Philips dvd recorder wont switch on - Televison & Video
2 Suggested Answers
BobbyR1234
  • 173 Answers
SOURCE: No sound when watching TV
I would check all cables to make sure they are connected properly and secure, also check the cables for any defects ie bent pins, frays in wiring, etc. and check all connectors on the front or back of your tv (which ever way you have it hooked up) to make sure they are not loose or damaged first. 2. I know you can connect your dvd properly, but I have to suggest it anyway, go back through the manual and make sure all settings are properly set.
3. You may need to update your firmware, which you can find instructions in pdf at this link it will be the 6th link down in pdf. I tried finding your device on the manufacturer's website, but you need the model number, I will include that link as well. Since it only 6 months old, it should still be under warranty so I would check into that as most usually have 1 year warranty. If all else fails, it might be something internal with the dvd recorder and you will have to get another one or take yours to a repair shop, but if you do take it to a repair shop make sure it is one that is reputable and trust worthy. I hope this helps you out and I am sorry I could not be more specific on the problem.
Posted on Jun 02, 2008
I have a Philips DVD recorder/player HDR3700. Works fine except when recording comes on the TV channel being watched changes to the channel being recorded which means I have to switch back to the TV...
Its a bug. I have one too and it does the same thing. Try asking Philips support at: http://www.support.philips.com/support/contact/contact_page.jsp?userCountry=us&userLanguage=en
Mar 01, 2015 | Philips Televison & Video
Why wont my vcr record
Well,this depends on what you're trying to record.If it's a DVD that's protected by copy right laws then you are attempting to commit a Crime.You can only record television content and even that I'm unsure of.See copy right laws in your state.Hope this helped.
Mar 29, 2012 | Philips Magnavox DVD/VCR Dual Player
Philips record player
Hello
If use box trips out when you switch ON thie DVD player, the power supply regulator board inside the DVD player has some kind of Diret Short circuit with it. The set needs through checkup, sometimes the power regulator boad may need replacement. The components of philips power supply systems are ver difficult to get from open electronic spare part market. OK.
Nov 11, 2011 | Televison & Video
Recording with a philips DVDR3480 using dvd+r
my phillips dvdr3480 will not let me record from my camcorder it states writing has failed please help
Dec 10, 2009 | Philips Televison & Video
Have i deleted my video
It's deleted,the disc protocol has changed bij the Philips recorder.
Jul 31, 2009 | Philips DVDR3320 DVD Recorder/VCR
Recorded discs wont play on an other dvd player
you have to finalise the disc when finished recording then it plays on any dvd player
Feb 15, 2009 | Philips DVDR3380/05 DVD Recorder
Get an error when i try to record
The strange thing about the Philips DVD players is that -R and -RW discs automatically record in +VR Mode. If the current discs you are using are -R/-RW's, then switch to +R/+RW, but usually you have to do the opposite - you are probably recording on +R discs - just switch to -R or -RW discs. All the Philips recorders do this to one extent or another. Good luck!
-Tha Mp3 Doctor
Jan 10, 2009 | Philips DVDR3545V/37
Philips DVDR3450H Recorder does not record all of timed programs
When setting the record timer make sure that PDC / VPS is switched OFF.
PDC - Programme Delivery Control / VPS - Video Programming System is designed to allow for late starting or running programmes. Not all channels support PDC/VPS, so the recorder may be waiting for a PDC/VPS signal which isn't there.
Jan 17, 2008 | Philips DVDR3450H DVD Recorder/HDD...
Wont record only on dvd+rw
Sorry but your laser is going! +R disks need a slightly higher burn power. Eventually you will have the same fault for RW disks.
Nov 30, 2007 | Philips DVDR70 DVD Recorder
Philips dvd player 616k
have you tried to record in sp then playback on same machine if this works then your drum for recording in lp or if yours has ep mode may need replacing as pre recordings are ok you need to get it serviced. hope this goes well
May 25, 2007 | Philips DVP642 DVD Player
Televison & Video Logo
61 people viewed this question
Top Televison & Video Experts
Electro Med Services...
