Question about Dishwashers
Impeller not blocked, what next? - Dishwashers
  • 17,130 Answers
Checking tips : click on Maintenance
Posted on Jan 24, 2013
Hi volvo penta 280 not sucking up water,ive replaced impeller etc etc motor its perfect and stays cool but the leg seems to be blocked and ive put a coathanger up there etc but water wont come through
first suspicion is that the impeller was not installed correctly and the vanes of the impeller are working in the wrong direction
it is possible that if the impeller was incorrectly installed that the vanes have been torn off
Nov 29, 2017 | Volvo Boating
Inlet/ drain light is flashing,I have cleaned out the basket, but it is still flashing and wont start. what do I need to do know?
Difficult to get help if you don't say what dishwasher it is.
Is it a Meile? This is a common condition foe Meile dishwashers and it usually means there is something blocking the outlet beyong the basket. I have a Meile and the first part of this fault fixing guide is normal.
The pump impeller may be unable to turn due to some muck blocking it. The first thing to do is remove the cover of the impeller. It is under the filter in the bottom the dishwasher. They have changed the design over the years, but there will be a plastic clip that you push or squeeze to allow you to slip the cover off. In the cover there is a ball bearing, you should be able to shake the cover and hear the ballbearing move. You can see it from the underside. If it doesn.t move freely this could be the problem, but this is unusual.
Next with the part you have removed out of the dishwasher, close the dishwasher on and turn it on for 5-10 seconds, this is to try and clear the obstruction. Next open the dishwasher again and put your finger down the opening the cover you removed from the impeller and see if the impeller moves freely. If it does, put everything back together and see how it goes. If it still will not start it is likely to be a blockage in the outlet pipe.
First remove the impeller cover again, this to rellease any pressure in the outlet hose so water doesn't gush out quite as much when you do the next bit. Get a large bucket or two ready and with the machine off loosen the clamp on the outlet hose where it joins the s-bend at your sink and remove the pipe from the sink. Here is where you need the bucket or maybe two. Of course if it is blocked you don't need the bucket yet. Check the pipe and the nipple on the s-bend to see if there is a blockage and remove it, then replace and tighten the clamp. The outlet may be blocked by solidified fat or something else, this happens if fat it emptied down the sink and it doesn't take much. When the fat hits the cold water in the s-bend it solidifies straight away and if it gets in the dishwasher pipe it blocks it. A very common issue with all dishwashers and people who pour fat down the sink.
Hope this is all it is, but possibly the pump or something else is cactus.
Feb 16, 2017 | Dishwashers
Motor runs but no pressure craftsman 2700 easy start
some filter is blocked up or the impeller is full or rubbish
motor runs so impeller should work
no preasure
something blocked hoxe kinken
start valve not actuating {check intake flow sensor}
Jun 04, 2015 | Craftsman Garden
OVERHEATING. THERMOSTAT GOOD. IMPELLER LOOKS GOOD. IMPELLER TURN WHEN THE ENGINE IS STARTED [REMOVED COVER]
blocked radiator fins,tubes,fins perished,.renew thermostat with genuine one.they are not worth relying on old ones.take it to a radiator specialist if radiator looks blocked.Sometimes dirt collects between radiatior and airconditioning radiator
Mar 18, 2015 | Cars & Trucks
Samsung dishwasher starts and after while stops with three lights cycles on (heavy , normal and quick)
I think that light combination means "Drain error". Most comonnly caused by something hard getting down into the drain pump, blocking or partially blocking the drain pump impeller or the check valve inside the drain hose right next to the drain pump.
Feb 24, 2015 | Samsung Dishwashers
Radiator top hose busted now there is noise in engine, sounds like water got in engine through intake or plugs got wet/ wiring. draining oil looking for water in it. If water in oil and now a noise were to...
no be carefull and dont play with something you dont understand ,noise could be the plastic impeller on the waterpump drive shaft come adrift causing the engine to overheat and burst the pipe and the noise is the impeller loose inside the block housing
Sep 27, 2013 | 2007 Dodge Charger SRT8 Sedan
Impeller
by Osko Pool n Spa If your Swimming Pool or Spa Pump Motor is humming and/or has very little or no water flow, please follow the following directions.
1) Remove the pump motor from the system.
2) Disassemble the front half of the Pump Pot Housing from the back half.
3) Check for any foreign obstructions which would jam the Impeller and remove it
4) Next, inspect the Pump Motor Impeller itself. (This is a high suspect part). See if there is any sign of wear or breakage. (This happens over time from debris in the water passing over the impeller). If so, your Impeller is damaged and requires replacement.
5) Next, remove the cover from the rear of the Pump Motor. Using a large standard blade, (straight), screwdriver or wrench... turn the main motor shaft. Listen for grinding and/or rumbling and feel for any restrictions while turning. If you hear or feel either, your bearings and/or brushes are damaged and need replacement.
If everything seems to be in good working order, then you need a new pump... not just replacement parts.
May 26, 2013 | Hayward Pool & Spa
Won't drain and won't spin ,makes a clicking sound
sound as though the drain pump has something hitting the impeller making the clicking noise,and the filter basket next to the pump is blocked by debris and not letting it drain
Sep 01, 2012 | Maytag MAH6700AWW Neptune Front-Load...
Dishwasher doesnt drain
need to check in sump next to drain pump to see if there is something blocking impeller.
Nov 04, 2009 | Frigidaire 24 in. FDB1050RE Built-in...
Water will not drain.
This problem is often due to a blockage in the impeller blades which are located under the filter at the bottom of the dishwasher. Remove the filter and you should be able to get to the impeller by undoing a couple of torx screws. If the impeller has been blocked (this could be by something as small as a grain of uncooked rice), remove the obstruction so the impeller turns freely.
Nov 04, 2006 | Bosch 24 in. SGS43E02 Exxcel Built-In...
Dishwashers Logo
Top Dishwashers Experts
