" plasma and the diplay sometimes flickers and goes to a thin line, somtimes its fine and sometimes its really bad.
Hi there
This is also a comon problem with notebook displays, it could be the signal cable thats runs to the lcd or it is the lcd its self.
I do sugest that if the unit is still under warrenty take it back or see if you can get onsite fix
Oct 22, 2009 | Hitachi 42PD6600 42 in. HD-Ready Plasma...
Picture Flickering
The sony tuners have been known to get intermittent, it might be a bad ground where the tuner connects to the main chasis, If the problem is in the tuner itself it will be most difficult to resolve since the connections are so small and compacted together.
Good luck
Apr 19, 2009 | Televison & Video
Hp Laptop screen flicker
I am sure that the issue is related to the cable that connects to the LCD Display or the LCD Backlight.
There should be some connection shortage because of which the LCD flickers few times as stated by dan231.
I Recommend you to get the Notebook examined as soon as possible before something really goes wrong...
Dec 05, 2008 | HP Pavilion dv6000z Notebook
Notebook lcd screen flickers and goes white
The refresh rate may cause this problem sometimes...
Try this
Right-click anywhere on desktop->Properties->settings tab->advanced button->monitor tab->screen refresh rate drop down list..Chose the refresh rate at which the screen will not flicker(try em' one by one)
If it doesn't work please post a comment and await reply before rating...
Oct 19, 2007 | Audio Players & Recorders
Pioneer P50A5-K goes to stand by mode
1) Pull chassis---remove power/convergence PCB==the one
with the large heatsink on it.
2) Remove solder from pins of four regulators on heatsink.
3)Clean board/pins w/ toothbrush & alcohol.
4)Re-solder, also solder both Stk's for prevent.
5)Re-assemble
Oct 10, 2007 | Pioneer SD-P50A5-K 50" Rear Projection...
Computers & Internet Logo
213 people viewed this question
David Payne
David Payne
