Question about RCA D52W19 52" Rear Projection Television
Replace transformer can anyone tell me how to remove and replace the flyback transformer on a rca 52 in tv ?
    Novelist:
  • 184 Answers
You will need a good quality soldering station, some solderwick to remove the solder from the transformer's pins on the underside of the circuit board. You can also use a solder removing tool but its a costlier device. You will have to remove many connectors and screws to free up the board so that you can access the underside of the board. You will also have to disconnect the anode lead from the high-voltage divider block, making sure the TV is unplugged and that there is no charge left in the CRTs.
If the preceding paragraph reads like greek to you, don't attempt to do this yourself!
michtech
Posted on Feb 13, 2009
Where is the verticle output IC on my 52 inch rca projection tv
if you remove the rear panel you will see the board on the far left has a large transformer with a large red HV cable coming out of it. Thats the flyback. Now look to the right side of that board in line with the flyback. The aluminum heat sink with the fins has the verticle IC. Its the first heatsink closest to where youre looking on the right side of the board with the flyback.
Dec 06, 2009 | RCA R52WM24 52" HDTV Projection Television
I have the RCA 52 in hd 5267 can someone tell me where the flyback transformer is located. I see where dave1645 said how to fix the problem of the 3 dimension colors i just dont know heer that stuff is...
Remove the Back panel, Then look to the far left lower board you will see a large transformer with a thick red wire coming out of the top of it. Thats the Flyback. There are three small brown rectanges just to the right side of the flyback. The center one is FL231. When that fuse blows your convergence will go out of alignment and the option will disappear from the menu.
Dec 04, 2009 | RCA HD52W56 52" Rear Projection HDTV
RCA 52in. Projection TV D52W19B does anyone
Hello butmommy03,
This is the procedure but first I must warn you. You are dealing with one of the most dangerous parts of a TV The High Voltage anode or the CRT and the flyback transformer. That being said this is what you have to do:
1) unplug the TV from the wall or power strip.
2) take the back of the TV, and find the High voltage trippler and using a screwdriver grounded by a clip-lead to the grounding strip touch it to the exposed metal of the input to the High Voltage trippler.
3) using a soldering iron de-solder and remove the wire from the HV trippler.
4) Once this is done, angle the chassis to expose the bottom of the Deflection board, if this is no possible you will have to remove the deflection board to get a look at the bottom, once this is done and you can view the bottom of the board using a soldering iron and a de-soldering pump you can remove the solder from around the pins of the flyback transformer about 10 pins in all. Then remove the screws that hold the flyback in place. this is the procedure you requested,
However again I must ask you not to do this yourself and to get a qualified TV technician to troubleshoot this TV for you.
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Jun 27, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
I replaced the fl231 fuse in my rca HD52W58 and it went back out
Had the same problem , you have to resolder the flyback before replacing the fuse.
Jun 25, 2009 | RCA HD52W58 52" TV
I have a RCA HD 52in and I'm have a problem with the Convergence Ic's
Hi, rca`s don`t have convergence IC`s, they use an entirely different system to perform convergence, you have a blown chemical fuse and 3-6 bad solder joints on your flyback transformer. replace fl231 chemical fuse rated at 400ma. right beside flyback (theres 3 of them your bad one is the middle one)and while your soldering re-solder all of the flyback transformer pins and your tv will be back to normal :) video-tek
Jun 04, 2009 | RCA R52WM24 52" HDTV Projection Television
Need to know how to install a flyback in 2004 52 in RCA tv.
First and foremost, disconnect the power cord from the mains.
Next, after having removed the back cover from the set, discharge the tubes' residual high-voltage to ground using a suitable tool.
Access to the transformer is pretty much staightforward here.
A few hardware removals and you can then get to the board and transformer..
Mark, then remove all leads that go to the unit.
INstallation is the reverse of removal.
Be sure to replace the driver device, just to be certain...accordianman
Dec 12, 2008 | RCA D52W19 52" Rear Projection Television
52" rca projection screen tv
If the light blinks 3 times its most likely the flyback. Your model uses flyback 259296 and you can get a replacement at the following link and they have free online instant messageing with a tech when you replace the flyback so they can take you step by step while you change it. Hers the link its flyback 259296.
http://servicemanuals.vstore.ca/
Aug 09, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA P52937 Flyback Transformer question
The lead going from the flyback to that other device is a voltage divider or splitter as they're incorrectly referred to... To remove the leads press down firmly, twist and then pull up...
Bill
Nov 21, 2007 | RCA P52937 52" Rear Projection Television
Flyback Transformer replacement instructions?
remove solder from all pins and squeeze clips to remove...
Oct 12, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Tv will not turn on with remote or when I press the power button on the tv.
The P52960 uses the PTK195 series chassis. The most common cause of that set not starting up is a shorted flyback transformer. It is quite easy to test and replace the flyback transformer in that chassis, but that should be done by a qualified tech experienced in RCA projection sets.
Sep 18, 2007 | RCA P52960 52" Rear Projection Television
RCA D52W19 52" Rear Projection Television Logo
191 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
