Question about Garden
I have a Lutian 168F pressure washer and the pull chrod mechanism is broken. One of the two small metal plates on springs has been lost and the other now slips out of its housing each time I use it. Any ideas please where I can get spares for it, I live in the UK. Thanks, Steve
  • 10 Answers
SOURCE: where does small spring fit
Most Karcher guns I have worked on have had a spring behind valve between hose pipe inside gun.
Posted on Apr 22, 2009
SOURCE: Karcher pressure washer 411A. loss of pressure...
411a when i turn on it gos for 1 min then i have too press it on and off 3or 4 times befor it works and it only stays on for 1 min.
Posted on May 21, 2009
  • 202 Answers
SOURCE: NO PRESSURE
check the coupling or the belt between the engine and pump. unsure which this washer uses. the pump may also have failed, usually it is the coupling or belt broken or slipping
Posted on Jul 09, 2009
  • 389 Answers
SOURCE: Alto Kew pressure washer stopped working!
Hi Steve, In 3 years of repairing pressure washers I've only ever seen one of these, and am having a hard time remembering much about it, except that it was really awkward to work on! Strictly speaking, many small pressure washer repairs are uneconomical, because the labour time involved costs almost as much as the machine is worth. However, a "motor won't go" problem does narrow things down a lot. To state the obvious, we're looking at an electrical problem. The challenge is to find the cause! Did the motor stop while you were using it, or did it fail to start when you got it out of storage? If you are in the UK you should first check the plug-top fuse and the full length of the flex for any damage. If you have any kind of low-voltage electrical testing device, you can test for continuity between the live and neutral pins of the plug (with the machine switched on you should have continuity). If you have no continuity (and the fuse is OK) there may be a problem with the switch on the machine. Unfortunately, unless you are a really keen DIY person, there's not much you can do by way of self-help. A repair centre may be able to help you, but beware of costs spiraling beyond the cost of a replacement machine. I hope this will be helpful - if you can give more details I'll help further if I can. Good luck!
Posted on Aug 16, 2009
  • 174 Answers
SOURCE: northstar pressure washer randomly gives pressure
Hi:
You need to find the bypass (unloader) valve and grease it with a good waterproof grease. Sorry, I cannot find a pic for you
Posted on Sep 03, 2009
Does the end of the pfaff 7570 sewing machine open up?
Consult your owner's manual. It should show how to open your machine (if it can be opened by other than a professional).
Oct 13, 2015 | PfaFF Creative 7570
How to recoil the spring on a pull start cord for a craftsman pressure washer model # 580 750 400
If no repair manual. It could be spring is broken. So I'd look for spring, and instructions to install spring. That should give you a good idea. I suppose the handle came off and lost the rope inside? Probably need new rope too. Same kind of instructions would apply in how to recoil if it's not broken.
Mar 13, 2015 | Craftsman Garden
Where do the springs connect on carb.
On most small engines the only spring that matters is one that goes from throttle plate on carb to end of governor arm. This spring must be exact unit, and hooked up in exact spot, because the system works by delicate balancing act. The spring is just strong enough to keep throttle closed most of the time. But when governor arm pulls then the spring is overwhelmed and it lets throttle get pulled open. This is the way that engine gets more power when under max load. If you go to site like Jacks small engine and put in engine numbers you may be able to see where spring went by looking at picture. If you do not have original spring - get one. Motor will never work right without balanced spring. If you run with no spring and throttle goes wide open - even for a minute you will over speed motor.
Oct 13, 2014 | Briggs Garden
Comet pressure washer is pulsating
check your check valves.
or one of the wobble plate pistons is not working right ( broken, broken spring etc)
Aug 17, 2013 | Comet AXD 3020 G Pressure Washer Pump
I have a Bernina Artista 180 that has a spring hanging down inside the door of the bobbin case area . Where does that connect
Your Bernina 180 is a rotary hook model and there is a bobbin case retainer mechanism below the sticth plate that has a long spring on it - it sounds like this has become detatched at one end and may well be affecting the stitch quality. Take the stitch plate out and you will see a black rectangular metal bar in front of the rotary hook mechanism - there is a small silver part in the middle that fits in a slot in the rotary hook bobbin basket - the spring should fit on this and then extend the length of the black bar and pull onto a retainer at the other end so that there is fairly strong tension on the silver part. If not this spring, then it's probably something that's dropped-off from elsewhere and maybe, possibly the feed-dog cam retaining spring. Let me know what you find.
Feb 07, 2012 | Bernina Artista 180
Won't start. Pull chord will only come out quarter of the way.
There could be two possible problems here.
1) Usually you want to squeeze the gun trigger to release backpressure on the pump so the engine will turn over easily. So hold the gun in one hand with water coming out of the gun while pulling cord.
2) The pull cord mechanism is connected to top of power washer with 3-4 bolts.
Take off those bolts and see if you can unravel the problem. The mechanism is connected to a spring and the spring pulls the cord back in ... so it seems like the rope is in a bind or the pull mechanism is bad.
We had to buy a replacement pull cord mechanism at one time for our power washer, but I forget exactly why it stopped working. We used the power washer two days a week for years. It's aggravating when it doesn't work.
Oct 17, 2010 | Briggs & Stratton Prosumer 20324 Gas...
Pfaff 1471 presser foot does not go down
This procedure is SPECIFIC TO THE PFAFF 7570. It MAY work for you. Try at your own risk.
Needed tools:
Small flat screw driver.
Large Phillips screw driver
Small torx screw driver
Large torx screw driver
Small cleaning brush
Small scissors and long tweezers.
Machine oil.
Old tooth brush.
Dish detergent.
Lots of care and patience.
In this particular case, perseverance was the winner. I'm quite handy with mechanical things, so I had to partially disassemble the machine until I found the cause of the problem. The foot presser mechanism DOES have a spring, but it's concealed and out of sight. I never suspected it, but that was the case. When I found it, white grease that was put there at the factory to lubricate its movement had turned into a think sticky gunk. That was what was holding the foot presser in the up position. This gunk was so stubborn! I had to clean the spring, the housing and a plastic pin really well, and then oiled all the components inside their housing. More below.
The shaft of the foot presser is hollow at the top. This is designed to hold a 1-5/8" spring and a 5/8" black plastic pin that's inserted at the top of the spring and protrudes from the hollow shaft.
Start placing the 7570 on a table that has a height that's comfortable for you. You'll be standing and squatting a lot to accomplish the task.
Standing behind the machine, and looking down, there's a metallic plate on your right that holds the thread tension discs. This plate covers the shaft, found underneath, and holds together the mechanism with the round wheel with numbers that protrudes slightly on the side of the machine's body.
Several pieces had to be disassembled in order to get to this plate, although at this point I'm doubting whether or not so much work was necessary, since I was so excited upon the discovery that I forgot to notice whether I could have found the spring and remove it without having to disassemble so many pieces.
The metal plate is black and thick, and is held down with a heavy gauge black machine screw. The plastic pin makes contact with the underside of this plate, which compresses the spring when the foot presser lever is up. Once the lever is disengaged from its locked or resting position (in the case of the embroidery position), the compressed spring pushes the entire foot presser down, as it DID when I first bought the machine.
These are the disassembly steps, without diagrams, but use your imagination as best you can to picture my description.
1 - Top cover removal.
The top cover (the one with the different built-in patterns drawn on its inside face) is held in place by two thin black metal plates where it hinges. A little bit of pressure towards the outside on the top of one of the plates (on either side) will release the pivot pin on one end, and then a little jiggle in the same direction will release the other. Put the cover aside.
2 - Concave top cover removal.
This cover is the one that houses the thread spool in the horizontal position, if that is your choice when sewing. It is held down by two plated machine screws, one short and one long. After removing the screws a little jiggling will help removing it, pulling it mainly upwards. You may need to put the large handle up, to allow for more movement. Put it aside once removed.
3 - Side cover removal.
This covers the area where the foot presser is housed, on the left side of the machine, as you face the buttons on the front of the machine.
Standing behind the machine, once step 2 has been achieved, one can see from the top, looking down, a large black machine screw on your right hand side, just inside the cover. You don't need to remove it completely, just about 1/2 turn will loosen the pressure to release the cover. Pull the cover outwards and sideways and set aside. You may want to also remove the light bulb, to be able to get to the mechanism to clean it, to remove pieces of thread that may be lying around or caught in the different moving parts. Push the light bulb gently in while turning it counter clockwise. You'll feel it disengaging from its socket. Pull it out and set it aside. Clean it if necessary. Use the scissors and the tweezers to remove any lint and debris.
4 - Pressure discs plate removal.
I'm not 100% sure now that this can be done at this stage, but continue. If this particular plate cannot be removed, because other components get in the way, then skip to step #4A below and come back here later.
Standing behind the machine, looking down at the housing, you'll see another large black machine screw holding down a black metal plate. Remove it completely and put it aside. Next, remove the plate, gently nudging its way out of the different obstacles that may be present. One of them may be the sewing shaft mechanism. If this is the case, gently turn the wheel manually to cause the mechanism to move up or down, as to allow more room for the plate to be completely removed.
Make sure you lift this plate slowly, as to prevent the spring and plastic pin from spilling inside the machine's body. Put the plate aside. Now you see the black plastic pin, perhaps stuck inside the hollow part of the foot presser. If so, pry it loose gently and clean it with a sudsy solution, and use an old tooth brush to remove the gunk from its coils. Do likewise to the plastic pin.
While you have the housing exposed with lots of space, I would suggest you should remove any debris, dust, etc, and oil all the moving parts with sewing machine oil.
5 - Assembly.
This is done in the reverse order. Congratulations! You've done it!
Additional steps, if metal plate in step 4 above cannot be removed after step 3.
4A - Front plate removal (The one with the colored buttons and LCD display).
Standing behind the machine, looking down, you'll see a grey ribbon cable crossing the case from back to front, under the main shaft. Remove its connector by pulling it up gently. No force or tools are necessary. Bend the ribbon to one side and set it aside, out of the way.
Squatting a little from the same position, looking inside the foot presser housing, you'll see two small plated screws, close to the edge of the housing, one towards the top and another towards the bottom. Remove completely.
In the same squatting position, and moving your attention to the main machine housing, you'll see the green PCB board. It's held by at least three screws. One of them, on your extreme left, is not visible because it's concealed by a plastic insert at the top of the left end of the 7570. This insert is held down in place by a thin black metal plate. This plate has a tiny hole where the top cover of step 1 hinges.
Gently turn the small torx screw holding down this plate 1/2 turn counter clockwise to release the pressure. Once loosened, slide the plate slightly towards your right. This will allow you to pull the insert up.
With the insert out of the way, squatting again, you'll see the third plated screw on your left. Remove it.
Turn the machine upside down and ensure it's not rocking from side to side.
Use the large torx driver to remove the machine's base. This base contains a power supply box, and another green PCB board. It's connected to the rest of the machine with several ribbon cables of different colors. The base is attached by 4 machine screws. Loosen the screws completely and remove using the tweezers.
Raise the base from the right end, allowing its other end to rest on the edge of the inverted 7570 body and stand it at 90°. Inspect the location, orientation, and general layout of the cabling. You may need to unlatch one or more plastic holders for the ribbons, which hold them flat and organized. Remove these holders to have greater access to the connectors.
Jot down the order of the different ribbons and the way the are inserted into their sockets on the PCB found inside the base. Fortunately the connectors are of different sizes, and there should be no way to insert the wrong one in the wrong socket, but it's best to be safe. Jot down order, color, etc.
Gently pull on the different connectors from the PCB board. A little bit of force is all that is needed. Push them aside one by one in order to allow you to see more and create more space.
Next, disconnect the large power cord. You need to insert a small flat screw driver to release pressure on the sides of the socket. Do it one side at a time, and then gently pull it out. Set the base aside. You're almost done!
Next, looking down, pushing the ribbon cables away from you, you'll see two plated screws in each corner of the inverted 7570 housing, on the side closest to you. Remove completely. At this time you should be able to remove the face plate, gently threading the widest of the ribbon cables through the opening on your left, in order to put the base aside.
With the face plate out of its position, put the machine in its straight up position and step 4 above can be accomplished.
Now, I also did remove the 7570 main handle in order to create more space and see more in the reduced area of the foot presser housing. If you too find it necessary to do so, use the corner of the tip of a small flat screw driver to pry the lock ring open, being careful not to allow it to spring out of your fingers and falling inside the case. Slide the pin out and then the handle itself, horizontally.
Go back to step 4 above if you came here because you could not do step 4.
Aug 22, 2009 | Kenmore 15218 Mechanical Sewing Machine
Pressure foot doesn't go down
needs to be serviced, you can ship to me i can fix keithat11@aol.com
Jul 30, 2009 | PfaFF Creative 7570
Cannot load staples
At the back of the staple gun is a flat shaped metal piece. It's at the bottom. Push in, pull down, then pull the mechanism out. You'll see it's a metal rod with a spring, that is attached to that flat metal piece. The spring pushes against another flat metal piece, that has a hole in it, and travels back, and forth on the rod.
The flat metal piece that the spring pushes down the rod, pushes against the staples.
Remove this spring mechanism, slide the staples down the rails. The staples will be in the position of an upside down U. Replace the spring mechanism, and lock it back into place. (Push in, pull up)
Should, your question be in reference to the fact that you have staples loaded, but upon pressing the trigger nothing comes out:
In the front of the staple gun, is a flat metal piece that pushes down on the staples. One staple at a time. The flat metal piece is shoved down by spring pressure. The spring pressure is applied to the flat metal piece each time you squeeze the trigger. (Flat metal piece = Hammer)
Sometimes, Two staples try to come out. When they do, this flat metal hammer is stuck up in the gun. To free the flat metal hammer, remove the spring mechanism out of the back of the staple gun. (The spring mechanism discussed above) Remove any staples in the gun.
Try to use a flat blade screwdriver, and see if you can shove the flat metal hammer in the front of the gun -> UP.
(DO NOT have the staple gun pointing at your face! DO NOT squeeze the trigger! DO NOT use excessive force)
If this method is of no avail for you, you have to disassemble the gun, and remove the metal hammer, and stuck staple/s.
Jul 29, 2009 | Arrow T50P ARROW STAPLE GUN
Garden Logo
122 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
